Design and Development Outputs Approval, Verification and Validation
morteza
Hi all,
I can not understand the difference between approval of design and development outputs (clause 7.3.3) and design and development verification (clause 7.3.5).
I think that one of the approval activities is the examination or assessment whether design and development outputs meet the input requirements of design and development or not. I think approval of design and development outputs includes checking of the satisfaction of sub-clauses 7.3.3 a to 7.3.3 d.
So, the approval of design and development outputs includes the verification activity.
In addition, ISO/TS in clause 7.3.3.1 requires design and development outputs validation.
Validation is the examination of product against the user needs (intended use). It is not the examination of design and development outputs against design and development inputs. Validation process is usually done by testing of prototypes in application conditions or bench tests.
In my view, ISO/TS should not use the term validation in clause 7.3.3.1
Thanks in advance for clarification.
John Broomfield
Re: Design and Development outputs approval,verification and validation
Hi all,
morteza,
Design output may be approved before verification, before validation and certainly before being issued for purchase or production.
The design output should be verified before its is validated so you know what you have validated. As an aside I understand the Wright Bros invented a plane that would fly because they verified before they validated. The successful design may then be approved for purchasing, delivering (in the case of a service) or producing.
Conflating approval with verification may suggest to some users that the validated design information does not need to be approved before issue for production (but it does).
Prototypes may be tested to validate the design but how would you do that with a bridge?
Designs may be validated with computer models, or by use of previously successful designs (for products operating in similar service conditions) or by partial prototypes testing (including freeze/thaw cycling, bake and shake or corrosion cycling perhaps) for novel features or by trial runs.
Approval of the design for production follows verification and validation but because validation is expensive approval of the verified design usually precedes validation as well (see 7.1c or 7.3.1).
Lastly 7.3.3.1 is not specifying validation requirements, but it is saying that product design output shall be expressed so it can be verified and validated.
The only problem with the list is differentiating what design output can be verified and what design output can be validated. The list does not include design prototypes but it is not meant to be exhaustive.
As with all minimum requirements you can decide to do more as necessary to run an effective design and development process (see 4.1f).
The verification team may report to the person who approves the design for validation on seeing evidence of verification.
For these reasons I recommend that you keep separate verification and approval.
John
sagai
You have just selected one of the most controversy subject :)
My view is that ...
design verification and validation are not equivalent with testing.
Design verification runs throughout the whole design and development process, it manifested in design reviews, peer reviews, design meeting, even in the kitchen when people are talking to each other and trying to find out if they are about to develop the product according to specification. And yes, one of the verification activity is testing according to predefined protocol.
Validation also pervading the r&d, think about the traceability of the requirement engineering, validation of tools they use, etc and also, yes, one of the validation activity is user testing/validation.
The other thing is, this Design Output question.
You should find you way, I still believe, design output more or less all of the specification, test protocols, meaningful review remarks (not necessary documented), test and validation results, tool testing and validation, r&d process definition, all of the things are describing the design effort and the result of the design and development activities.
Okay, maybe it makes more confusion than less ...
Do not necessary think about one golden document and one golden revision. Design output evolves in terms of content and in terms of maturity of those content during the r&d activities, and when you say okay ... we have something we consider as ready to manufacture, that is the moment when you could claim, you have final design outputs.
These are just thoughts, neither ultimate truths, may help you to find your own way.
Cheers!
morteza
John
Thanks for your great answer.
I understand that the first paragraph of clause 7.3.3.1 is about the format of product design outputs. But, I think the writing format of the requirement is not correct. Because according to clauses 7.3.5 and 7.3.6:
verification is done by comparing product design outputs against design input requirements. And
validation is done by comparing product design outputs against specified intended use requirements, NOT against design input requirements.
So, it would be better that ISO/TS would write the requirement in this way:
The product design output shall be expressed in terms that can be verified and validated against product design input and specified intended use requirements.
I hope this clarifies my question.
Thanks again
John Broomfield
John
Thanks again
morteza,
Verification of design outputs against "design input and specified intended use requirements" is near enough the same as "product design input requirements".
In other words the standard is specifying does it look as if the design fulfills the brief?
Then, once we know the characteristics of the design output (through verification) we are ready to validate the design to see if it actually works. Indeed, validation may show deficiencies in the design brief (design inputs).
John
C AS9100 8.3.5.e Design and Development Outputs - Key Characteristics / Critical Items AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Identification of Inputs vs. Outputs in Design and Development (Section 7.3) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Design and Development Outputs for Software Development (7.3.3) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
somashekar A question on D&D Outputs in Design and Development Stages (7.3.3) ISO 13485:2016 - Medical Device Quality Management Systems 4
H Design and Development outputs - How Should I audit it? Clause 7.3.3 Design and Development of Products and Processes 7
B Design and Development Audit checklist - What are design inputs and design outputs? Design and Development of Products and Processes 1
H Design and Development Review 7.3.4 - Planned intervals for outputs and validation Design and Development of Products and Processes 3
Howard Atkins Design and development outputs Design and Development of Products and Processes 4
S ISO13485:2016 7.3.9 design and development change ISO 13485:2016 - Medical Device Quality Management Systems 3
S Design & Development records for Medical Devices Packaging and Labelling ISO 13485:2016 - Medical Device Quality Management Systems 8
R Role of QA during Design and Development of Products and Processes Design and Development of Products and Processes 4
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E Design and Development file Procedure ISO 13485:2016 - Medical Device Quality Management Systems 0
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 9
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
L Design & Development of a SERVICE Service Industry Specific Topics 13
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
K Old medical devices -> 7.3.7. Design and development validation ISO 13485:2016 - Medical Device Quality Management Systems 1
M Design Development MDR Design and Development of Products and Processes 0
O How can I justify excluding the R&D group and the design and development clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C IATF 16949 8.3 Exclusion - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 6
A Design and development of products and services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 & ISO 14001:2015 - I need a format for Design & Development planning ISO 14001:2015 Specific Discussions 2
AlienraverX Design and Development Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V Who should define and own the Design and Development Plan and how to maintain the updates and revisions. ISO 13485:2016 - Medical Device Quality Management Systems 2
K Design and Development Exclusion Quality Management System (QMS) Manuals 1
V Exclusion of 'Design and Development' from scope of certification ISO 13485:2016 - Medical Device Quality Management Systems 9
XRAY_3121 Design and Development Requirement - MDSAP Audit Finding Other Medical Device Regulations World-Wide 5
P Performance evaluation (IVDD Annex VIII) & Design and Development Validation Studies EU Medical Device Regulations 1
S Waterfall model or v-model design and development ISO 13485:2016 - Medical Device Quality Management Systems 2
JoshuaFroud Design and Development of Software under 13485:2016 or 62304? ISO 13485:2016 - Medical Device Quality Management Systems 6
M IATF Clause 8.3 - Design and Development IATF 16949 - Automotive Quality Systems Standard 5
K Design and Development Exemption/NA confusion Design and Development of Products and Processes 6
L Software Medical Device - 7.3.8 - Design and Development Transfer ISO 13485:2016 - Medical Device Quality Management Systems 4
S Purchasing for Design and Development Organization ISO 13485:2016 - Medical Device Quality Management Systems 3
qualprod Development separated from design? ISO 9001 cl. 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Design and development of user centric audit report visualisation tool Design and Development of Products and Processes 5
D IATF 16949 Design and Development Planning IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Cl. 8.3 - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 1
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
A ISO 13485:2016 Certification for Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 0
H IATF 16949 Cl. 8.3 - Design and Development Exclusion Question IATF 16949 - Automotive Quality Systems Standard 4
R Development of Design FMEA - Functional Requirements FMEA and Control Plans 1
G ISO 9001:2015 8.3 Design and Development (in Civil Engineering) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M AS9100D excluding Design and Development - Small Job Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
Moumen H API Spec Q2 Design and Development Requirements for Service Providers Oil and Gas Industry Standards and Regulations 11
