Definition Defect Mapping - Here is my definition
John B.
Registered Visitor
Hello all.
Here is my definition of Defect Mapping: "A problem solving tool used to visually identify and track physical locations and types of defects on a product."
Does anyone use Defect Mapping? If so, how? On what kind of processes are you using Defect Mapping?
Any advice?
Gratefully,
John
We use it under a different name (concentration diagram). It is useful for analyzing soldering defect (e.g., bridges) locations on a PCBA. You could also use it to study the locations of molding defects (nonfills, knit lines), casting porosity, etc.
Hello all.
Any advice?
Gratefully,
John
Hello John. I am new to Elsmar Cove and was poking around and saw your post. I know it has been a long time but I thought it couldn't hurt to add my comments. Defect mapping in my experience is used heavily in industries such as paint processes, casting, weld inspections, stampings and other processes where defects are usually attribute/visual/functional and it is important to know the location as well as the type of defect. For example, in a foundry application, it would be common to keep track of how many castings are being produced with a particular defect, such as porosity or shorts (unfilled section). It is important not just to know what defect is occurring, but also where the defect is recurring over a period of time/production runs. Knowing the recurring Casting measles.png location of the defect as well as type allows a process or tooling or quality engineer to have a much better idea of what the root cause is. For example, if I map short material locations over time by marking the location of short material on an image of my part, that would lead me to how I might change my gating, injection pressure, or other process factor that would affect shorts in a specific area. Or if I map "thin" areas on parts I am painting, if I see from my defect map/concentration diagram of where thin has occurred over some time, it will give me clues as to how to adjust my paint robot pattern, nozzle angle, part orientation, etc. The value is in being able to map defects on a single image of your part (CAD image, line drawing, digital photo) and see if a pattern emerges in the type/location of defects. Below are a couple examples of defect maps. The one on the left represents an image with a grid laid over it (like a 10 x 10 grid) with counts in each grid location of the number of defects in that grid area. The larger one is more of a defect "scatter" where individual defects from many parts are mapped on a single image.
John Predmore
I used a Concentration Diagram to solve my first problem for Red X certification. The die casting department had a big reject problem due to porosity. The castings had to be 100% visually inspected or else assemblies downstream would fail leak test and result in more expensive scrap. As I recall, this problem was costing them $75K/month. The engineers had spent weeks studying scrap parts, trying different settings, all in an attempt to minimize porosity voids. The voids which intersect the center bore were the biggest concern.
The Quality Engineer from the die cast department and I went through the scrap pile with a piece of graph paper, and in 10 minutes, we had prepared Diagram A on the left (I no longer have the original, so this is a re-creation). I remember our conversation, "It looks pretty random to me." Then, in a flash of genius, I suggested we turn the picture 90°. He measured the depth of the porosity voids with a ruler and a flashlight, and in 10 minutes I had prepared Diagram B. My friend looked at the picture and said "Oh my gosh, do you know what that means?" I said I could see it was not random, but I didn't know what it meant. He said the problem was the bung. I said I don't know what a bung is. He said the bung is the slug which forms where the two halves of the die cast mold come together. All the porosity was at the dividing line between the mold halves. The solution was to re-make the mold cavity and move the bung an inch higher. That way, any porosity which formed was in a non-critical area.
The morale of the story, the concentration diagram alone was not enough to see the answer, the quality engineer's knowledge of casting was not enough to solve the problem, but put those two together and we solved a $75K problem in 20 minutes. Turning a random problem on its side for a new perspective was also key to this success. I often say, "random" is more a statement of our ignorance than any useful description of the problem. I also say, if your quality people can solve a $75K problem in 20 minutes with proper tools, why would you have them do anything else?
John, That was a great real world case study. Not only highlighting the collaboration of individuals with different expertise working together to solve a problem, but also how having timely information presented in a meaningful way leads to a rapid determination of root cause. By the way, you left out the part of the story where you were given a large bonus based on the substantial cost savings...
John Predmore
Still waiting for that bonus, but I was rewarded in other ways. This was the beginning of a 4-year career as a full-time problem solver. Most engineers will tell you they solve problems, but solving the company's problems was my full-time job for 4 years. I got good at it . I was very fortunate and learned a lot. I am pleased to share with others on Elsmar.
“It’s amazing the things you can see when you look”. Yogi Bera
Graphical visualization of the Problem is the most critical tool we have s problem solvers to detect the non-random pattern.
This diagram is also called a measles plot.
One of the first reported uses of this approach was by Dr. John Snow during a major cholera outbreak (The broad street pump).
John Snow's map. Blue = public water pumps; Red = cholera cases
1611324074743.png [/QUOTE]
I Old Time Scatter diagrams for defect type and location- software Quality Tools, Improvement and Analysis 7
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
L How to write a proper defect description in a NCR Nonconformance and Corrective Action 4
Q Calculating Defect Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R Software change control process and defect tracking ISO 13485:2016 - Medical Device Quality Management Systems 1
G Defect codes and process codes need to be controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Fender1 Customer specified Item Defect Corrective Action Responsibility Customer Complaints 18
R Defect Display Area for Employee Shift Change Information Misc. Quality Assurance and Business Systems Related Topics 1
L PPM Defect Rate as a Performance Metric - Are there Flaws? Quality Manager and Management Related Issues 9
P Evolving Quality Levels - Expectations for Lowered Defect Levels AQL - Acceptable Quality Level 21
A Defect Rate for asking for an RMA - Company wants an RMA for every defect found Supplier Quality Assurance and other Supplier Issues 10
T Customer Requirement for Sorting - Visual Defect on Plastic Part IATF 16949 - Automotive Quality Systems Standard 9
P Visual Defect during Validation Process Design and Development of Products and Processes 6
J Classifying Defect Reports from Business Partners US Food and Drug Administration (FDA) 4
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A How Defect Rate Changes After Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N New to ISO 9001 - NCR for every defect? Nonconformance and Corrective Action 5
optomist1 Converting Defect Rate To Capability index Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Renault Painting Defect Acceptance Criteria Manufacturing and Related Processes 4
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
T Probablity of correctly detecting a defect size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Metal Stamping Defect--Need Help with Corrective Action Manufacturing and Related Processes 5
A Shall we raise SCAR/CAR for every defect as per our current procedure? Nonconformance and Corrective Action 4
M AQL (Acceptable Quality Level) for Mixed Part Defect IATF 16949 - Automotive Quality Systems Standard 1
S Are P-charts for a Particular Defect or can Different Defects be counted in one? Statistical Analysis Tools, Techniques and SPC 2
K Defect Reporting and Tracking Software for a Small Machine Shop Quality Assurance and Compliance Software Tools and Solutions 1
S Standard Machining Defect Codes Nonconformance and Corrective Action 2
K Defect Detection for Fresh Injection Molding Solid Parts Manufacturing and Related Processes 5
R LTPD (Lot Tolerance Percent Defective) Sampling Plan with %Defect Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
1 Defect Tracking Excel Spreadsheet Template Excel .xls Spreadsheet Templates and Tools 2
S Measurement Error When Measuring a Defect - Scratches Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
S What if I find a defect after AQL (Inspection)? Pharmaceuticals AQL - Acceptable Quality Level 1
S Six sigma and defect rate (6 sigma = 3.4 PPM) Six Sigma 6
B Can Minitab 15 Chart Geometric Distributions with Very Low Defect Rates? Using Minitab Software 2
J Calculating Defect Rate or Percent of Rejection Manufacturing and Related Processes 4
D Herringbone Defect Condition in Rolled Steel Misc. Quality Assurance and Business Systems Related Topics 3
B Minitab Gage R&R using Defect Count per Unit Area Using Minitab Software 1
L Zoned Defect Chart - 9 zones with 12 possible defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J How to understand NOTE 2 in the ISO 9000 definition of defect? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Customer asks me about AQL for defect types AQL - Acceptable Quality Level 2
L Typical defect ppm level for barrel surface coating process? Supplier Quality Assurance and other Supplier Issues 1
A Lamination Defect in Structural Steel Plate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Ring Joint Gasket Defect Types and their Consequences Various Other Specifications, Standards, and related Requirements 13
T Implementing Defect Logs into my existing Non-conformance procedure Nonconformance and Corrective Action 4
M Root cause analysis on non-defect defect reports? Problem Solving, Root Cause Fault and Failure Analysis 1
Q Defect Awareness Training - Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
S Quality Defect Management Software - Discussion and Recommendations Misc. Quality Assurance and Business Systems Related Topics 3
