Definition of "Sensitive Products" Clause 8.5.4 (c) in AS9100 Rev. D
We were recently given a minor nonconformance from a customer against clause 8.5.4(c). The auditor interprets the "special handling and storage of sensitive products" as chemicals (such as epoxy or adhesive). In my 13 years of AS9100 auditing, it has always been audited as product, such as ESD sensitive parts and components.
I am curious what others think the interpretation of "sensitive product" is from AS9100 D.
Al Rosen
Chemicals and epoxy would be addressed under 8.5.4 e. shelf life control and stock rotation or 8.5.4 f special handling and storage for hazardous materials.
What was the actual non conformance statement?
outdoorsNW
Without more details about your situation, adhesives may fall under special handling and storage.
What do the products' directions say?
Some adhesives need to be stored at cool to cold temps. A few adhesives give temperature vs. storage life data. Where I work, we refrigerate some adhesives (such as some Loctite), and we have some epoxy tubes that must be stored at -40. Others are stored at normal room temperature.
Many adhesives have expiration dates. Common wood glue often only performs at full strength for a year [often you have to look at the mg website to find this out], although for less demanding applications this may not matter, since often the wood will split before the glue fails.
If you do not have one already, you likely need an instruction in a process to check the storage temperature and expiration date (opened and unopened) for each new adhesive type and act accordingly.
Marc
Fully vaccinated are you?
Be happy you didn't have a critical auditor for 13 years. But now that it has come to the surface...
Just to add slightly to what @outdoorsNW and @Sidney Vianna stated:
During the design phase, all parts, supplements and materials need should be defined. Part of the Design Output is Receiving/Receiving Inspection and Storage controls. Products like those Sidney and outdoors cited are great. Sometimes, also, there are products, usually a chemical, can not be frozen so it has to be stored in a heated area.
In many industries, such as aerospace, the design outputs for materials are important with respect to maintenance. O-rings were mentioned here. Depending on the use case, many times various o-rings and seals have to be replaced after a certain number of flight hours. This is very common where the seals come into contact with chemicals such as aviation fuels, various hydraulic fluids, etc.
My intention with this post is just to point out that as Design Outputs, storage requirements should already be well defined.
Thoughts about Shelf Life: Search results for query: shelf life and site:elsmar.com shelf life at DuckDuckGo
C Narrow definition of IMTE or calibration possible? ISO 13485:2016 - Medical Device Quality Management Systems 8
G Medical Device - Borderline/Definition EU Medical Device Regulations 0
S Configuration Item definition question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Definition Outsourced process - Clear definition - 13485 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
M Definition Aviation - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
A DMDIV-Variants : definition and technical documentation CE Marking (Conformité Européene) / CB Scheme 4
O Clarifying FDA definition of "finished device" and “capable of functioning” 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L 'Distributor' definition & MDR/MSR relationship EU Medical Device Regulations 3
D Definition of equipment for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
M ISO 13485:2016 Complaint Definition Clarity Customer Complaints 2
DuncanGibbons Technical Data Package vs Digital Product Definition APQP and PPAP 0
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
S Importer definition EU Medical Device Regulations 0
A Software as Medical Device (SaMD) definition and its applicability Other Medical Device and Orthopedic Related Topics 4
M Definition of Done - New Product Phase to the sustaining phase Manufacturing and Related Processes 3
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
D BS EN 62304 - Medical-Relevant Data C.5 - Definition of IEC 62304 - Medical Device Software Life Cycle Processes 5
P Definition of production tooling in IATF16949 clause 8.5.1.6 IATF 16949 - Automotive Quality Systems Standard 4
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
J Definition Defect Mapping - Here is my definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
D Definition of "Critical Laboratory Equipment"? General Measurement Device and Calibration Topics 1
Z Definitive definition of design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R Definition Key Supplier - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
F MEDDEV 2.7/1 rev 4 and MDR - Definition of Description of Principles of operation EU Medical Device Regulations 4
S Definition of "servicing activities" - Spinal Implants ISO 13485:2016 - Medical Device Quality Management Systems 4
T Custom made medical device MDD vs MDR definition CE Marking (Conformité Européene) / CB Scheme 12
C Function definition for DFMEA FMEA and Control Plans 1
W Key functional characteristic definition - Tolerances and Deviations Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Marc Definition Waiver - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
M Informational MHRA guidance – Assistive technology: definition and safe use Medical Device and FDA Regulations and Standards News 0
R Critical suppliers (Definition of) and MDSAP (Medical Device Single Audit Program) ISO 13485:2016 - Medical Device Quality Management Systems 19
Pancho Definition Quality Assurance Program - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
M Inputs on definition of very similar processes for multi site audit sample - IAF MD1 2018 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
U Hand-Held dosing device has no PATIENT - Interpretation of the PATIENT definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L Medical Device Accessory - Health Canada guidance / definition on what an accessory is Canada Medical Device Regulations 3
C MDR Importer/Distributor Definition Questions EU Medical Device Regulations 29
G Medical Device "Immediate Container" Interpretation of Definition US Food and Drug Administration (FDA) 2
S Definition of Convenience Kit for a Combination Product US Food and Drug Administration (FDA) 0
M Are Risks and Opportunities Required as Part of the Process Definition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Definition Jidoka - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
Marc Definition DFMEA (Design FMEA) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
J Definition of repackager v. manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S MDR Annex II Design & Manufacturing info - 'Adjuvants' definition EU Medical Device Regulations 3
C Informational CFR 21 Definition for Data or Raw Data Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
I Lot or Batch definition for IVDs Imported Legacy Blogs 0
S Mains outlet MSO definition IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Mikishots Definition Defined - Definition and meaning of "defined" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
