Delay in IATF 16949 Certification from Registrar
  • Thread starter paulaizmyname2017
  • Start date
P
paulaizmyname2017
Has anyone ever had to file a complaint against a Registrar?
P
paulaizmyname2017
Nobody has? I have been audited for over 25 years and this is the first time I have ever wanted to file a complaint. I meaning WE as a company. Do you go to the IOAB? There is really no clear direction of who to contact.
howste
Thaumaturge
ANAB has nothing to do with IATF certification. The starting point is the CB themselves. They are required to "have a process for addressing appeals from the client and complaints from any interested parties." If they don't give you a satisfactory answer then you should escalate to the IAOB (if you are in North America) as they represent the IATF here.
AndyN
Moved On
True in part. The scheme isn't theirs, however, the CB is still under the accreditation of ANAB for ISO 9001 which is the base standard. If ANAB refer it, then I'd go with that. You can bet it's not unique to IATF clients.
Mikey324
I think a lot of people are behind right now. I've heard from some sources to expect your cert at or around the 120 day mark. If it takes longer than that, i would think about other options for the future. Just my guess, so many transitions have the works generally gummed up.
AndyN
Moved On
Gummed up, handling a bunch of complaints no doubt...
