Derivative Measurands to CMC
Jerry Eldred
Don't you love the big words.... Okay, Lets say I am accredited to generate and measure (for example) 1000 VDC and to measure current to as low as 1 pA (picoamp). But, for example, I am accredited on my CMC to measure up to 2 Giga Ohms.
Even though I am accredited to 2 Giga Ohms, I can put 1000 ACCREDITED Volts across an unknown resistance, and measure the ACCREDITED current to as low as 1 picoamp. This combination theoretically results in 10E15 Ohms (1 Peta Ohm = 1,000 Tera Ohms = 1 Million Giga Ohms). There are of course all of the contributors of repeatability, drift, resolution, uncertainties of calibrations, etc...
So although the cumulative uncertainty of a given established resistance would have lots of contributions, would it nevertheless be accreditable? This, as a derivative measurement to my CMC? Or even if I am able to make the measurement and subsequent derived (possibly) accredited resistance value, would I be limited to CMC, even though my CMC allows me to directly accredit the input parameters (i.e.: voltage source and current measurement).
I could then (if this is accreditable) accredit these values, and make accredited measurements with them which would not exceed my CMC. Or is this the sort of question I should ask my accrediting body?
dgriffith
I just read this, and perhaps you already have it: https://www.ilac.org/documents/ILAC_G18_04_2010.pdf
What is your measurement method for the 2G accreditation (resistor std?), and why so low if you can derive greater?
Hopefully by now you have done so. Even with the wealth of knowledge others here have, this looks like a stickler.
I might add that according to the document, flexible scopes are not allowed for calibration labs, only testing, if I read that right. Perhaps you cannot derive greater than your scope or use methods other than described in your scope?
