Design and Development Process vs. Product
carolk79
Here is my situation. I have just been through my reregistration audit for ISO 9001:2000. We have design of product excluded from our certificate this time which was originally on the certificate. My president and registrar change the scope without informing me. A week before the audit I received an updated audit plan with the change on it. I tried to change what I could but it wasn't enough. So anyways, I received a minor nonconformance for not updating documentation due to the change in scope.
I understand in our procedures and work instructions what I need and don't but the standard is giving me troubles.
Can I exclude all of 7.3?????? If so where does process design fall. Will I need to keep some of 7.3 to allow for process design????
I am just so confused.
Please Help
Sidney Vianna
Post Responsibly
Hi Carol,
The basic rule is: if your organization is responsible for the design of the PRODUCT, then you can not claim exception to 7.3 and be certifiable to ISO 9001:2000. Check examples 2 and 3 HERE
Douglas E. Purdy
Sidney Vianna said:
Hi Carol,
Sidney,
Thanks for the update on this Guidance Document. I believe it was you that brought these to our attention earlier this year. I did not know that this document had been revised. How do you keep up with these changes? Do these documents hold any weight (authority) in the certification / registration system yet?
Doug
carolk79
We do not design product at our facility.
But my auditor said I have to have design of process. My only problem is I don't know where this requirement is or how to meet this requirement.
Sidney Vianna
Post Responsibly
Very Simple!
It is very simple. You challenge his/her assertion. Provided that we are talking ISO 9001 (that's my assumption since we are in the ISO 9000 Forum, and not TS-16949), have you auditor read paragraph 7.3 of ISO 9001:2000
7.3.1 Design and development planning
The organization shall plan and control the design and development of product..
It should be clear after that.
If s/he insists that you have to apply 7.3 to the product realization PROCESSES, then, you calmly, tactfully and diplomaticaly asks:
Dear auditor, could you please help me out finding this requirement in the Standard?
And don't ever feel afraid to elevate this to someone at the Certification Body's office. Auditors will make bad calls (I've done it) from time to time, and someone at the CB technical staff should clear the issue.
Hope this helps.
RoxaneB
I'm with Sidney on this one, Carol. :) My organization has excluded ALL of 7.3 because, while we may design the PROCESS we do not design the PRODUCT.
Our Product specifications are provided from other sources. We simply design our processes to ensure we can provide the product. :)
For what's it worth, Carol, it took me some time to wrap my head around this whole PROCESS/PRODUCT design issue. :eek:
It sounds to me like you have a TS auditor. In TS, you cannot exclude process design. But, then again, TS puts a focus on the requirement that is not present in 9K.
With that stated, it might not be a bad idea to look at process design. There is a good possiblity that doing so will uncover problems (actual and potential).
carolk79
You guys are great
Thanks this helps me a lot but I still have one more question???
Let me help you understand.
We are a fiberglass shop. What we do is regular production parts and, what we call "projects" "Projects" are one of two thing: 1)our customer provides use with a plug, or reversed mold, and we build a mold from there design.
2) Customer provides use with a print and/or drawing and we have to build a plug and a mold.
Now when we receive a RFQ on a mold we go through the following process:
After quote is accepted:
1)Create a timeline indicating person responsible, description of duties, date
and time of each process, and completion date. This is then submitted to
the customer.
2)When this is accepted by the customer, the work,including prints, drawing,
timeline, and a project Log is sent to production.
3)When requested by the customer, design reveiws are done periodically to
ensure that the customer design is feasible and meets requirements. At
the reviews, the customer comes to our shop and reviews progress and
initiates any changes that may need to be made.
4)After the mold is complete, a prototype is made from the mold.
5)The prototype is then sent to the customer for approval. If approved, the
customer will pay the remaining balance and we will begin produstion per
purchase order.
6)If not approved, customer will return the part with neccessary corrections
Changes will then be made and another prototype built and sent.
Now that you know all this information here is my question:
If I exclude design from my scope, what do I do with all this info????
Does this merely fall under product realization???
Could changes in design, specified by customer, be Engineers Changes???
Paul Simpson
Your choice
carolk79 said:
The problem is if you elect to include process design (as it sounds like your president has) then all elements of 7.3 come into play. The note 2 under 7.1 planning clearly allows you to apply the principles of design control to your own product realization processes - but it is your choice!
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
C IATF 16949 8.3 Exclusion - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 Cl. 8.3 - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 1
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
O Design and Development Process - Does one size fit all? ISO 13485:2016 - Medical Device Quality Management Systems 13
L Medical Device New Product Design & Development- How long does this process take you? Other Medical Device and Orthopedic Related Topics 1
W Design and Development, and Assembly Process Quality Metrics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Process Development Requirements for a Contract Manufacturer with no Design Design and Development of Products and Processes 5
V Examples of Design and Process FMEA for Pharmaceutical Product Development ISO 14971 - Medical Device Risk Management 7
K Process Auditing Clause 7.3 Design and Development Internal Auditing 11
AnaMariaVR2 Pharma ?Quality by Design? (QbD): An Introduction, Process Development & Applications Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
B 7.3.1 Design & Development Planning related to Process Design IATF 16949 - Automotive Quality Systems Standard 4
T How to link Process Design Changes in Serial Production to Design & Development? Design and Development of Products and Processes 6
D AS9100C PEAR (Process Effectiveness Assessment Report) for Design and Development AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
kedarg6500 Manufacturing Process Design and Development Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Manufacturing Process Design and Development Review - TS 16949 Clause 7.3.4 IATF 16949 - Automotive Quality Systems Standard 12
R Setting Departmental Objectives - Product and Process design & development IATF 16949 - Automotive Quality Systems Standard 2
T Scaffolding Service - ISO 9001 Clause 7.3 Design and development process Design and Development of Products and Processes 3
ScottK What defines the need for the ISO9001 Design & Development process? Design and Development of Products and Processes 15
J Determining Legal& Statutory requirements while Auditing Design & Development process Design and Development of Products and Processes 8
S Design & Development Process - Graphic Design Work Design and Development of Products and Processes 14
A How to Document the Design & Development and Resource Management Process in IT Firm? Design and Development of Products and Processes 2
A Can you suggest meaningful KPI's for our Design and Development process? Design and Development of Products and Processes 5
U Process Ownership - APQP shall be be led by Design & Development Dept? Design and Development of Products and Processes 2
R Processes in Design & Development - Have you Defined Manufacturing Process Designs? Design and Development of Products and Processes 11
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 5
L Design & Development of a SERVICE Service Industry Specific Topics 13
K Old medical devices -> 7.3.7. Design and development validation ISO 13485:2016 - Medical Device Quality Management Systems 1
M Design Development MDR Design and Development of Products and Processes 0
O How can I justify excluding the R&D group and the design and development clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Design and development of products and services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 & ISO 14001:2015 - I need a format for Design & Development planning ISO 14001:2015 Specific Discussions 2
AlienraverX Design and Development Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V Who should define and own the Design and Development Plan and how to maintain the updates and revisions. ISO 13485:2016 - Medical Device Quality Management Systems 2
K Design and Development Exclusion Quality Management System (QMS) Manuals 1
V Exclusion of 'Design and Development' from scope of certification ISO 13485:2016 - Medical Device Quality Management Systems 9
XRAY_3121 Design and Development Requirement - MDSAP Audit Finding Other Medical Device Regulations World-Wide 5
P Performance evaluation (IVDD Annex VIII) & Design and Development Validation Studies EU Medical Device Regulations 1
S Waterfall model or v-model design and development ISO 13485:2016 - Medical Device Quality Management Systems 2
JoshuaFroud Design and Development of Software under 13485:2016 or 62304? ISO 13485:2016 - Medical Device Quality Management Systems 6
M IATF Clause 8.3 - Design and Development IATF 16949 - Automotive Quality Systems Standard 5
K Design and Development Exemption/NA confusion Design and Development of Products and Processes 6
C AS9100 8.3.5.e Design and Development Outputs - Key Characteristics / Critical Items AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Software Medical Device - 7.3.8 - Design and Development Transfer ISO 13485:2016 - Medical Device Quality Management Systems 4
