Design Control for Repackager-Relabeler
V
Victoria7
I am new to medical device and the company I work for doesn't have a Design Control Procedure. Everything I read says we need it. The CEO says we buy finished 510k's and put them in a convenience kit using the customer specs therefore we are not designing anything. The company has an ISO 9001:2008 certification with thier QSM saying they are exempt because of the reasons mentioned above.I found a LOT of info in FDA Guidance for Design Control, Medical Device QSM Compliance guide, 21CFR 820 and ISO 9001:2008. Looking for clarity.
Confused:bonk:
MIREGMGR
What have you been reading?
You buy devices, and sell kits. Are the devices you buy in bulk form, such that you are adding the primary packaging and the only label? Or are they individually packaged, and you leave that primary packaging intact and place the packaged product into your kit overpack, which then gets an overlabel describing the kit's contents?
In the former case, you're probably a repackager/relabeler. In the latter case, you're only a kit-packer.
In either case, I think it's unlikely that it could be concluded that you have design responsibility.
The only circumstance where that might apply is when a kit packer buys non-medical-device items from a general manufacturer, and--in the process of creating kits with them--re-purposes them for a clear medical device purpose. In that case, the kit packer is the most likely party to end up with medical device Manufacturer responsibility, and sometimes that can entail design responsibility so as to encompass the process by which a determination has been made that the product is suitable for the medical-device intended use.
V
Victoria7
We are a repackager/relabeler but we also sterilize the kits. In the past FDA has given them a 483 for not implementing Design Control while ISO has not??
MIREGMGR
Sterilization is a manufacturing activity. That's normal for kit packers. Manufacturing and design of course are separate.
It's always dangerous to reach conclusions from so little information, but it certainly would seem on the face of the situation as if perhaps the FDA inspector might have erred in that one regard.
It's really dysfunctional to add a design control process to a QMS when no design activity is undertaken. It's hard to write, hard to maintain and certainly hard to explain in subsequent audits and inspections.
If it hasn't been too long since the FDA's inspection in question, you might want to address all of the other issues that you think are needed, then request an explanation from the FDA of specifically what the inspector was reacting to, in making that citation.
V
Victoria7
Thanks miregmrg for your input. It gives me a lot to think about and share with the rest of the team. Your the best.:thanx:
I have visited the forum several times scanning through different posting for information but this is the first time I have posted. I'm sure i'll be back.
I
IAmLearning
Let me re-ask this question this way:
If an FDA registered repackager/relabeler company buys products from an FDA registered manufacturer/sterilizer company, and the manufacturing company does all the repackaging/relabeling work , and simply ships the product to the repackager/relabeler location, then what Quality Control documentations/procedures does the repackager/relabeler needs to have onsite to ensure they are in compliance with FDA's Quality Control regulations?
MIREGMGR
Repackaging and relabeling are usefully discussed at http://www.fda.gov/MedicalDevices/D...dicalDeviceQualitySystemsManual/ucm122391.htm. You can review the discussion there to verify that your classification of your business is correct.
As stated at that location, a repackager / relabeler is a Manufacturer and as such, must have a full QSR-compliant quality system.
If a Manufacturer utilizes a third party to conduct some or all of their manufacturing operations, that third party is a supplier. The Manufacturer must have systems in place to adequately control their supplier(s) so that the Manufacturer can demonstrate that the Manufacturer's product(s) comply with applicable regulations, etc.
CBAL08
I have a problem. A company has a distributor in US and all products are 510K cleared. Would it be possible to change the distributor to Kit assemblers who in addition would also perform the Service and maintenance activities of the complaint goods that are in the US market? What would be the regulatory implications for this kind of facility? Do they have to follow the Full QSR and be audited by FDA inspectors? Please help.
MIREGMGR
That's a business decision. The FDA's role doesn't include permission-giving for such changes to your business arrangements.
Of course, all of the participants in a medical device marketing channel must comply with the regulations that apply to their role.
Per http://www.fda.gov/MedicalDevices/D...urDevice/RegistrationandListing/ucm053165.htm, a kit packer must have a full quality system relative to their scope of activities, and is subject to FDA inspection.
W Need for current design or process control FMEA and Control Plans 2
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Relabeler for patent expired product - design control responsibilities? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Design Control - Ways of capturing inputs from manufacturing Other Medical Device Related Standards 5
M Medical Device Design Control Auditor Recommentations General Auditing Discussions 19
R Operator's manuals as prevention design control FMEA and Control Plans 2
S Design Control for Class I Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Defining Approvals Required for Design Control Documents ISO 13485:2016 - Medical Device Quality Management Systems 6
C Design Transfer - How do you guys control the design transfer process? Document Control Systems, Procedures, Forms and Templates 5
S Is Human Factor Testing required as part of Design Control Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
W Design Control Assistance required ISO 14971 - Medical Device Risk Management 7
V For a Drug-Device Combination Product, 'Design Control' Process is triggered at? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Design Control - Can Validation be based on a limited/first Production Run ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Design Control for Relabeling and Repackaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Dual ISO 9001 (Manufacturing) and ISO 13485 (Design Control) for same product line ISO 13485:2016 - Medical Device Quality Management Systems 3
J Incoming Inspection Plans under Design Control (part of DMR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Design & Documentation of Control Systems and Procedures Document Control Systems, Procedures, Forms and Templates 11
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
A Design Control Requirements: IDE exempt, NSR Device (Clinical Study) US Food and Drug Administration (FDA) 2
M Class II Medical Device Design Control Non Conformance 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
I Content to be included or excluded in Design Control Meeting Minutes ISO 13485:2016 - Medical Device Quality Management Systems 4
H ISO 9001 Document Control Requirements - Design and Development Department Checklists Document Control Systems, Procedures, Forms and Templates 3
M QSR - Design Control on Existing Device not Designed following QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H Medical Device Design Control Requirements (820.30) on Existing Products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Internal Design Control Audit ISO 13485:2016 - Medical Device Quality Management Systems 5
E Better control of DHR (Design History Record) during processing Document Control Systems, Procedures, Forms and Templates 5
D Class I and Class II Medical Device Accessory Design Control Requirements US Food and Drug Administration (FDA) 3
G Understanding Identification of Design in QSR 21 CRF Part 820.30 Design Control (f) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Tracking Log for IP during Design Control Process Document Control Systems, Procedures, Forms and Templates 1
K 7.3.7 Control of Design & Development Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Design Control - Parent Company is located in Australia 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S New Requirements for Design Control in AS9100 C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
W Design History Verification Records Control and Approvals US Food and Drug Administration (FDA) 3
B Design Control and Release Manual plus a Quality Manual Quality Manager and Management Related Issues 13
K Design Control SOP - Streamlining with R&D Department ISO 13485:2016 - Medical Device Quality Management Systems 6
A R&D Design Control - Ideas to Improve the Quality of Drawings Design and Development of Products and Processes 7
H Design Control Requirement - Initial Distributor of a Class I Video Laryngoscope US Food and Drug Administration (FDA) 4
M ISO 17025 and Design/Process Control Requirements ISO 17025 related Discussions 2
bobdoering Myth or Mythunderstanding: Implications of the Economic Design of Control Charts Statistical Analysis Tools, Techniques and SPC 1
C At what stage does Design Control play a role in Medical Device Development ISO 13485:2016 - Medical Device Quality Management Systems 2
B Suggestions on how to control a Design Dossier? Document Control Systems, Procedures, Forms and Templates 2
T Request for a Design Control Procedure or Process Flow for HVAC Design Document Control Systems, Procedures, Forms and Templates 1
A Design/Change Control Procedure - How to cope with Changes during Development? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 26
J What things go in Design Control Documentation for a 510k of Class II Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Design Control & Rapid Prototyping - Medical Device Software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Declaration of Conformity to Design Control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Declaration of Conformity to Design Control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
A QSR (820.30 part e) Design Review and Design Control Responsibilities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
