Design/Change Control Procedure - How to cope with Changes during Development?
todayssunny
#21
Hi Aphel,
I'm not sure if this thread is still active.
However in such a case as described by you,
our procedure requires to complete a design change form (during development / pre design transfer).
A part of this form is to assess the change impact...in your case the assessed impact would be to go back and do the change and repeat design verification afterwards.
bes regards
#22
Hello everybody,
Thank you for all the answeres and guesses...
The problem i have, is not to control changes in single documents (e.g. drawings), therefor we have a nice procedure (document controls).
But what are your solutions (procedures) if you have for example the following change during development:
Imagine, you just went through the milestone design freeze, you have already startet design verification. And now - during design verification you realise, that you are not able to pass a certain requirement and you are forced to make a change to a functional design input requirement.
What are your design change procedures saying in such cases?
How do you organise, manage and document such necessary changes?
Best regards,
Aphel
I also have the same question.
I don't know how to properly control the design change before design transfer, and don't know how to compile the Design History File (DHF) after the design change has been finished.
yodon
#23
At some point, the design artifacts go under design controls. Any change after that must follow the Design Changes procedures (820.30(i)). Presumably, you already have procedures for this. Typically, a "change request" is opened then that is reviewed to determine scope and impact (especially on the Risk Analysis). The proposed changes are approved and then implemented. Some method to verify or validate the changes is defined. If you have already done any system V&V then the impact of the change on those efforts needs to be evaluated and likely some additional V&V work is warranted. The change record providing traceability to what all changed / what was done as well as the updated design artifacts become part of the DHF.
Hope that makes sense.
In the future, it might be best if you open a new thread rather than jumping on an old one.
QAengineer13
#24
After reading this page, I need some clarity related to the concept of Pre-Production change control and Post-production change control
In a design and development project, say they have an alpha build, beta build and then their Pre-production unit (PPU) build.
Before PPU build process start is when the design freeze happens and the Design verification starts.....
Is the term Pre-production change control means anything and everything related to the change control before the DESIGN TRANSFER is my understanding, correct? and Post-production is after the sucessful transfer and the Production units are built, is this correct?
:thanx:
Marcelo
#25
Nope, pre-production should in fact be before design input (because after that, the design process "goes into" design control).
QAengineer13
#26
Thanks Marcelo, but sometimes I find these FDA terminology used are tricky for interpretation.
For conversation sake,
In this case if the pre-producttion is before Design Input because the Design Control process kicks in, I agree then the FDA should used a simple plain language as "Pre-design control change process" or "Pre-input freeze change control process" why would they use a term " production" when the production of the NPI/NPD happens only after successful design transfer?
Please let me know whether my interpretation makes any sense? thanks:cfingers:
QAengineer13
#27
Also could you or anyone in the group share with me an example of what would be the Pre-production change control checklist/ form/ procedure would look like? :thanx:
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Design/Change Control Form Example and Advice Design and Development of Products and Processes 13
T Design and Development: 7.1.4 - Change Control - What is a good change control system Design and Development of Products and Processes 7
J Significant change related to design and intended use EU Medical Device Regulations 3
U NOC - What is considered a "design change" EU Medical Device Regulations 5
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
S MDR Delay - MDD design Change? (before new MDR DOA) EU Medical Device Regulations 8
H New 510K VS Documents about design change. Other US Medical Device Regulations 1
R Explain what "design change" is to people new to the industry ISO 13485:2016 - Medical Device Quality Management Systems 9
T Closing out CAR while waiting for design change Nonconformance and Corrective Action 12
L Managing design projects: New Medical Device Project or Change Design and Development of Products and Processes 1
T How to Document Risk Effects on Design Change(s) ISO 14971 - Medical Device Risk Management 3
I Another design change or new product? IVD device ISO 13485:2016 - Medical Device Quality Management Systems 6
S Engineering change order versus a design change request ISO 13485:2016 - Medical Device Quality Management Systems 1
Q PPAP - How to determine the "Design Record Change Level" APQP and PPAP 2
S Verification and Validation of Post Market Design Change Design and Development of Products and Processes 2
A Reporting of Design Changes (Color Change Only) EU Medical Device Regulations 5
Q 510K Checklist that considers every Design Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Medical Device DHF (Design History File) - One per Design Change? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
V Product Evaluation Requirements for Change in Manufacturing Facility/Change in Design 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
S Design Change vs. Intellectual Property Design and Development of Products and Processes 9
J What should be included in the Design Change Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S External or Internal Design Change and Responsibilities Document Control Systems, Procedures, Forms and Templates 3
C Design Change needed for Changing an Angle in existing Product from 15-25 degrees? ISO 13485:2016 - Medical Device Quality Management Systems 11
S Design Change Drawing Reviews and Customer Approval Process Document Control Systems, Procedures, Forms and Templates 5
A Design Review OR Design Change - Software development company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Procedure for "Customer Acceptance of a design or process change" Design and Development of Products and Processes 12
B Severity Reduction by Product or Process Design Change? Seeking Good Example Design and Development of Products and Processes 2
S FMEA Severity Rating - Will a Process Design Change also Change the Severity Rating? FMEA and Control Plans 21
L Outsourced Design with Internal Design Change Design and Development of Products and Processes 2
J When does an engineering change become a design change? Design and Development of Products and Processes 7
A Engineering change validation - Companies that have no design responsibility Design and Development of Products and Processes 5
R Is design change applicable (7.3.7)? Design and Development of Products and Processes 2
M Reducing both Detection and Occurance in a Design FMEA WITHOUT a Design Change FMEA and Control Plans 8
N What are the VDA requirements for Design change? VDA Standards - Germany's Automotive Standards 2
K FMEA - Reduce Occurance of a Failure (or its cause) by Design Change FMEA and Control Plans 6
DuncanGibbons Section 8.3 relevant for design organisations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
R Is a FAIR required on parts that we design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
Q PPT used as Design Review ISO 13485:2016 - Medical Device Quality Management Systems 3
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
D Design controls - Inputs, outputs, V&V, DHF, DMR ISO 13485:2016 - Medical Device Quality Management Systems 10
LostLouie Manufacturer divorced from Design process, is he justified in design process deficiencies? ISO 13485:2016 - Medical Device Quality Management Systems 9
R DFA & DFM - Examples for Design for assembly and design for manufacturability Lean in Manufacturing and Service Industries 2
