I've always worked at medical device companies where an SOP (Standard Operating Procedure) defines the reliability and confidence levels for me based on a given risk index. For example, based on the output of an FMEA I will have the estimated severity, occurrence, and detection which combine to form some risk index (sometimes an RPN is used). And based on that, I look at a table in the SOP which says I need .9900 reliability at 95% confidence, or perhaps it's a different level.
How are these levels defined? Is there a standard which defines what typical reliability/confidence levels should be used?
Typically, I have used .99 reliability as tightest control, .975 reliability as medium control, and .95 as loosest control (all with 95% confidence).
What do other companies use?
Thanks for the help!
welcone to the cove!
