Design an experiment to optimize the PCB solder reflow profile
P
peacewong
Hello All,
I have a difficulty about the PCB defect in reflow. Could somebody provide an example of DOE to optimize the reflow profile? Thanks a lot.
D.Scott
Re: Design an experiment to optimize the reflow profile
Hello All,
I'm not sure what you are looking for with this question but I will try to get us on the right track.
I am answering here and closing the duplicate thread so we don't have input scattered all over.
First, a DOE is typically defined based on alternative elements of a process. The experiment would then illustrate the effect each option has on the process and a "best" action can be determined. In order to do that, you must outline all the alternatives and "design" the experiment.
For example, in your reflow profile you are "having trouble with the PCB defects". I assume you are having problems with the temperature gradient across the PCB? Your DOE should include a comparison of convection versus IR ovens; the length of your soak zone and other contributing factors you may identify.
There are some pretty good articles on reflow profiles on the Internet. Check this one before you run an experiment. It may have your answer already.
http://www.tkb-4u.com/articles/soldering/reflprofadjust/reflprofadjust.php
Good luck with the DOE. Please share your results with us.
Dave
P
peacewong
Thanks a lot. In fact, I'm badly in need of a DOE example for reflow profile as a Six Sigma project.
Tim Folkerts
I doubt you will find a competed DOE for this topic with all the data & analysis you might need. The article Dave Scott linked to is actually close ... the results of a designed set of experiments (a "DOE") to optimize the heating profile. ITt gives the basic results as well as some of the basic graphs that would be produced.
If you want to do your own DOE from scratch, you need to decide what you want to learn (and how big of a budget you have). I am not an expert on reflow profiles, but from the article, it appears that some key parameters are
* initial ramp rate
* soak temperature
* soak time
* peak temperature
* cooling rate
Since you said you wanted to "optimize" the process, then a RSM (response surface methodology) approach would be called for. With 5 factors, you would need 30-50 individual trials to complete a standard DOE. From the results of these trials, you would then perform the analysis to determine the optimized parameters.
As an alternative, you might consider an EVOP (evolutionary operations) approach. Here you make minor adjustments to an existing process and see what the results are. The disadvantage is that it might take longer to optimize the process. the advantageis that you can continue with normal production as you do the experiments.
Tim F
harry
Hello All,
I believe you are dealing with lead free solders - which had caused a flurry of discussions and studies because of different characteristics.
There are a number of discussions in google and some specialized forums (such as smt forum). You may be able to get some ideas from this page.
T Comparative Design of Experiment to pick better Trimming Blade Supplier Six Sigma 5
F Resolution III Factorial Design for a Screening Experiment Six Sigma 2
B Design of Experiment - 24 Samples per Run Statistical Analysis Tools, Techniques and SPC 16
B Design of Experiment (DOE) for Heat Treatment Process Statistical Analysis Tools, Techniques and SPC 4
M Design of Experiment (DOE) Help Needed Quality Tools, Improvement and Analysis 8
S DOE (Design of Experiment) with Several Output Variables Quality Tools, Improvement and Analysis 4
DuncanGibbons Section 8.3 relevant for design organisations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
R Is a FAIR required on parts that we design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
J Significant change related to design and intended use EU Medical Device Regulations 3
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
U NOC - What is considered a "design change" EU Medical Device Regulations 5
Q PPT used as Design Review ISO 13485:2016 - Medical Device Quality Management Systems 3
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
D Design controls - Inputs, outputs, V&V, DHF, DMR ISO 13485:2016 - Medical Device Quality Management Systems 10
LostLouie Manufacturer divorced from Design process, is he justified in design process deficiencies? ISO 13485:2016 - Medical Device Quality Management Systems 9
R DFA & DFM - Examples for Design for assembly and design for manufacturability Lean in Manufacturing and Service Industries 2
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
A Design History File - Not ready to share the design drawings or Bill of Material US Food and Drug Administration (FDA) 2
W Need for current design or process control FMEA and Control Plans 2
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Qualification and Validation (including 21 CFR Part 11) 5
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
A Sample Agreement available for Outsourcing Medical Device Design activity? ISO 13485:2016 - Medical Device Quality Management Systems 1
DuncanGibbons How is the arrangement between Design and Production organisation envisaged? EASA and JAA Aviation Standards and Requirements 4
L Design & Development of a SERVICE Service Industry Specific Topics 13
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A AS9102B - 3.6 Design Characteristics and form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
S MDR Delay - MDD design Change? (before new MDR DOA) EU Medical Device Regulations 8
J Iterative design and production for custom made products ISO 13485:2016 - Medical Device Quality Management Systems 3
T Design Input detail & specificity ISO 13485:2016 - Medical Device Quality Management Systems 4
J Design file for pre-existing products - Inputs and Outputs ISO 13485:2016 - Medical Device Quality Management Systems 5
D Design Transfer Template capturing Customer Specific Requirements Other Medical Device Related Standards 3
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
M Looking for a Presentation on Design for Excellence (DfX) Manufacturing and Related Processes 2
K Old medical devices -> 7.3.7. Design and development validation ISO 13485:2016 - Medical Device Quality Management Systems 1
