Design and Process - Validation vs. Verification - What is the difference?
Kevin Mader
One of THE Original Covers!
#11
Dbzman,
Say that you can’t verify hardness of the part because the hardness test is a destructive test method (it will leave a dimple where you don’t want one). How will you ensure that the heat treat process produces the right results?
You must validate the process by knowing what the process is capable of producing through various validation and verification techniques. Perhaps the only way to ensure shipping the right hardness is by knowing the process intimately, through a prior validation process, where you can offer reasonable assurance that the outcome will meet specifications (process control monitoring, sample bar of material with similar composition, etc).
If I run a process in statistical control, my outcomes are predictable. By performing SPC, I monitor the process and know that the outcomes are what they should be, without having to perform any verification activities (beyond initial process validation, of course).
Regards,
Kevin
O
olddog
#12
Re: Reply to Answers
dbzman said:
Thanks for all of the input!
One more question:
we are a Heat Treating company. All we do is take the customer part, heat treat it to harden it, and then send it back to the customer. We test for hardness to make sure that it is correct. Verification
How does verification and validation fit into this?
Thanks!:bonk:
When you setup the line to process the next batch of parts for this customer and take a first piece sample to assure that hardness is within the requirements you are validating. (You do this by testing a part -verification)
howste
Thaumaturge
#14
Re: Speaking of diferences
tattva said:
Can anybody tell me now the diference about efficiency and effectiveness?:confused:
Why don't we start with the ISO 9000:2000 definitions:
effectiveness
extent to which planned activities are realized and planned results achieved
efficiency
relationship between the result achieved and the resources used
Effectiveness is about how well something works. Efficiency seems to be about how much it costs to do it (in terms of $$, people, or other resources).
L
Link Xue
#15
Re: Validation & Verification - Dif??
Originally posted by dbzman
Could someone help me better understand the differance between "Validation" and Verification"?
Thanks!
:bonk:
I think in TS 7.5.2 Validation of processes for production and service provision has clear definition, it said:
The organization shall VALIDATE any processes for production and service provision where the resulting output cannot be VERIFIED by subsequent mornitoring or measurement..............
SO, VALIDATE IS A PROCESS
VERIFY IS AN ACTION
howste
Thaumaturge
#16
According to the ISO definitions, verification is confirmation that a requirement has been met. Validation is confirmation that a requirement has been met related to the intended use of the product (or process).
N
noboxwine
#17
Thanks!
:bonk:
Verification: Paper
Validation: Product
tattva
#18
Originally posted by tomvehoski
Verification will be to do a hardness check to make sure you hardened it to the correct specification. Validation will most likely be up to your customer - unless you have the ability to run the part in a real world type test.
In your situation I normally state something to the effect that verification is the act of inspection. Validation is the responsibility of the customer. As long as the customer does not complain, and pays the invoice, the part is considered validated and the design process can be considered closed.
Tom
I´m in the foam seat industry and we do perform hardness test to seats, and recently one of our customers in Plymouth found out one headrests was not in SPC, they said it had 14.5 N for I.L.D., the SPC is 30.6 to 39.5, they sent it back to us, made us to present a contianment program, hand & visual verification, and many other things, president of this company even said: how in God´s Name we were QS certified and worse trying for TS.
The issue here is that the piece was returned to us and try another shot for the piece´s hardness " IT WAS 31.6 N". So is it a good thing to leave validation to the customer?
Any ideas about another way to perform validation? Thanks im advance :truce:
howste
Thaumaturge
#19
It sounds like you need to do a correlation of measurement methods with your customer, and educate them on the proper method. More than likely your method is right, since (I assume) you're the experts...
#20
From TS2;
Verification - "...ensure that the design and development outputs have met the design and development input requirements".
Outputs are design records, BOM, test requirements, process studies,etc.,etc. that are required to meet the input requirements.
Validation - "... ensure that the resulting product is capable of meeting the requirements ...".
This is perfromance testing of the product.
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
W Design and Process Validation - Different? ISO 13485:2016 - Medical Device Quality Management Systems 6
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
Chennaiite How to Measure Effectiveness of the Design Validation Process? Design and Development of Products and Processes 7
L Design Validation Process Owner - Who should be the process owner of validation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Process, Product and Design Validation - One-off Tools ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
M Sample Size in Design Verification & Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Can Process Validation actually be Design Verification? Design and Development of Products and Processes 4
Q Design Control and Process Validation Tools and Presentations (Medical Device) wanted Design and Development of Products and Processes 7
Q Differences between Sample Sixes for Design Verification vs. Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
P Design Validation & Process Validation Requirements - Automotive Electronics Design and Development of Products and Processes 3
A Manufacturing process design validation - What aspects are validated? Design and Development of Products and Processes 3
LostLouie Manufacturer divorced from Design process, is he justified in design process deficiencies? ISO 13485:2016 - Medical Device Quality Management Systems 9
W Need for current design or process control FMEA and Control Plans 2
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
B Supplier of design and manufacture process ISO 13485:2016 - Medical Device Quality Management Systems 10
A Design process goal for ISO 9001 Manufacturing and Related Processes 23
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
C IATF 16949 8.3 Exclusion - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 5
C Design Transfer - How do you guys control the design transfer process? Document Control Systems, Procedures, Forms and Templates 5
H Measuring Design Process Design and Development of Products and Processes 4
B Outsourcing process design (8.3.3) IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Cl. 8.3 - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 - Cl. 8.3.3 - Product design inputs, manufacturing process design inputs IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
V For a Drug-Device Combination Product, 'Design Control' Process is triggered at? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
Q ISO 9001:2015 - Design of Process vs. Design of Service Service Industry Specific Topics 4
T TS16949 Process Design Requirements IATF 16949 - Automotive Quality Systems Standard 2
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
N What does an effective design process look like? (shoots flare in the air) Design and Development of Products and Processes 2
O Design and Development Process - Does one size fit all? ISO 13485:2016 - Medical Device Quality Management Systems 13
L Medical Device New Product Design & Development- How long does this process take you? Other Medical Device and Orthopedic Related Topics 1
D ISO 9001 Design Process Flow Chart ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G ISO 14001 & Product Design Process Environmental Aspect Review Requirements ISO 14001:2015 Specific Discussions 7
W Design and Development, and Assembly Process Quality Metrics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Audit Design Process every Surveillance Audit - AS9104 Requirement? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
H How to make the Design Review Process Effective Design and Development of Products and Processes 1
R Process Development Requirements for a Contract Manufacturer with no Design Design and Development of Products and Processes 5
V Examples of Design and Process FMEA for Pharmaceutical Product Development ISO 14971 - Medical Device Risk Management 7
K Process Auditing Clause 7.3 Design and Development Internal Auditing 11
V The best practice to maintain & link Design and Process FMEAs FMEA and Control Plans 8
A ISO/TS 16949 - 7.3.3.2 Manufacturing Process Design Output IATF 16949 - Automotive Quality Systems Standard 6
AnaMariaVR2 Pharma ?Quality by Design? (QbD): An Introduction, Process Development & Applications Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Q Tracking Log for IP during Design Control Process Document Control Systems, Procedures, Forms and Templates 1
B 7.3.1 Design & Development Planning related to Process Design IATF 16949 - Automotive Quality Systems Standard 4
T How to link Process Design Changes in Serial Production to Design & Development? Design and Development of Products and Processes 6
