Design Control and Release Manual plus a Quality Manual
Brian Hunt
I'm currently implementing the quality management system in an organisation which does a lot of design work for clients. As the design control and release processes are the directly value adding activities, I've decided that the creating a stand-alone Design Control and Release Manual which covers Clause 7 (Product Realisation) and clause 8 (measurement analysis and improvement) would, when translated into clear English rather than ISO 9000 speak (who uses the term product realisation in real life?) would help this manual to be used and developed as part of day-to-day operation - it should become a home for documented best practice from around the organisation.
This manual is referenced from the quality manual and these two manuals together describe the documented quality management system and cross-reference the supporting procedures and records.
Has anyone else taken this approach? How successful has it been? If anyone has translated the requirements of Clause 7 and 8 into 'normal' language then please share it with me
Marc
Another quick "Bump". My Thanks in advance to anyone who can help with this one.
somashekar
Hi Brian Hunt...
I see that you are forcing yourself to draft procedures more out of some perceived need than the requirement.
If you are talking ISO9001 QMS then all your "How you do" the design work for clients can be within your procedure for design and development and you can include design delivery just like the design delivery that happens within an organization. As you will have clients who begin to own the design after you deliver, most of the phases of final design approvals indeed happens with the client involvements, and at several places within the design and development procedure, you must map this.
I would say that this procedure you make will not be one, but several that meets each of the clients needs and is accordingly drafted.
For the rest, ISO does not demand a procedure, and where it demands you could have then addressed and controlled separately.
It is good to have documentation that works for you rather than make a volume, looking into all bits and details. Continue to refine them as you begin implementing the documented procedures. The Quality manual can again be as simple and as innovative as you can think of that just meets the ISO9001 4.2.2 requirements.
Just my thoughts ~~~
Brian Hunt
Thanks for your comments ssomashekar
My intention is not just to do the minimum to get ISO9001:2008 certification but to achieve a better way of managing the design process. ISO9001 provides a good framework for the development of Design Operations Manual - what gets in the way, is the strange language that the standard uses. The use use of 'shall' for one example, is not the language used in business to describe how processes and procedures are managed. Terms like 'product realisation' also create a barrier to understanding.
The Design Operations Manual will be compliant to ISO9001:2008 requirements but will be written in ever day English so that it can be used as aid rather than an hinderance.
Marcelo
There's more to clause 7 and 8 to any processes, even contracted ones. For exampl,e how is training of the people performing the process handled? How are the resources used in the process handled? I think I understand what your are tryying to to, but keep in mind that you might need to apply almost the whole of the standard.
somashekar
My intention is not ISO9001 certification at all. A good way to manage the design and development process is to identify the stages and the interaction between the stages and the parties involved in finally getting the design and development outputs that is usable.
You will be able to see a mini ISO9001 process within the design and development activity.
As design and development deals with higher levels of personnel, I would not suggest a good rundown procedure steps aka work instructions in the design and development documented procedure.
If you are aligning to the ISO9001 system, then read the standard, understand the intent and concept and draft the procedure in your own type and style. Get correctly the "what to do" and write procedure in a way everyone within the organization understands the "How you do it" part.
Brian Hunt
Yes - training, infrastructure and the other things have to be in place for an ISO9001 compliant organisation are all relevant. These will be covered in the Quality Manual - the Design and Release Manual will be for the customer value chain i.e. all the activities that add value for the customer from the actions of the design engineer.
That assumes that all staff are trained to do the job and that all the other support functions are in place - the design team don't need to know that.
Brian Hunt
I went ahead and did it anyway...
Now attached - still in draft and the process of translating ISO9001 speak into something that people recognise as English is still in progress.
I would really value you comment, good and bad on this.
Cheers
Brian
K Is more than one Design Control & New Product Release Procedure OK? Design and Development of Products and Processes 3
W Need for current design or process control FMEA and Control Plans 2
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Relabeler for patent expired product - design control responsibilities? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Design Control - Ways of capturing inputs from manufacturing Other Medical Device Related Standards 5
M Medical Device Design Control Auditor Recommentations General Auditing Discussions 19
R Operator's manuals as prevention design control FMEA and Control Plans 2
S Design Control for Class I Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Defining Approvals Required for Design Control Documents ISO 13485:2016 - Medical Device Quality Management Systems 6
C Design Transfer - How do you guys control the design transfer process? Document Control Systems, Procedures, Forms and Templates 5
S Is Human Factor Testing required as part of Design Control Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
W Design Control Assistance required ISO 14971 - Medical Device Risk Management 7
V For a Drug-Device Combination Product, 'Design Control' Process is triggered at? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Design Control - Can Validation be based on a limited/first Production Run ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Design Control for Relabeling and Repackaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Dual ISO 9001 (Manufacturing) and ISO 13485 (Design Control) for same product line ISO 13485:2016 - Medical Device Quality Management Systems 3
J Incoming Inspection Plans under Design Control (part of DMR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Design & Documentation of Control Systems and Procedures Document Control Systems, Procedures, Forms and Templates 11
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
A Design Control Requirements: IDE exempt, NSR Device (Clinical Study) US Food and Drug Administration (FDA) 2
M Class II Medical Device Design Control Non Conformance 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
I Content to be included or excluded in Design Control Meeting Minutes ISO 13485:2016 - Medical Device Quality Management Systems 4
H ISO 9001 Document Control Requirements - Design and Development Department Checklists Document Control Systems, Procedures, Forms and Templates 3
M QSR - Design Control on Existing Device not Designed following QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H Medical Device Design Control Requirements (820.30) on Existing Products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Internal Design Control Audit ISO 13485:2016 - Medical Device Quality Management Systems 5
E Better control of DHR (Design History Record) during processing Document Control Systems, Procedures, Forms and Templates 5
D Class I and Class II Medical Device Accessory Design Control Requirements US Food and Drug Administration (FDA) 3
G Understanding Identification of Design in QSR 21 CRF Part 820.30 Design Control (f) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Tracking Log for IP during Design Control Process Document Control Systems, Procedures, Forms and Templates 1
K 7.3.7 Control of Design & Development Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Design Control - Parent Company is located in Australia 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S New Requirements for Design Control in AS9100 C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
W Design History Verification Records Control and Approvals US Food and Drug Administration (FDA) 3
K Design Control SOP - Streamlining with R&D Department ISO 13485:2016 - Medical Device Quality Management Systems 6
A R&D Design Control - Ideas to Improve the Quality of Drawings Design and Development of Products and Processes 7
H Design Control Requirement - Initial Distributor of a Class I Video Laryngoscope US Food and Drug Administration (FDA) 4
M ISO 17025 and Design/Process Control Requirements ISO 17025 related Discussions 2
bobdoering Myth or Mythunderstanding: Implications of the Economic Design of Control Charts Statistical Analysis Tools, Techniques and SPC 1
C At what stage does Design Control play a role in Medical Device Development ISO 13485:2016 - Medical Device Quality Management Systems 2
B Suggestions on how to control a Design Dossier? Document Control Systems, Procedures, Forms and Templates 2
T Request for a Design Control Procedure or Process Flow for HVAC Design Document Control Systems, Procedures, Forms and Templates 1
A Design/Change Control Procedure - How to cope with Changes during Development? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 26
J What things go in Design Control Documentation for a 510k of Class II Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Design Control & Rapid Prototyping - Medical Device Software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Declaration of Conformity to Design Control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Declaration of Conformity to Design Control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
A QSR (820.30 part e) Design Review and Design Control Responsibilities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
