Defining (Identifiying) Key Processes in a Company - "Key Process Master List"
Helmut Jilling
Auditor / Consultant
#11
Re: Defining Key Processes in a Company - "Key Process Master List"
It sounds like you are on the right track. Those could be some of your key processes. There may be other processes as well, and certainly would be other supporting or administrative ISO processes.
John Broomfield
#12
Hello all,
I am trying to identify all of our key processes for our company so that I can put them into a "key Process Master List" and I am not sure where to begin end. I guess what I am asking is can... anyone give me some advice on how to identify "key" processes for a company?
TDSims67,
ISO 9001 requires you to determine the processes that are essential to the effectiveness of your management system.
It does not require you to define them so you can put them in a list.
Determine the processes that are key to your organizational management system's success by working with top management to understand how the organization works as a system for converting the needs of your customers into cash in the bank.
Start with the processes that get the work, do the work and receive payment. This is known as your organization's core process and it may comprise 5 to 15 key processes.
Your organization sustains and directs its core process with its other key processes. Most of these already exist and a few may come from the standard itself. Examples include recruiting and training, controlling documented information, auditing and problem solving.
Do this analysis on your organization as a system aided by the standard. Using someone else's list of processes will not work but could act as a bit of a checklist so you can seek exactly what your organization does to get work, do work and get paid.
Remember, your management system's processes are almost always cross-functional (in that more than on department or function is involved).
Your core process flowchart will run from customers having a need to your organization receiving payment for satisfying that need. It will show the sequence and interaction of the key processes in the core process.
Our clients have developed their process-based management systems this way since 1986. And top management love a management system that is worthy of their commitment.
John
John Broomfield
#13
thira7,
Do you also design training to fulfill Partner learning objectives? What about recruiting and verifying the competence of instructors? How does your NGO receive payment so you have the money to invest in maintaining and improving the system?
Keep up the good work,
John
CATERAF
#14
It can be quite tricky to identify processes initially! It sounds like you're on the right track. Without knowing your company it's hard to say what the processes are. However, a few key things that I have found helped me to identify processes. I hope something in here helps!
1. Think of what happens from the time a customer contacts the company (or from when you start searching for customers) and then trace that through to the time that you have satisfied the customer's needs (i.e., the project/job you're working on is finished). Don't go very deep as you jot it down.. go very broad to start with. e.g., for our company we do marketing functions to identify customer (process: marketing), they then contact us and we do some quoting and work out a contract (process: sales). If the project is big we pass it through to project management and they delegate and control who is doing what and when (process: project management). The engineers then use the information from project management to design their product and test it (process: engineering). When the design is tested and correct it then gets produced in mass through a particular set of procedures (process: production) etc.. all the way through to installation and commissioning.
2. A process can generally be broken down into lots of steps and may produce multiple 'things' (called 'outputs').
3. Generally, what comes out of (aka 'is produced by') one process may then be used to do the next sequential process. So it's an output of one process but it's an input of another. e.g., Sales produce a contract (output) which project management need to write up a project plan (a project management output). So, the contract is an output for sales and an input for the next process, project management.
4. Each step of a process can (but doesn't have to) have a procedure.
5. A process can have sub-processes. E.g., Production can be broken into Planning --> Producing the Product --> Validating the Product.
6. There are processes that support the main-line work that you do. For example, in order to do your work you need to purchase resources (process: 'purchasing'), you would also need staff to do the work (process: 'staff hiring') etc.
7. To help identify the main processes it can be good to draw very basic flowcharts going vertically down and then line them up next to each other in the order that they happen. If you find processes that can occur at any stage (E.g., you may need to purchase resources at many points), these may be additional processes or support processes.
Hope something there helps.. generally a combination of them helps to identify. It does take a while to get your head around.. just keep looking at the flows through your organisation and you'll start to notice patterns :) The key is to not give up.. ! :)
thira7
#15
Thank you. Your answer was very helpfull. Last week i was in a dead end and i really was desperate, however i start doing flowcharts and helped me a lot. Thank you for your help.
thira7
#16
About the money, we receive money from funders but this is mostly about negotiation skills and not a process (this is my view)
John Broomfield
#17
thira7,
All work is process.
"Negotiating donations" sounds like a key process to me. If not for the survival of the NGO then for maintaining and improving the NGO's management system (also see clause 6.1).
If you analyze the system rather more deeply you may find this process is owned by a senior manager whose competence includes negotiating:
"Promoting our work and securing donations to fulfill our mission".
It will likely include the maintenance of the information on your website.
John
thira7
#18
Yes this is true funding is very important. I will try to go deeper in this. I have one more question how can i put these processes in my Quality Manual, for example if i have a meeting process how can i relate it to the quality manual.
I hope this is clear enough.
John Broomfield
#19
thira7,
Meetings are activities within some key processes. An organization that manages conferences will call the conference (meeting) itself a key process but I'm not sure this is what your NGO does.
So, when including a meeting in your deployment flowchart of a key process show who chairs and who attends the meeting, the info sent to attendees so the can prepare for the meeting and describe the outputs of the meeting then go on to describe what the process does with these outputs.
Your quality manual could become very cluttered and confusing to users if it included all the documented procedures and work instructions that specify the way the key processes are carried out. This is why most organizations, these days, control and distribute the procedures, instructions (if needed) and forms separately to whomever needs them.
Your document coding scheme and computer network will enable this.
Then confine your manual to describe how the NGO Management System works to achieve its objectives. Keep it brief so it is a very useful document for any stakeholder to understand how the NGO works.
John
thira7
#20
The processes of Control of Documents and Control of Records are giving me some hard time. This two processes are used to define how,where and how we can retrieve our forms and reports?
J Defining staff competence - Small mechanical workshop Occupational Health & Safety Management Standards 20
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
M Defining frequency of measurement tools callibration Calibration and Metrology Software and Hardware 3
M Defining and Documenting Record Retention CE Marking (Conformité Européene) / CB Scheme 5
G Defining performance metrics for DFMA implementation Design and Development of Products and Processes 2
S Defining a Quality System from scratch - Preferred system and documentation names Document Control Systems, Procedures, Forms and Templates 4
A Defining Expected Service Life in Risk Management File Reliability Analysis - Predictions, Testing and Standards 5
C Defining Approvals Required for Design Control Documents ISO 13485:2016 - Medical Device Quality Management Systems 6
K Defining Acceptance Quality Level, I need clarity on AQL 1.5, 2.5, 4.0 AQL - Acceptable Quality Level 5
M Defining the lifetime of orthopedic implants joints Other Medical Device and Orthopedic Related Topics 2
C AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
V Defining Safety Precautions for Category 4,5 Molecules Occupational Health & Safety Management Standards 2
E European Regulations defining the terms Repair and Refurbish EU Medical Device Regulations 5
T Defining Major vs. Minor Changes to Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
GStough Adequately Defining Which Suppliers to Audit and Frequency Supplier Quality Assurance and other Supplier Issues 8
E Quality Techucuan (Technician) in Electronics - Defining Postion Requirements Career and Occupation Discussions 4
moritz Defining a good Scope for Critical SOPs ISO 13485:2016 - Medical Device Quality Management Systems 7
T Standards for defining audible alarms/warnings for OR instruments IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Defining Critical Vs. Non-Critical Suppliers/Service Providers (API Q1, 9th. Ed.) Oil and Gas Industry Standards and Regulations 2
B IEC 60601-2-24 - Defining Storage Volume IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Defining Sub-Disciplines for Chemical Testing Laboratory Employee Proficiency Testing General Measurement Device and Calibration Topics 1
T Defining Nonconformances in a Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Defining Reliability and Confidence Levels Reliability Analysis - Predictions, Testing and Standards 3
J Defining Martial Arts and Gymnastics Statistical Techniques Statistical Analysis Tools, Techniques and SPC 4
V Defining the criteria for equipment to be qualified or requalified Qualification and Validation (including 21 CFR Part 11) 2
R Need help on defining scope for Design Verification File for Class III IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Defining CCP (Critical Control Points) in a Rice Mill Plant Food Safety - ISO 22000, HACCP (21 CFR 120) 9
S Process Map and defining KPIs Misc. Quality Assurance and Business Systems Related Topics 5
5 Major Nonconformance for not "clearly" defining the "device lifetime" ISO 13485:2016 - Medical Device Quality Management Systems 2
E Defining the lifetime of an Implantable Medical Device Other Medical Device and Orthopedic Related Topics 5
B Defining Expected Oxygen Leakage for Safety Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Defining Post Mold Cure Ramp-Down Temperature Manufacturing and Related Processes 2
K Audit Nonconformity on Defining 'Outsourced' Infrastructure Maintenance Quality Manager and Management Related Issues 21
G Points to consider while defining the Quality Policy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Defining Quality Objectives for Product Realization and Design and Development AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Developing Documentation and Defining Processes as Subcontractor IATF 16949 - Automotive Quality Systems Standard 6
C Defining ISO 9001:2008 Scope for a Sterilization Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Defining Skilled vs. Semi-Skilled vs. Unskilled Labor Manufacturing and Related Processes 1
I Defining the scope for ISO 9001 Registration - Software, Hardware and Customer Care ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Product Specification vs. Information Defining Product - The differences? 7.3.3.1 IATF 16949 - Automotive Quality Systems Standard 6
R Defining Interaction of Processes in a Software Company Software Quality Assurance 3
N Where to begin defining and monitoring Quality Metrics in a Machine Shop Manufacturing and Related Processes 9
A Testing Process Audit - Defining a Process Compliance Mechanism Software Quality Assurance 2
R Defining the type of Applied Part - Metal Probe (Applied Part) employs Water Cooling IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Defining Security Interfaces for Scope for ISMS - Need help IEC 27001 - Information Security Management Systems (ISMS) 10
A Defining the differences between Prototype vs. Production Guidelines? Contract Review Process 5
R Help defining Eyewear Customer Complaint Categories Customer Complaints 5
G Quality Objectives - Where to start defining Quality Objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
