Define timeline for Major and Miner Audit finding
Hi So currently we received finding on our internal audit process.. One of the audit finding (AF) was open over a year for miner corrective action.
So our new AF which is : Against FDA 21 CFR Part 820.22 Quality audit, and ISO 13485:2016 §8.2.4; regarding “undue delay of corrective actions” SOP**** did not describe the time limits nor the extension process of the identified corrective actions/audit findings from quality audits.
So our corrective action for this is: SOP shall update to - Duration of time as to when the audit findings should be closed.
I am not able to update that in procedure. What should be content. What will be the redline for this
How to define Major AF closure time
How to define Minor AF closure time
Tagin
If I understand it correctly, the issue is not about predefining fixed closure times; instead, it is about the "undue delay".
There should be:
  • a plan for the corrective action completion, which includes projected target dates for completion of containment, correction, preventative action, effectiveness, etc.
  • those target dates should be realistic, and based on urgency of issue, resources available, etc.
  • if those target dates are being missed, and there is no justifiable reason for missing the target dates, then that is "undue delay".
So, if you had a minor corrective action open for over a year, and you had no justifiable reasons why it was still open, then that is 'undue delay'.
So, your SOP should probably include:
  • the planning of completion of corrective action steps with target dates
  • monitoring of target dates
  • escalation path if target dates are missed, so that management can take action
  • also, setting of target dates may be driven by external sources, such as the customer or auditing company, etc. So, your process should allow these externally-driven target dates to override (or at least, be considered) in place of internally-created target dates.
There should be:
Thank you for following up.
So how could you define the date in procedure. So request came from management that Minor AF corrective action should close in 90 days and Major should go to CAPA. But i am not sure how to add that verbiage in SOP.
Tagin
It depends alot on the structure and style of your SOP. But in general, maybe something like this:
Audit Findings
Audit findings shall be handled according to their severity:
  • Minor - corrective actions for minor audit findings shall be completed within 90 days of the final audit report. If the activities required to complete the corrective action are expected to exceed the 90 days, then <person-in-charge> should escalate the corrective action to management for how to proceed.
  • Major - corrective actions for major audit findings shall go into the CAPA system within 10 days of the final audit report.
Sidney Vianna
Post Responsibly
The issue has been discussed numerous times at the Cove and how unwise is to have pre-determined, fixed, cast-in-stone timeframes for "corrective actions". The treatment of the negative occurrence has to take into account the risks associated with the situation. Containment, correction and corrective actions must be commensurate (including timeframes) with the criticality and risks that are specific to the situation. Line stoppage and product recalls, for example, are extremely difficult to "proceduralize" but they should be available if and when necessary to mitigate nonconforming products multiplying and reaching end consumers.
T How do you define your Hazards? <a Risk Management discussion> ISO 14971 - Medical Device Risk Management 16
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
V Who should define and own the Design and Development Plan and how to maintain the updates and revisions. ISO 13485:2016 - Medical Device Quality Management Systems 2
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
M How To Define ISMS (information Security Management System) Scope IEC 27001 - Information Security Management Systems (ISMS) 18
K How to define Expected life service life of medical device Other Medical Device Related Standards 4
S How to Define Importers under EU MDR / Brexit EU Medical Device Regulations 3
M Should Potential Customer Complaint Outcome Define Registrar NC Rating? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
Q QI Macro Histogram - Can someone define *sorted data*? Capability, Accuracy and Stability - Processes, Machines, etc. 7
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
I How do you define Risk (Medical Device)? ISO 14971 - Medical Device Risk Management 30
M SOP or template for a study to Define Storage Conditions of Orthopaedic Implants EU Medical Device Regulations 3
D Definition Client - How does the government define their clients? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
alonFAI How to define a Risk Based Approach for Supplier Management per ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
G How to define the scope of QMS as per ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
R How to define QMS certification scope statement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Review of "Key Data" for contract labs, but SOP doesn't define "key data". Problem? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
G Procedure to define Signing Authority for Procurement Limits ISO 13485:2016 - Medical Device Quality Management Systems 2
P Can a company define new quality standards for special industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Are there any requirements to define barcode requirements ? Misc. Quality Assurance and Business Systems Related Topics 2
X How to define Calibration Acceptance Criteria General Measurement Device and Calibration Topics 3
H ISO 17025 - How to define a "Test Equipment" ? ISO 17025 related Discussions 2
J Where do you define Internal Auditor qualifications? Internal Auditing 9
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
T Internal Audit - How to define the Importance of Departments and Processes Internal Auditing 8
T Help me understand how to define Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
L How to define R & D Receiving (Incoming) Inspection Plan Design and Development of Products and Processes 18
B How to define and implement Configuration Management Document Control Systems, Procedures, Forms and Templates 5
C How to Define and Document Controls of Outsourced Processes Food Safety - ISO 22000, HACCP (21 CFR 120) 5
S Please help me define training requirements for a Career in Regulatory Affairs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K How to define the Acceptances Criteria for all equipment? Manufacturing and Related Processes 7
L Definition Program - How do you define Program with regard to ISO 9001? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
A Supplier Evaluation SOP - How do I Define Major and Minor Suppliers? Supplier Quality Assurance and other Supplier Issues 14
Q Where to define Authorities and Responsibilities in Documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Define Energy Used/Delivered - Applicable to Electrical or Mechanical Power or both? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R 820.50 (A) (2)Define the Type and Extent of Control to be exercised over Vendor Misc. Quality Assurance and Business Systems Related Topics 5
A Where to define Process Tailoring Form used in CMMI in the ISO 9001 Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Criteria to define QMS processes in ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 23
S How to define New Equipment? Device is Returned, Refurbished or Repaired Misc. Quality Assurance and Business Systems Related Topics 3
C Controlling Documents: Beyond the standard, how do we truly define what to control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C How to define Process Special Characteristics (SC) FMEA and Control Plans 4
kedarg6500 What is the meaning of "define/defined" in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Crusader Local Control Document procedure....define it or not? Document Control Systems, Procedures, Forms and Templates 24
M Excel Templates for Plan & Define Phase in NPI Process for Tire Manufacturer Excel .xls Spreadsheet Templates and Tools 1
R Define Data from Taguchi to Response Surface Methodology in Minitab Using Minitab Software 2
K How to define PVC Pellet Quality Manufacturing and Related Processes 8
J How to define a Product's Realization Process and Scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S How to define Permissible Error for Measurement and Test Equipment? Measurement Uncertainty (MU) 3
