Definitive Understanding of 8.2.2.3 Manufacturing Process Audit
P
pinpin - 2009
#11
The standard does not give any guidance. But I will share my preferences, based on many audits of how lots of companies do it. The TS standard defines 3 different levels of auditing. Since they went to the trouble of actually iidentifying them as 3 different sub-clauses, it is safe to assume they were actually looking for 3 different kinds or degrees of audits. Here's how I describe it.
8.2.2.1 The system processes must be audited, in a process approach. This includes core processes, support processes, all of them. If your system identifies 16 processes, I would expect to see internal audits of all 16. Review the metrics, criteria, inputs/outputs...audit the process and all the links to supporting processes.
8.2.2.2 This is a more detailed, ground level audit of each manufacturing process (or sub-process). For example, if you stamp, weld, paint and assemble, that would be 4 mfg. process audits. Most people use this opportunity to walk the control plan in great detail. Check each step, the gages, inspections, control specs, reaction plans, FMEA, process map, etc. This is one of the few times you will actually get to that level of detail. Take advantage of it. Some peole will even do that to each press line or work station. It depends how many you have. There is nothing that says you have to do them all in 1 year.
8.2.2.3 This is frequently addressed by the regular floor inspections, Q-lab verifications, First Article verifications, Annual Layouts, Dock Audits. Some people also tood in the Chrysler Layered Audits, if they do them.
Let me repeat, the standard does not specify exactly how these must be done. What I described is a common approach, but I am sure there are other approaches as well.
Dear Helmut Jilling,
First of all, I would like to thank you for your dedication and detailed explanation...:thanks::thanx::applause:
I have some questions, hope you teach me:
1) Under clause 8.2.2.1, the system is formed by many processes. Some suggest to list them in a matrix with all the applicable TS Clauses identified, then when we do systems audit of each process, we shall make sure all these identified clauses are audited (with evidience indicated in Turtle Diagram or audit check list that normally used in ISO 9001? Turtle Diagram doesn't seem to have enough space for recording information...can we don't use it as long as our checklist showing those items listed in turtle diagram? )? I think we may not have time to check all the clause requirements.....can we only audit some, base on status and importance....is it ok and acceptable by TS auditor?
2) Under clause 8.2.2.2, a manufacturing process may have many subprocesses within it, though some say these subprocesses are "steps" and not required to be audited but only the process, but if not audit these "steps" how can we say we have audited the process that make up by them (these steps)? TS does not specify when to do manufacturing process audit, since a company may not have many manpower to do audit, but as long as they do at least one audit throughout the entire time when the process is running (before it ceased to operate because no more orders require it to be run. Sometime, the order is too little and may just stop within 1-2 days before audit can be done...), is it accceptable to TS auditor? If not, what reason and what criteria in TS standard says it is noncompliant?
Is it all the steps listed in control plan must be audited in order to meet clause 8.2.2.2's "...each manufacturing process..." requirement?
3) Instead of having diffrent timing doing product audit, is it more effective to do product audit at the same time while doing manufacturing process audit? I look at it this way, product is the output of process, if we do not look at the product and the process generating it at the same time doing audit, we may not be able to readily identify weaknesses in the process while we discover defects in the product. Is it correct?
clause 8.2.2.3 says "....at a defined frequency", is it acceptable to do at least one audit (same reason as I said for manufaturing process above)?
Looking forward to hear from your views and teaching..........:thanks::thanx:
Helmut Jilling
Auditor / Consultant
#12
That matrix is in the TS Rules book. It is a tool to keep track of which clauses and links should be reviewed when auditing a process. You should try to check all of them, but the amount of depth you go in each one, would depend on how important it is.
You should audit each subprocess, but, if you walk through all the important items on the control plan, as I previously suggested, then you will cross through each subprocess. As to scheduling, that is up to you to figure out how to do it. I would recommend each manufacturing process should be audited as least once per year. If it is not robust, it should be more frequent. TS standard does not go into any detail, so you have to decide what is appropriate.
Some companies do these two at the same time. More often, the product audit is done by shop floor inspectors, and the timing is based on when the product is run. The mfg. process audit is usually done by trained auditors.
Duke Okes
#13
I would occassionally take a control plan and walk it thru. Then later, do the same thing on another product and/or line. Depending on how many products/lines you have might impact how often you do these audits.
P
pinpin - 2009
#14
Dear Helmut Jilling, is it also to apply "process" auditng method with Turtle Diagram when doing Product Audit?
Duke Oke, your said "I would occassionally take a control plan and walk it thru. Then later, do the same thing on another product and/or line. Depending on how many products/lines you have might impact how often you do these audits.". Do you use Turtle Diagram as a checklist to fill out findings/audit evidence besides the control plan?
Can you show me a sample of each type of these audit (systems, manufacturing process and product)? :thanks::thanx:
Helmut Jilling
#15
Some people use Turtles to record evidence during an audit. That is OK, but I do not recommend it.
I like Turtle Diagrams as a way to describe a process. I think they are useful, if done correctly. But, once you have filled it out, I recommend making it part of the procedure for that process. Why fill it out again and again with the same information. Why not just take the official one, already filled out, and verify that the information on it is still being followed?
Spend your time interviewing and evaluating, and less time writing redundant information.
Jan T
#16
Hi pinpin;
We have basically one manufacturing process, we are contract electroplaters.
What I do is audit each line that is running (as we do different finishes
on different lines) at various times throughout the year. I determine the audit schedule based on the volume that is processed on the line, also taking into consideration if there have been any NCRs generated for parts processed on the line. These I will audit more frequently than others.
Jan
mindy463 - 2008
#17
The way we interpret it in our facility is each (individual)control plan is audited, line by line. Much in the same manner that Ford and GM audit during launch readiness.
P
pinpin - 2009
#18
Hi pinpin;
Jan
Dear Jan, thank you! I agree with your ways.:thanks::thanx:
Helmut Jilling
#20
This "walking the control plan" is the best approach of the various methods I have seen.
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Z Definitive definition of design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Definitive screening design in Minitab 17 Manufacturing and Related Processes 1
M CQIA (Certified Quality Improvement Associate) Exam: The Top 3 Definitive Books? Book, Video, Blog and Web Site Reviews and Recommendations 4
Wayne Searching for Zero - The Definitive Dimensional Metrology Reference Book, Video, Blog and Web Site Reviews and Recommendations 7
Manix Revision & Versions! Definitive difference between a Version and a Revision? Document Control Systems, Procedures, Forms and Templates 13
J Corrective Action vs. Preventive (Predictive) Action (CAPA) - A Definitive Discussion Preventive Action and Continuous Improvement 177
Q Understanding "free movement" for CE-marked products EU Medical Device Regulations 2
D High level understanding of EUDAMED EU Medical Device Regulations 3
A 60601-1 understanding of stationary device IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Help with basic understanding of Competence requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Qualification and Validation (including 21 CFR Part 11) 5
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Informational Health Canada has launched an e-Learning tool to aid in understanding the premarket regulatory requirements for medical devices in Canada Medical Device and FDA Regulations and Standards News 0
S Understanding UDI requirements - Class 2 medical device (hearing aids) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Informational Understanding Costs And Risks For HFE Usability Studies — Part 1: Testing In-House Medical Device and FDA Regulations and Standards News 0
P Understanding FDA draft "Management of Cybersecurity in Medical Devices" Medical Information Technology, Medical Software and Health Informatics 3
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
R Understanding a few points on ISO 9001's Design and Development Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Understanding Cycle Time - Why the time of the other activities are left out Lean in Manufacturing and Service Industries 11
J Understanding ISO 9001:2015 - 10.3 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Understanding ISO9001:2015 - 8.3: Design and Development of Products and Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
E Understanding of TS 16949 Clause 7.6.2 IATF 16949 - Automotive Quality Systems Standard 5
K Understanding IEC 60601-2-68 requirements ISO 13485:2016 - Medical Device Quality Management Systems 1
A Training material for interpretation & understanding Part 11 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
N Understanding, Challenging & Approving Supplier Control Plans FMEA and Control Plans 7
M Definition Recommendations - Understanding "recommendations" and "recommended corrective action" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
S Understanding UDI (Unique Device Identification) Other US Medical Device Regulations 10
T Understanding USP <1112> Water Activity as applicable to Medical Devices Other Medical Device and Orthopedic Related Topics 4
K Understanding Risk Management Requirements according to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S MIL-HDBK-217 - Understanding the various Environmental Conditions Reliability Analysis - Predictions, Testing and Standards 1
D What is your understanding or interpretation of TS16949 7.4.1.2 IATF 16949 - Automotive Quality Systems Standard 6
C Understanding the relationship between 62304 and the MDD ER IEC 62304 - Medical Device Software Life Cycle Processes 7
S Understanding Subgroup Size - Multi Cavity (Minitab) Statistical Analysis Tools, Techniques and SPC 4
R Understanding clause 15.4.2.1 d) of amendment 1:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M Understanding accreditation, MoUs, certifications Other ISO and International Standards and European Regulations 28
L Mobile Medical App - Understanding 21 CFR Part 820 Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Understanding and implementing ISO 17025 ISO 17025 related Discussions 9
M Understanding Versions of Collateral and Particular Standards IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Understanding, Analysis and Monitoring Quality Defects on Composite Components Statistical Analysis Tools, Techniques and SPC 3
S Understanding PMS (Post Market Surveillance) and PMCF (Vigilance and PMCF) Quality Manager and Management Related Issues 1
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
Q Beginner's Understanding - The Purpose and Applications of QMS/ISO Standards Philosophy, Gurus, Innovation and Evolution 12
