Decontamination of Customer Returned Product - Seeking sample procedure
sardonyx
Is there anyone out there that can give me a sample procedure on how to decontaminate a customer returned product. Any sample will do I just want to have an idea on how do you handle this. Or do we need to have a procedure for that? Thanks!
G
Gert Sorensen
What kind of products are you producing? The procedure would be different depending on the product, and the possible contamination.
RA Princess
Hi everyone
I am puzzling over the same thing at the moment. :confused:
We manufacture long term implantables that come into contact with the central nervous system. Can anyone offer any advice please?
SteelMaiden
What do you actually do, now? just document what you are doing, along with any improvements to the process you would like to see.
Obviously, you know that you have things to do with returns, so the best thing you can do is document it. None of us are as well versed with your particular product as you are.
RA Princess
Thanks for the reply. Sorry I should have explained a little better. This is our first product we are looking at taking to market. We are currently implementing ISO 13485 and are looking to CE-Mark for sale in Europe. So unfortunately at the moment we dont do anything. :(
RobRoy
Not sure If I'm on the right track here, is it a Return Authorisation procedure you are looking for?. If so I have attached one which you can customise.
If on the other hand these "Devices" are contaminated with body or spinal
fluids , then you can't just mail them through the post.In the NHS in the UK
the Trusts have procedures to decontaminate and mark material that needs to be maintained,repaired or returned to the manufacturer and must fill in a decontamination declaration(see attached example).This is all explained in the MDA bulletin DB2003(05) which is also attached.
This alone though is only a small part of your Material Control Process and
won't be much use on its own.If you need to know a specific Sterilisation procedure then contact me.I have a lot of info.
Hope this helps
Roy
V
victoriab65
For used devices, especially those in contact with central nervous system, you need to be aware of the risk of prions. The WHO Infection Control Guidelines (attached) outline the latest thinking in prion decontamination for surgical instruments. It is also available freely at their website:
http://www.who.int/csr/resources/publications/bse/WHO_CDS_CSR_APH_2000_3/en/
Undiluted bleach for one hour is probably the easiest method, if your device can handle it.
The standard practice followed by med device manufacturers for decontamination of used devices has been glutaraldehyde (e.g. Cidex). Please note that glutaraldehyde (e.g. Cidex) preserves prion infectivity.
RosieA
Why not require that any returned material be cleaned and (if necessary) sterilized prior to being returned? Put the onus on the customer for protecting everyone in the chain!
In a past life I worked for a medical devices company and we put this policy in place after receiving a device back that scared the poop out of our Returns Coordinator. The device is designed to come in contact with blood and tissue during surgery. When we opened the box, there was our device, bloody, along used needles and a half used bottle of Heperin. Obviously it came right from the surgical suite. :mg:
After that we insisted on cleaned and sterilized product. Our Returns Coordinator also was required to get the Hepatitis vaccine.
In my present job, which is as far away as you can get from medical devices, we got some product back from a meat packing plant that had pig hair and guts attached to it. No hesitation on my part: we rejected it back to the customer and required that it be cleaned before we'd touch it. Animals can transmit disease too.
You have to protect your people and everyone in the transportation chain!
I am working in a medical device company and we often receive samples for investigation; we face the problem with contaminated products -administration sets- which are coming from the hospitals and sometimes contain blood as they are in direct contact with the patient. The issue here is, who's responsible to clean/decontaminate samples before shipping back for investigation? And what if those samples contain medicine fluids or drags for chemotherapy as well; Transportation companies also deny to carry out these samples containing drugs.
Any feedback on this is more than welcome and thank you in advance,
Kind regards,
Thanos
T Decontamination responsibility on customer complaint investigation Customer Complaints 4
D Hospital Decontamination and the MDR - Technical Files, UDI and PMS EU Medical Device Regulations 3
A Decontamination of Site returned Material ISO 13485:2016 - Medical Device Quality Management Systems 3
M Decontamination Label on Unit Packages per UL (Underwriters Laboratories) Manufacturing and Related Processes 1
D Decontamination of "Used" Complaint Product & Disposal of Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
M Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 6
R Cpk demands from automotive customer Capability, Accuracy and Stability - Processes, Machines, etc. 5
briteme4 Customer Requests FAI on Tooling Fixture AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 3
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
G Too many customer complaints Customer Complaints 16
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
G Risk of stopping your customer's line IATF 16949 - Automotive Quality Systems Standard 4
D CB and customer audits considered as internal audits? General Auditing Discussions 9
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
B Retention Samples when Customer Leaves Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Email Template that go to a customer and then get returned to us for RMA/Warranty Document Control Systems, Procedures, Forms and Templates 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Quality review Meeting with Customer for complaints we received Customer Complaints 6
D IATF16949 - Interpretation of Customer Requirements clauses IATF 16949 - Automotive Quality Systems Standard 3
S Obligation to accept customer audits? IATF 16949 - Automotive Quality Systems Standard 23
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
S Customer Specific Requirements (CSR) not signed/approved IATF 16949 - Automotive Quality Systems Standard 17
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
R Customer Satisfaction importance in companies with Government/Public Administration as main customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ooi Yew Jin Customer E audit preparation Quality Manager and Management Related Issues 2
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
S Issuing of CoC to Customer in a Word or Excel format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Design Transfer Template capturing Customer Specific Requirements Other Medical Device Related Standards 3
W Direct to customer export of medical device (class I: prescription lenses + frame) US Food and Drug Administration (FDA) 2
