Depth micrometer rod adjustment?
amstel1
Hi guys, I wonder if anyone can share with me how to adjust rods on depth micrometers?
I have Mitutoyo 0-4", 0-6" or 0-12", rods are frequently out of tolerance. I tried loosening two hex screws and then moving nut back or forth as needed...and I get it close, but it is almost impossible to get it on zero in timely manner and avoiding thermal expansion.
If there is a simple and quick way or any proper way(I am not sure if I am doing it right), please let me know
Regards
Ninja
Looking for Reality
Howdy,
Typically, the mic will come with an adjustment wrench (do a search for that term and look at the pics...)
After changing extension rod, close the mic to "zero feel" then use the wrench to adjust the reading to zero.
This does not change the incremental movement...it just rotates the whole screw mechanism so you're starting at the right place...
Decent little step by step on the rezero-ing here .
After you do it...best to then measure a "known"...the rods aren't always perfect length...get to know how long they really are...
Ninja
Looking for Reality
Oh, just an adder...
Thermal expansion, measured by a hand mic...not gonna happen. There's no way a hand mic can measure thermal expansion of anything 12" or less.
TCE is measured in parts per million per deg C.
A 12" part with TCW of 15ppm/degC shifts 0.18 mils (4.6um) per degreeC. a 3degC shift makes it half a mil (5 tenths) or 14um.
No way I'm ever gonna trust a hand mic to measure that reliably...
and a high TCE is 303 stainless...it's only 9.9ppm/degC, not 15.
amstel1
Hi Ninja...
This procedure is to adjust barrel to zero, not the actual rod. That is easy part.
Problems are extension rods, they get out of tolerance and need adjustment. Each one have locking mechanism with two hex screws and a nut. In theory it seems like loosening the two hex screws and then turning the nut left or right, depending where it's needed, then pulling that mechanism with two hex screws close to the nut and tightening two hex screws and also tightening the nut with the small wrench that is provided in the case.
It is easy to get it close to the zero, but almost impossible to get it on the zero. By the time I get there I spend so much time playing with it that it already expanded considerably(rod itself, no the micrometer), even if I get the zero I have to wait several hours do double check if it's really on zero.
This Mitutoyo has 0.001" increments, our in-house tolerance is 0.0005", I usually manage to get it close to that on either side of the scale, but almost impossible to get at least 0.0001" if not 0.0000". There must be easier and quicker way to adjust those.
I spoke to Mitutoyo and they either didn't understand or did not want to share that information with me, they refer me to buy microchecker which I already have. Funny enough, they provide you adjustment wrench for barrel, hex key and wrench for the nut, but no instructions how to zero the rod.
Similar is for the Interchangeable outside micrometer anvils, you have to loosen the nuts and then turn nut up or down as needed and then tighten them both. I found them slightly easier to adjust then these.
Ninja
Looking for Reality
Howdy again...that's why I mentioned:
A set screw and a lock nut...to precisely adjust to a 0.0005" window...don't bother trying to get that right anytime soon.
That's like using a tape measure to measure the thickness of paper.
Lock the rods down, establish (using a known) how long the rod actually is...and use it for that length.
If it were me, I would do it once to the best I could, and have Loctite on the threads and the set screw...If my 4" rod ended up being 3.9985" so be it...label it as such and use it as what it is (as opposed to constantly fighting to get 4.0000")
HTH
Ninja
Looking for Reality
Another adder FWIW... I wouldn't trust a hand mic for 0.001" tolerance anyway.
You ever try to GR&R that?
Best I ever got was a 45% GRR
NickV....
HTH
IMO that seems like a risky scenario for a NC over and over again. The fact that you're relying on the operator to look at the label indicating the "actual" value at zero then your guaranteed to have issues....oops I forgot or I didn't notice the label or the label is missing...etc.. A depth mic is +/-0.001 and to get it within that range is tricky but not impossible with some practice. If you're looking for reliability and something easy to manipulate purchase a dial depth gauge that you can easily zero the dial for each rod being used. They come in 0.0005" graduation as well. But I do like the Loctite idea! I'm doing that next calibration interval.
Ninja
Looking for Reality
Fair enough point.
When faced with relying on an operator who is capable of doing something (math), and relying on a gage that is not capable...I'll take the operator.
That said...getting a gage that doesn't need all the fiddling around sounds even better (though more expensive).
4 Federal Specification GGG-C-105C - Caliper, Micrometer, Gage, Depth Micrometer General Measurement Device and Calibration Topics 7
R MDR & depth of technical files review by NB's EU Medical Device Regulations 18
silentmonkey Rationalising the level of effort and depth of software validation based on risk ISO 13485:2016 - Medical Device Quality Management Systems 10
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
H Depth in the organization for Interested Parties and Risks & Opportunities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B AS9100 Rev D Sequence and Interactions of Processes - How in depth do I need to go? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
F The depth of the required Design Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Depth Gage Spindle moved when changing Contact Point Calibration and Metrology Software and Hardware 6
C Case Hardening and Case Depth Measurement Manufacturing and Related Processes 4
T How to interprete .600/.625 depth in the drawing callout ? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Inspecting Full Thread Depth with a Plug Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Software Design Specification - How in depth should this be? US Food and Drug Administration (FDA) 5
V Depth of Internal Auditing and Training aspects in Research & Development (R & D) Internal Auditing 4
A Measuring Countersink Depth without the use of an expensive gage General Measurement Device and Calibration Topics 3
V ASQ CSSGB - More In Depth Probability and Sampling Methods prep materials Book, Video, Blog and Web Site Reviews and Recommendations 4
P Relationship between Crimping ID & Crimping Depth - Minitab usage Statistical Analysis Tools, Techniques and SPC 3
Q Clarification of Thread Depth for AS5202 and or MS33649 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B Inspection Tools for Flatness and Channel Depth of Bipolar Fuel Cell Plates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Liquid Bath Depth for Calibration of Glass Immersion Type Thermometer General Measurement Device and Calibration Topics 10
R Effective case depth of .508mm MIN. How do I measure this? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Traceability to the Thimble of ID (inside diameter) Micrometers and Depth Micrometers Calibration Frequency (Interval) 2
A Why not a thorough, in depth internal audit? General Auditing Discussions 15
K Quality Objectives - How in depth should we go with our quality objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
M Reading Gauge Output Into Excel .xls - Mitutoyo digital plunger type depth gauges Excel .xls Spreadsheet Templates and Tools 5
Proud Liberal Thread depth - Starting point for measuring FULL THREAD General Measurement Device and Calibration Topics 7
F Auditing Depth - IT, Finance and H&S and Environment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C QMS and ISO 9001 Orientation training - How in depth this needs to be? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
A Outside micrometer anvils parallelism General Measurement Device and Calibration Topics 3
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
A Micrometer anvil chipped General Measurement Device and Calibration Topics 19
C Micrometer and Vernier Caliper simple calibration process General Measurement Device and Calibration Topics 8
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
G Procedure Creation specifically for dimensional (caliper, micrometer, dti) Document Control Systems, Procedures, Forms and Templates 8
W Standard for Micrometer Anvil Flatness Oil and Gas Industry Standards and Regulations 5
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
G Caliper or Micrometer's Dimensional Flatness General Measurement Device and Calibration Topics 5
G Manual Procedure with Uncertainty Budgeting for either a Caliper or Micrometer General Measurement Device and Calibration Topics 6
M Uncertainty Budget for a Micrometer Measurement Uncertainty (MU) 5
M Laser Micrometer Suggestion (if any) for diameters that are +/-.0001 inch General Measurement Device and Calibration Topics 1
T A question on Calibration on In-line Laser Micrometer General Measurement Device and Calibration Topics 1
M Micrometer Anvil Placement to measure the diameter of Steel Wires Measurement Uncertainty (MU) 6
C One Inch Micrometer Calibration Method General Measurement Device and Calibration Topics 2
W Micrometer Storage while not in use General Measurement Device and Calibration Topics 4
D Can anyone share a completed Gage R & R on a Micrometer? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
W Thread Micrometer Standard Tolerances General Measurement Device and Calibration Topics 4
S Micrometer Calibration Using a CMM Calibration and Metrology Software and Hardware 12
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
M Calibration of a Micrometer used as a Standard General Measurement Device and Calibration Topics 5
