Defect Detection for Fresh Injection Molding Solid Parts
K
KCIPOH
Hello Cove members,
Good day. Our production are having a difficulty in detection of the bubble inside a solid PP white color injected part (not transparent part), at customer side, they will drill holes and put in brush furr.
If there is a bubble (size of a red bean) in our product, this will cause problem of cannot assembly the furr on the drilled holes.
I'm thinking of having the part weight as a detection point to detect whether there is a bubble inside a part but i think the weight shown will be very less and cant justified the defect.
This raw material are mix with blowing agent by our mixer.
Need inputs on this :confused:
Checking the weight was the first thing that occurred to me as well, but what about the reason for the bubbles? How common are they, and what is currently being done in order to avoid them altogether?
/Claes
BridgeGap
For detection, part weight is the way to go, using an appropriate inspection plan.
There are scales for this, calibrated according to your needs.
And as Claes indicated, while you are utilizing an interim detection process, I'd really be looking after the root cause. Its a pretty common and easy to fix processing problem. If the technical ability of your processors is insufficient to deal with this, I'd get with your human resources department real quick.
Good luck
K
KCIPOH
Hello Claes,
Fyi, this is the first time we have this problem with our customer and currently QC are checking 5 pcs/hr for the critical defects, i'm having to destruct the part using jigsaw during the first shot of production run each time but would it help? as for the rootcause, we are in the progress.
Thank You for inputs :)
Hello BridgeGap,
Appreciate your inputs as well :)
kuyakut
Hi
Does heating the part with a hot air gun cause the 'bubbles' to collapse and then reappear when the plastic cools?
This is still your main question to answer because the remedy for voids is usually different than for bubbles.
Voids are packing and cooling - bubbles are trapped gas and venting. Bubbles are ususally near the surface - voids can appear anywhere but usually near the middle of the wall.
It can be minimize by Increasing Holding Pressure and Holding Time or Increase cooling time.
Kuyakut
K
KCIPOH
Hello kuyakut,
Fyi, once this part drop off from the mold, it will straight drop into a bin filled with cool water cooling by water chiller.
but i guess you are right, the defects i think i suppose to address here is void rather than air bubbles as it happened in the middle of the wall.
I'll duscuss your suggestion with my production guys and update you if any outcome.
Thanks and appreciate your inputs :yes:
W Measuring production performance - Defect Detection % vs. Internal Reject Registered Visitor Articles Archive 4
B What Process will ensure defect detection? Nonconformance and Corrective Action 12
U Determining population defect rate from sample defect rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Corrective action for a defect from customer's mistaken Nonconformance and Corrective Action 1
C Handling in-Process Defect Repairs Nonconformance and Corrective Action 31
J Average Industry Defect rates Supplier Quality Assurance and other Supplier Issues 2
I Old Time Scatter diagrams for defect type and location- software Quality Tools, Improvement and Analysis 7
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
J Definition Defect Mapping - Here is my definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 13
L How to write a proper defect description in a NCR Nonconformance and Corrective Action 4
Q Calculating Defect Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R Software change control process and defect tracking ISO 13485:2016 - Medical Device Quality Management Systems 1
G Defect codes and process codes need to be controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Fender1 Customer specified Item Defect Corrective Action Responsibility Customer Complaints 18
R Defect Display Area for Employee Shift Change Information Misc. Quality Assurance and Business Systems Related Topics 1
leftoverture PPM Defect Rate as a Performance Metric - Are there Flaws? Quality Manager and Management Related Issues 9
P Evolving Quality Levels - Expectations for Lowered Defect Levels AQL - Acceptable Quality Level 21
A Defect Rate for asking for an RMA - Company wants an RMA for every defect found Supplier Quality Assurance and other Supplier Issues 10
T Customer Requirement for Sorting - Visual Defect on Plastic Part IATF 16949 - Automotive Quality Systems Standard 9
P Visual Defect during Validation Process Design and Development of Products and Processes 6
J Classifying Defect Reports from Business Partners US Food and Drug Administration (FDA) 4
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A How Defect Rate Changes After Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N New to ISO 9001 - NCR for every defect? Nonconformance and Corrective Action 5
optomist1 Converting Defect Rate To Capability index Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Renault Painting Defect Acceptance Criteria Manufacturing and Related Processes 4
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
T Probablity of correctly detecting a defect size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Metal Stamping Defect--Need Help with Corrective Action Manufacturing and Related Processes 15
A Shall we raise SCAR/CAR for every defect as per our current procedure? Nonconformance and Corrective Action 4
M AQL (Acceptable Quality Level) for Mixed Part Defect IATF 16949 - Automotive Quality Systems Standard 1
S Are P-charts for a Particular Defect or can Different Defects be counted in one? Statistical Analysis Tools, Techniques and SPC 2
K Defect Reporting and Tracking Software for a Small Machine Shop Quality Assurance and Compliance Software Tools and Solutions 1
S Standard Machining Defect Codes Nonconformance and Corrective Action 2
R LTPD (Lot Tolerance Percent Defective) Sampling Plan with %Defect Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
1 Defect Tracking Excel Spreadsheet Template Excel .xls Spreadsheet Templates and Tools 2
S Measurement Error When Measuring a Defect - Scratches Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
S What if I find a defect after AQL (Inspection)? Pharmaceuticals AQL - Acceptable Quality Level 13
S Six sigma and defect rate (6 sigma = 3.4 PPM) Six Sigma 6
B Can Minitab 15 Chart Geometric Distributions with Very Low Defect Rates? Using Minitab Software 2
J Calculating Defect Rate or Percent of Rejection Manufacturing and Related Processes 4
D Herringbone Defect Condition in Rolled Steel Misc. Quality Assurance and Business Systems Related Topics 3
B Minitab Gage R&R using Defect Count per Unit Area Using Minitab Software 1
L Zoned Defect Chart - 9 zones with 12 possible defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J How to understand NOTE 2 in the ISO 9000 definition of defect? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Customer asks me about AQL for defect types AQL - Acceptable Quality Level 2
L Typical defect ppm level for barrel surface coating process? Supplier Quality Assurance and other Supplier Issues 1
