Definition of a general order?
O
Obstacle3
Hello was hoping to get some advice on general orders.
We are a department of 100 people, in a company of 15,000. Our department is certified and contains 6 sections.
I want to setup an order system, so the entire business has a general order register (on sharepoint) and each section has an order register for section management issued orders ( also on sharepoint, using the name of the section instead of general order eg Production Orders).
I am stuck on the semantics of the naming and definition.
Obviously, orders issued by the Manager of the entire department, will be called "General Orders".
my question is what should I call the orders issued by the section managers (eg Production Manager) for employees of the particular section (in this examples, production floor staff).
Should they be "Special Orders" or "Production General Orders". Right now I am leaning towards "Production Orders".
Any advice would be greatly appreciated, thanks in advance Covers.
:thanx:
O
Obstacle3
The other consideration I am lost with is what defines a general order?
Some people I have spoken to consider work instructions and/or reminders as general orders, but I would argue that they should be things not covered in process/procedure/work instruction documentation.
Any thoughts?
Wes Bucey
:thanx:
For starters, does any other department do anything similar?
What you propose is troubling to many who might see it as a proliferation of the "silo syndrome" where each department creates a silo of its own information, guarded by moats and firewalls to protect against intrusion or incursion by any other department or division in the organization.
Can you provide us with a lucid explanation of why your department seems to be sailing alone into these waters?
O
Obstacle3
Thanks for the response.
This is a huge organisation. General orders that apply across the whole organisation are creatd and trickled down.
Likewise group general orders are issued, so our group for example, contains 6,000 or so. Our sub group contains 3,000 and again there are things that only apply to those 3,000 people.
Then our department contains 100, and again there will be general orders that only apply to those people.
Then there are 6 sections, so each would have instructions that only apply to people a given section.
They will be readily available for all, through sharepoint, but grouped and issued specifically for members of particular sections by managers of those sections.
The broadly applicable orders will be issued by the department manager for members of all sections seperately.
harry
From my experience over here, general orders give an impression of something bureaucratic. It is a term used almost exclusively by the government and a general order is practically a policy - upon which the different government departments will act and come out with details.
In the manufacturing environment, a job order or work order is normally used upon acceptance of order to instruct the production and/or other departments to start working on it. From there, some come out with a traveler to guide, instruct and track the order as it move along the various processes. Depending on set-up and choice, the job order may be combined with the traveler, especially for cases where there are a lot of details. If there are parallel processes, you may have to have extra copies for these.
In the service environment, similar set-ups should work. You may start with a service order and some sort of traveler or combined and this document serves to guide, track, manage and record the order as it moves along the various processes.
Creative use of such documents can cut down mistakes, multiple handling and paperwork drastically. Forget about fanciful names or semantics - try to stick to the practice at your place and use terms people are familiar with.
O
Obstacle3
Thanks for the response Harry.
Unfortunately, we are a government organisation and we are very bureaucratic.
This is an instruction, like "from now, the subject heading for all emails to custoemr XYZ should say be "ABC" ".
harry
................. Unfortunately, we are a government organisation and we are very bureaucratic.
Ahh, I forgot about that. Over here, they follow a method something like: policy -> procedure -> SOP -> Work instructions. For implementation purpose, government servants will wait for 'circular letters' - something like a work instruction before processing the relevant documents. This may take months after the general order was issued.
O
Obstacle3
yep, there is the same level of insanity from some here but generally the email is enough
O
Obstacle3
How about Local Order as they apply to a local area?
Good suggestion, thanks for that I will throw that around and see what the feedback is.
One thing we have to be aware of in my organisation is ambiguity of terminology, we already have Local Appendices which is seperate and a bunch of other things with local in it!
L GDPR scope - "Personal data" definition - General Data Protection Regulation EU Medical Device Regulations 5
M Definition Aviation - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
A DMDIV-Variants : definition and technical documentation CE Marking (Conformité Européene) / CB Scheme 4
O Clarifying FDA definition of "finished device" and “capable of functioning” 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L 'Distributor' definition & MDR/MSR relationship EU Medical Device Regulations 3
D Definition of equipment for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
M ISO 13485:2016 Complaint Definition Clarity Customer Complaints 2
DuncanGibbons Technical Data Package vs Digital Product Definition APQP and PPAP 0
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
S Importer definition EU Medical Device Regulations 0
A Software as Medical Device (SaMD) definition and its applicability Other Medical Device and Orthopedic Related Topics 4
M Definition of Done - New Product Phase to the sustaining phase Manufacturing and Related Processes 3
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
D BS EN 62304 - Medical-Relevant Data C.5 - Definition of IEC 62304 - Medical Device Software Life Cycle Processes 5
P Definition of production tooling in IATF16949 clause 8.5.1.6 IATF 16949 - Automotive Quality Systems Standard 4
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
J Definition Defect Mapping - Here is my definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
D Definition of "Critical Laboratory Equipment"? General Measurement Device and Calibration Topics 1
Z Definitive definition of design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R Definition Key Supplier - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
F MEDDEV 2.7/1 rev 4 and MDR - Definition of Description of Principles of operation EU Medical Device Regulations 4
S Definition of "servicing activities" - Spinal Implants ISO 13485:2016 - Medical Device Quality Management Systems 4
T Custom made medical device MDD vs MDR definition CE Marking (Conformité Européene) / CB Scheme 12
C Function definition for DFMEA FMEA and Control Plans 1
W Key functional characteristic definition - Tolerances and Deviations Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Marc Definition Waiver - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
M Informational MHRA guidance – Assistive technology: definition and safe use Medical Device and FDA Regulations and Standards News 0
R Critical suppliers (Definition of) and MDSAP (Medical Device Single Audit Program) ISO 13485:2016 - Medical Device Quality Management Systems 15
Pancho Definition Quality Assurance Program - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
M Inputs on definition of very similar processes for multi site audit sample - IAF MD1 2018 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
U Hand-Held dosing device has no PATIENT - Interpretation of the PATIENT definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Medical Device Accessory - Health Canada guidance / definition on what an accessory is Canada Medical Device Regulations 3
C MDR Importer/Distributor Definition Questions EU Medical Device Regulations 14
G Medical Device "Immediate Container" Interpretation of Definition US Food and Drug Administration (FDA) 2
S Definition of Convenience Kit for a Combination Product US Food and Drug Administration (FDA) 0
M Are Risks and Opportunities Required as Part of the Process Definition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Definition of "Sensitive Products" Clause 8.5.4 (c) in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Marc Definition Jidoka - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
Marc Definition DFMEA (Design FMEA) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
J Definition of repackager v. manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S MDR Annex II Design & Manufacturing info - 'Adjuvants' definition EU Medical Device Regulations 3
C Informational CFR 21 Definition for Data or Raw Data Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
I Lot or Batch definition for IVDs Imported Legacy Blogs 0
S Mains outlet MSO definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Mikishots Definition Defined - Definition and meaning of "defined" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
D Definition User Needs - Concrete definition for "User Needs" as required by the FDA Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
L Process Definition and Process Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
