Defining Post Mold Cure Ramp-Down Temperature
G
gynco
Hi there, is there any standard to follow in defining a Post Mold Cure (PMC) ramp-down temperature for I.C?
1.What are the possible effect on the I.C, if the oven door is immediately open after the curing considering the conditions : RT: 22 to 30 Deg C, RH: 40% to 60%?
Our PMC temperature Oven is set at 170 to 180 degree C.
2. What is the acceptable temperature difference if the parts were subjected to a
oven temp of 170 to 180 deg C. while the RT:: 22 to 30 Deg C, RH: 40% to 60%?
Thank you very much for your kind attention on my inquiry.
Murphys Law
I don't recall if there is a standard on this but the risk you want to consider the thermal shock of ramping down from 170C range to room temp.
The concern is one of warpage which could cause package cracking or internal delamination especially as the packages will still be in strip format and want to flex.
One thing to be aware of is the Tg of your mold compound. Above this temperature and is soft malleable. Below it, then it is solid. That is ~125C range depending on the mold compound itself and how Tg measurement technique is defined.
The humidity is not a concern due to the Packages being hotter than ambient and moisture will not ingress.
Ask your mold compound manufacture if they have any recommendations about ramp down times. I know they have one on Post mold cure time. I don't know if your plan is to slightly open the door, fully open the door but you should study it if you want to make this change. Also evaluate difference between fully loaded oven and partially loaded as they will have different thermal loads. You may end up with two temps: One down from 170C to say 150C and after that they can even be removed.
Ronen E
Problem Solver
Moderator
Not 100% sure what materials we are talking about, but post-curing usually applies to thermoset, or at least to gelling, ones; while Tg (sounds like you are referring to the glass transition temperature) applies to amorphous thermoplastic resins.
I agree that it's best to consult with the raw material's manufacturer.
K Defining risk control measures IEC 62304 - Medical Device Software Life Cycle Processes 14
J Defining staff competence - Small mechanical workshop Occupational Health & Safety Management Standards 20
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
M Defining frequency of measurement tools callibration Calibration and Metrology Software and Hardware 3
M Defining and Documenting Record Retention CE Marking (Conformité Européene) / CB Scheme 5
G Defining performance metrics for DFMA implementation Design and Development of Products and Processes 2
S Defining a Quality System from scratch - Preferred system and documentation names Document Control Systems, Procedures, Forms and Templates 4
A Defining Expected Service Life in Risk Management File Reliability Analysis - Predictions, Testing and Standards 5
C Defining Approvals Required for Design Control Documents ISO 13485:2016 - Medical Device Quality Management Systems 6
K Defining Acceptance Quality Level, I need clarity on AQL 1.5, 2.5, 4.0 AQL - Acceptable Quality Level 5
M Defining the lifetime of orthopedic implants joints Other Medical Device and Orthopedic Related Topics 2
C AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
V Defining Safety Precautions for Category 4,5 Molecules Occupational Health & Safety Management Standards 2
E European Regulations defining the terms Repair and Refurbish EU Medical Device Regulations 5
T Defining Major vs. Minor Changes to Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
GStough Adequately Defining Which Suppliers to Audit and Frequency Supplier Quality Assurance and other Supplier Issues 8
E Quality Techucuan (Technician) in Electronics - Defining Postion Requirements Career and Occupation Discussions 4
moritz Defining a good Scope for Critical SOPs ISO 13485:2016 - Medical Device Quality Management Systems 7
T Standards for defining audible alarms/warnings for OR instruments IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Defining Critical Vs. Non-Critical Suppliers/Service Providers (API Q1, 9th. Ed.) Oil and Gas Industry Standards and Regulations 2
B IEC 60601-2-24 - Defining Storage Volume IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Defining Sub-Disciplines for Chemical Testing Laboratory Employee Proficiency Testing General Measurement Device and Calibration Topics 1
T Defining Nonconformances in a Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Defining Reliability and Confidence Levels Reliability Analysis - Predictions, Testing and Standards 8
J Defining Martial Arts and Gymnastics Statistical Techniques Statistical Analysis Tools, Techniques and SPC 4
V Defining the criteria for equipment to be qualified or requalified Qualification and Validation (including 21 CFR Part 11) 2
R Need help on defining scope for Design Verification File for Class III IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Defining CCP (Critical Control Points) in a Rice Mill Plant Food Safety - ISO 22000, HACCP (21 CFR 120) 9
S Process Map and defining KPIs Misc. Quality Assurance and Business Systems Related Topics 5
5 Major Nonconformance for not "clearly" defining the "device lifetime" ISO 13485:2016 - Medical Device Quality Management Systems 2
E Defining the lifetime of an Implantable Medical Device Other Medical Device and Orthopedic Related Topics 5
B Defining Expected Oxygen Leakage for Safety Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Audit Nonconformity on Defining 'Outsourced' Infrastructure Maintenance Quality Manager and Management Related Issues 21
G Points to consider while defining the Quality Policy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Defining Quality Objectives for Product Realization and Design and Development AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Developing Documentation and Defining Processes as Subcontractor IATF 16949 - Automotive Quality Systems Standard 6
C Defining ISO 9001:2008 Scope for a Sterilization Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Defining Skilled vs. Semi-Skilled vs. Unskilled Labor Manufacturing and Related Processes 1
I Defining the scope for ISO 9001 Registration - Software, Hardware and Customer Care ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Product Specification vs. Information Defining Product - The differences? 7.3.3.1 IATF 16949 - Automotive Quality Systems Standard 6
R Defining Interaction of Processes in a Software Company Software Quality Assurance 3
N Where to begin defining and monitoring Quality Metrics in a Machine Shop Manufacturing and Related Processes 9
A Testing Process Audit - Defining a Process Compliance Mechanism Software Quality Assurance 2
R Defining the type of Applied Part - Metal Probe (Applied Part) employs Water Cooling IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Defining Security Interfaces for Scope for ISMS - Need help IEC 27001 - Information Security Management Systems (ISMS) 10
A Defining the differences between Prototype vs. Production Guidelines? Contract Review Process 5
R Help defining Eyewear Customer Complaint Categories Customer Complaints 5
G Quality Objectives - Where to start defining Quality Objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
