I think this is a good way to go. I have seen a matrix similar to this on another thread and avilable form quality works.. My problem is I cant understand how it works. Seems it merely links the same the same two process from the top and the side accept where each two same processess intercede.
Any ideas??
thanks
I posted the matrix above years ago as an example of how a matrix could be used. It does only what the standard requires: describes the interactions between the various processes of the QMS.
Generally the matrix is not the method I use in quality manuals though. In another thread I posted an example of the type of process map I usually prefer:
Sample process map2.ppt. It describes, at a very high level, what the interactions are between the processes. It also identifies process sequence and where standard requirements are met.
I've read quite a few posts about this topic and I like others find it very difficult to deal with.
From what I have learnt from trawling the net is that for this and any all other requirement to be met and "work" any description of process interactions has:
to be at a high level
must able to be read with ease
is easy to understand and grasp
To this extent I think this graphic from a previous company I worked for is as good as any. I am the first to admit it's not perfect but then I did not draw it either.
All feedback welcome and I hope it helps. (I think the graphic is attached)
Since you asked for feedback, I have two concerns with the graphic you posted. First, it seems to me that it describes documents and activities done
within each process, but doesn't describe the interactions
between the processes as required by 4.2.2c.
Second, the only processes that are listed are product realization processes. Note 1 under 4.1 in ISO 9001 states: "Processes needed for the quality management system referred to above include processes for
management activities,
provision of resources, product realization,
measurement, analysis and improvement." The graphic is missing the management, resource provision, measurement, analysis and improvement processes that are important to an effective QMS.
