Defined retention time of quality records - ISO 9001:2000 Paragraph 4.2.4
mjflkitty
5.7.1 The department/individual concerned must identify the retention for each record used. Once defined, the records must be retained only on the duration identified.---> meaning they should define it? should this definition be written in a document or not necessarily?
Marc
Fully vaccinated are you?
There is a forum here dedicated to records requirements. I moved this thread to that forum.
I did a quick search using 'record retention' and limited the search to thread titles. I came up with several which discuss this, including:
http://Elsmar.com/Forums/showthread.php?t=3128 and
http://Elsmar.com/Forums/showthread.php?t=6939
It really doesn't matter where you define retention time as long as you do define a minimum retention period. Some put it right on each record such as in the footer. Others have a 'Master' records listing where they define it.
You have to, as a minimum, keep the record for the defined period. You can keep records longer than stated. But - In TS 16949 it is a bit different in that they are more strict about citing a disposal/destruction method and the expectation is that when the record reaches its 'end of life' that it is disposed of appropriately.
5.7.1???
Hullo Kitty,
Um... 5.7.1? Are we reading the same std? I'll assume we're talking about 4.2.4 and carry on from there, ok?
Anyway, the retention period for each document should be what you need (Of course, legislation will sometimes have to be considered too..) We have been turning this subject inside out on several occasions. The following threads may be of use to you:
Identification of Quality Records (9K:2K - 4.2.4) - How?
Forms have no linkage to procedures or instructions - How to address?
Trigger Point - Determining When We Can Dispose of Quality Records
Control of Records Definition - Controls needed and the 'disposition' of records
Defining Record Retention Times - Is 5 years long enough?
Quality Records - How long do you keep inspection records and why?
Disposition of Records
Added later: Aha... Hello Marc. :bigwave: You beat me to it by a mere minute...
/Claes
mjflkitty
Thank you
Thank you Marc for answering all my questions, and for bearing with me. I'm still 23 and I do have hard time about all this. Thank you for helping
kitty :thanx:
Don't worry, you'll get the hang of it. Besides, being young is something most of us have been plagued by at some period of our lives. It will go away eventually... :lol:
/Claes
mjflkitty
Claes Gefvenberg said:
Hullo Kitty,
Hi!
"5.7.1" is the number from our procedure, not from the standard..... :D :magic:
P Defined Records Retention Time Of Customer/Regulatory Requirements Records and Data - Quality, Legal and Other Evidence 4
E Record Retention - NC for keeping records longer than our defined minimum Records and Data - Quality, Legal and Other Evidence 9
Y EU MDR Technical Documentation - Defined Review EU Medical Device Regulations 1
G Remote support - IATF allowed words defined? IATF 16949 - Automotive Quality Systems Standard 15
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 1
Cats Clause Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
T No Defined Shelf Life/Expiration Date - Disposable single-use, non-invasive, non-sterile Other Medical Device Regulations World-Wide 2
S How are Medical Device Components and Subassemblies defined? ISO 13485:2016 - Medical Device Quality Management Systems 1
Mikishots Definition Defined - Definition and meaning of "defined" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
E Defined Roles in Small Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P Validation of Processes - What is meant by 7.5.6 (a) - Defined Criteria for Review ISO 13485:2016 - Medical Device Quality Management Systems 7
J Measuring Leakage Currents with IEC 60601 defined Measurement Device (MD) IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
R Technical Files Sampling Rule defined in NBOG 2009-4 EU Medical Device Regulations 2
J What results need to be defined in IATF 16949 Clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 3
J Deformation specification not defined in print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S How others have defined "reaudits"? 21 CFR Part 820.22 Internal Auditing 1
R Property - What is defined as Property in ISO 14971 ISO 14971 - Medical Device Risk Management 4
C AS9100 Requirement Definition - Defined vs. Documented AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
X Are defined roles and responsibilities mandatory for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Root Cause of 'Supplier Evaluation Not defined' Nonconformance and Corrective Action 15
J Is painting considered a Special Process as defined by ISO 9001 7.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
A How is Segregation of Duties defined in the IT World? IEC 27001 - Information Security Management Systems (ISMS) 4
Q Must Support Processes have defined KPI's (Key Performance Indicators)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K What constitutes (is defined as) as a Medical Device? Other Medical Device and Orthopedic Related Topics 3
Chennaiite External Audit re-defined Imported Legacy Blogs 4
B Definition Diagnostic - Is "diagnostic" defined in the EU Medical Device Standards? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
H Document Control Defined? Determining what documents must be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V QbD Approach - What are the "New Processes" to be "Defined / Introduced" US Food and Drug Administration (FDA) 6
kedarg6500 What is the meaning of "define/defined" in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S No Process Defined to Capture the Special Requirements of Customers Problem Solving, Root Cause Fault and Failure Analysis 10
G How is a Medical Device defined in the EU? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Suspect Product: How can Suspect Product be defined? TS 16949 IATF 16949 - Automotive Quality Systems Standard 15
G SEI CMMI Dev v1.3 - Defined (ML2) and Managed (ML3) Process Areas Software Quality Assurance 1
T TS 16949 Internal Audit Effectiveness Defined Internal Auditing 5
V Definition Documented versus Defined Procedures Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
J Control of Outsourced Processes defined within the Quality Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I Does a QMS defined by the element-by-element approach meet the intent of 4.1a? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
T A confusing Non-conformity - No defined QMS processes intended for 'Management' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Defined intervals for review of quality system documents? Document Control Systems, Procedures, Forms and Templates 13
S Non-conformance regarding Lean Process - Lean Process is not defined ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
P Specified stages of design and development shall be defined - TS 16949 clause 7.3.4.1 IATF 16949 - Automotive Quality Systems Standard 4
M Common tools defined Funny Stuff - Jokes and Humour 3
C Measurement of Uncertainty ?as defined by the US Pharmacopeia? Measurement Uncertainty (MU) 9
A Accepted / litigated AQLs in the Automotive Industry? Where is this defined? AQL - Acceptable Quality Level 7
C Definition Internal Laboratory as defined in TS16949 - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 14
