Defect Prevention - We first have to observe a defect before we can prevent?
Marc
#11
Date: Mon, 2 Oct 2000 15:39:10 -0500
Subject: Q: Corrective or Preventive? /Green
Dear List Members,
As a temporary alternative to tires, please consider the following
actual event, and comment on
1. Is it a corrective/preventive action?
2. Is it a preventive action?
3. Is it both?
4. Does it belong on the discussion list?
Occurrence: August 1999
Conditions: Observed audit, "Certification Assessment" ISO 9002, 1994 Two auditors, two working days, the following event occurred at 3:30 PM on day one.
Senior lead assessor and his guide approached a machining center in preparation for conformity assessment of the activity in that area. As the two men entered the area an aerosol can of "bluing" sitting near the machine began to discharge it's contents vertically into space. The machine operator quickly grabbed the can and directed the uncontrolled spray into the machine oil sump.
No harm, no foul?
The auditor decided not to record the occurrence in his working notes. The auditor complimented the operator for quick thinking, they all laughed and went on with a fruitful audit interview.
The management representative learned from the auditor's guide of the event. At that point the mgt. rep. assigned someone to fetch the spent aerosol can.
The directions on the can were clearly visible, and among other user concerns was a warning not to expose the can to flame, excessive heat, and to store and use the product at a temperature range of 65F to 95F. NOTE: "August" - "Illinois" - It was 101 F outside the plant that particular day and no record was available of the interior temperature. As the observer I'll guess at 105F +/- 5.
The management representative dispatched three subordinates to search the entire facility for similar "dye" spray cans. Seventeen cans were found in various work areas. (all above 100F).
1. The spray cans were collected and moved into a air conditioned supervisors office.
2. The 2nd shift supervisor was informed verbally to use spray only if needed, and to return the cans immediately after use to the air conditioned environment.
3. The management representative typed up a "temporary" procedure for the use of the blue dye spray cans, and forwarded copies to each day shift foreman.
4. The purchasing agent was left a hand written note to investigate the purchase of an alternative product with less critical temperature constraints.
5. The management representative then documented the days "blue dye" event on a standard internal corrective action form, and then duplicated the same information on an internal preventive action form.
6. Verification of the corrective action was to visually inspect the plant for any similar dye spray cans and/or verify that replacements were obtained and/or controls implemented to ensure proper storage and use of the spray product.
7. Verification of preventive action was to implement a search of the entire plant for ANY other aerosol cans that might have a similar potential risk. (reaction dependent upon search findings).
This is an actual occurrence. I believe it represents the very best that ISO has to offer to any organization. I don't recall ever mentioning to anyone before now that this occurrence did not effect "finished product quality"
Your opinions and comments pro or con would be appreciated.
Thank you in advance
Joe Green
Date: Wed, 4 Oct 2000 16:06:10 -0500
Subject: Re: Q: Corrective or Preventive? /Green/Andrews
Ole Joe wrote (in part);
Joe,
From your post it seems that this company (or at least the management rep.) knew what they were doing. Corrective actions were implemented (removal of all blue dye cans to safe storage area and Purchasing to investigate alternate supplies). Preventive action was undertaken (entire plant was assessed for other spray cans that might have similar temperature constraints). All sounds good to me.
One question though - with the temperatures well over 100 degrees F (enough to send spray cans into premature discharge) - what impact does the temperature have on the HUMAN resources in the manufacturing areas? Is this considered a "suitable" work environment?
My 2 cents.
Ethan Andrews
Date: Wed, 4 Oct 2000 16:16:16 -0500
Subject: Re: Q: Corrective or Preventive? /Green/Randall
> From: Joseph & Susan Green <[email protected]>
> Dear List Members,
> 3. Is it both?
Joe,
I enjoyed reading the events you describe below. In my opinion:
(1) IF the company's quality system requires that dye sprays be handled, stored and used in accordance with the manufacturer's instructions, then it would be a noncompliance and a corrective action would be required to bring the actual practices into compliance with the formal documented quality system.
(2) However, if the company's quality system does NOT require dye sprays to be handled, stored and used in accordance with the manufacturer's instructions (which I assume was the actual case since most company's would not document a requirement to follow such instructions), then the steps taken would be a preventive action.
(3) Whether the dye spray actually came into contact with the finished product or not is irrelevant The question is whether the quality system requires the handling of the dye sprays according to the manufacturer instructions.
According to the definitions given in ISO 8402, there must be an actual noncompliance before corrective action is taken -- otherwise, by definition, the action taken is preventive.
I enjoyed reading something a little different from the normal type of questions / issues raised in this discussion group -- so I would say yes. I think that this type of topic / question certainly belongs in this discussion group.
Richard C. Randall
Date: Wed, 4 Oct 2000 16:20:02 -0500
Subject: Re: Q: Corrective or Preventive? /Green/Paten
Joe,
An interesting story. I'm not sure it matters whether you call this corrective or preventive - but, to me, it is clearly a preventive action - because by definition no failure occured - although the process controls in place where "barely good" enough to "detect" the condition before failure could occur!
Actually a lot of preventive actions are initiated by people who "know" that a condition exists that IS going to cause failure - sooner or later.
Mike Paten
Date: Wed, 4 Oct 2000 16:29:49 -0500
Subject: Re: Q: Corrective or Preventive? /Green/Kozenko
Joe:
I selected only "No. 7" although my opinion runs consistently throughout your post.
It was a corrective action, especially when one quick thinking operator grabbed a self-discharging aerosol can and pointed the discharge where it would do no environmental harm. Big plus.
It was a preventive action when other potential self-discharging cans were collected and placed in a temperature zone less conducive to their independent self-discharge. This was also an OHSA-flavoured safety action which I will rub under the nose of white collared engineer types who tell me ISO and OSHA don't ever mix. Balderdash.
Granted, a further preventive action would have been to air condition the entire plant. No doubt, lots of people thought of this. Perhaps one day, someone will implement it. It is a tribute to your management people that at least something was done with the remaining cans. A less satisfactory, and less safe, approach, would have been to tell everyone what to do in the event "their" can started to self-discharge. One slip-up amongst all those cans, and someone could have gotten a lung full of nasty stuff, or worse, one or both eyes...
Does it belong on this list? I'd surely say yes. It's a fine example of the theory of the standard and how it actuates into floor- and executive-behavior.
David M. Kozenko
Date: Mon, 9 Oct 2000 12:49:58 -0500
Subject: Re: Q: Corrective or Preventive? /Green/Andrews/Green
> From: [email protected]
Ethan responded:
> Joe,
> My 2 cents.
My reply to Ethan
Good catch. I hadn't thought about that one. Especially with regard to 9K2K. It leans toward "work environment" or "infrastructure". It makes me wish the "Human" and "Physical" factors had not been removed from the FDIS.
Value added comes from the improved awareness of events. (such as a spray can uncontrolled discharge) ..The point I press over and over is that no matter how immature or incompetent the organization, the more they focus energy on reality, appropriate reaction to reality, and pat themselves on the back for doing what they should have done all along, the entire world "International" gets a little better. (Hard to measure, but I still believe in ISO and it's inherent GOOD.
Old Joe
S Design and Development - Defect Prevention Plan Design and Development of Products and Processes 10
S Definition Organizational Defect Prevention Plan? Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
I Old Time Scatter diagrams for defect type and location- software Quality Tools, Improvement and Analysis 7
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
J Definition Defect Mapping - Here is my definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
L How to write a proper defect description in a NCR Nonconformance and Corrective Action 4
Q Calculating Defect Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R Software change control process and defect tracking ISO 13485:2016 - Medical Device Quality Management Systems 1
G Defect codes and process codes need to be controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Fender1 Customer specified Item Defect Corrective Action Responsibility Customer Complaints 18
R Defect Display Area for Employee Shift Change Information Misc. Quality Assurance and Business Systems Related Topics 1
L PPM Defect Rate as a Performance Metric - Are there Flaws? Quality Manager and Management Related Issues 9
P Evolving Quality Levels - Expectations for Lowered Defect Levels AQL - Acceptable Quality Level 21
A Defect Rate for asking for an RMA - Company wants an RMA for every defect found Supplier Quality Assurance and other Supplier Issues 10
T Customer Requirement for Sorting - Visual Defect on Plastic Part IATF 16949 - Automotive Quality Systems Standard 9
P Visual Defect during Validation Process Design and Development of Products and Processes 6
J Classifying Defect Reports from Business Partners US Food and Drug Administration (FDA) 4
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A How Defect Rate Changes After Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N New to ISO 9001 - NCR for every defect? Nonconformance and Corrective Action 5
optomist1 Converting Defect Rate To Capability index Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Renault Painting Defect Acceptance Criteria Manufacturing and Related Processes 4
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
T Probablity of correctly detecting a defect size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Metal Stamping Defect--Need Help with Corrective Action Manufacturing and Related Processes 5
A Shall we raise SCAR/CAR for every defect as per our current procedure? Nonconformance and Corrective Action 4
M AQL (Acceptable Quality Level) for Mixed Part Defect IATF 16949 - Automotive Quality Systems Standard 1
S Are P-charts for a Particular Defect or can Different Defects be counted in one? Statistical Analysis Tools, Techniques and SPC 2
K Defect Reporting and Tracking Software for a Small Machine Shop Quality Assurance and Compliance Software Tools and Solutions 1
S Standard Machining Defect Codes Nonconformance and Corrective Action 2
K Defect Detection for Fresh Injection Molding Solid Parts Manufacturing and Related Processes 5
R LTPD (Lot Tolerance Percent Defective) Sampling Plan with %Defect Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
1 Defect Tracking Excel Spreadsheet Template Excel .xls Spreadsheet Templates and Tools 2
S Measurement Error When Measuring a Defect - Scratches Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
S What if I find a defect after AQL (Inspection)? Pharmaceuticals AQL - Acceptable Quality Level 1
S Six sigma and defect rate (6 sigma = 3.4 PPM) Six Sigma 6
B Can Minitab 15 Chart Geometric Distributions with Very Low Defect Rates? Using Minitab Software 2
J Calculating Defect Rate or Percent of Rejection Manufacturing and Related Processes 4
D Herringbone Defect Condition in Rolled Steel Misc. Quality Assurance and Business Systems Related Topics 3
B Minitab Gage R&R using Defect Count per Unit Area Using Minitab Software 1
L Zoned Defect Chart - 9 zones with 12 possible defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J How to understand NOTE 2 in the ISO 9000 definition of defect? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Customer asks me about AQL for defect types AQL - Acceptable Quality Level 2
L Typical defect ppm level for barrel surface coating process? Supplier Quality Assurance and other Supplier Issues 1
A Lamination Defect in Structural Steel Plate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Ring Joint Gasket Defect Types and their Consequences Various Other Specifications, Standards, and related Requirements 13
T Implementing Defect Logs into my existing Non-conformance procedure Nonconformance and Corrective Action 4
