Design Control Issues - Toolroom says the system is too complicated
K
kapoor
#11
Design control format
Hi
I have gone through ur design data sheet. But i could not understand whether this sheet is used to review ur product design in case of any abnormality is observed on shop floor or its regular design review format.
Please let me know in details what problem ur facing and how actual user want to change the system. Being QMS professional our motive is to make user friendly system and a system which looks very good but not friendly to actual user.
If u send me more details and process flow for this system i will try to resolve ur problem.
Kapoor
David Hartman
#12
Fire Girl,
Perhaps I'm reading into your Tool makers concerns, but let me ask a few questions.
If I understand correctly your tool maker probably receives a request for a new tool (Through what media? - email, a paper doc, phone call, etc.). If that is true, then that is your record of the "initial design review" and input definition.
If the tool maker initiates further discussions with the requestor (once again via email, phone, etc.) then that is your design input review (obviously a record of the phone calls would have to be documented somehow), but some designs are going to be simplistic enough that a formal review is not necessary (and your process should state that).
Create design should be easy, if the tool maker has the design documented somewhere (which I would hope occurs, else all that info is lost and has to be regenerated every time). To meet the requirement all that is necessary is to ensure that the media used for documenting the design is somehow dated (maybe electronic timestamp for e-media).
Output review and verification are accomplished in a single step by the toolmaker looking at the design document and ensuring that he has captured what was required. For audit purposes how is this proven: Did he continue to manufacture the tool? (If yes, reveiw/verification were acceptable; If no, then he must have made changes to the document.)
Why would he have to add a step in each of these cases to document all of this activity on a separate document, other than for the ISO auditor's benefit? If there is no other reason, then your system should somehow recognize what is being done without that separate step. Your NOT in business to please the ISO auditor!
mitsu11
#14
In my last position, I had a similar "issue". He was an old school engineer who couldn't shake the thought that ISO was the flavor of the month. I couldn't convince him, but eventually I gave up. I realized that he was ALREADY doing all of the necessary steps; he just wasn't documenting them very well.
Instead of teaching this old dog a new trick, I used his current practice to show him what all of those ISO terms meant. "Inputs" are those details you write down in your ragged wire notebook while you are on the phone with a customer. "Outputs" (for our case) are the drawings, BOMs, and any instructions written when you are done (which could be identified as goals up-front). "Reviews" were done pretty much every day when this engineer and the production manager had lunch together. "Verification" was when he hobbled out to the production floor and checked to be sure that the assembler built it right. "Validation" was (for our case) when the customer called back and said Yea or Nay.
All of this could happen in a day, or 6 years, depending on the project. So, in order to harness the minor ISO stuff required, I gave him this attached (?) form to complete as a plan, which acted as a project folder cover page, too. He could pull out a folder, no matter what stage it was in, and identify important dates and information.
Of course, the critical part was the discussion.
Old school engineer = at least a year of discussions
Toolroom guy = Good bloody luck!
Z
ZeeMan
#15
Verification vs. Validation: My 2 Cents
Fire Girl said:
David
Can you guys give me your definition of the difference between verificaiton and validation? That seems to be a real bone of contention.
FG
Verification = Determining whether the design meets what the customer asked for (requirements).
Validation = Determining whether the design meets what the customer wanted (needs).
The difference resulting from performing these two actions is the stuff the customer forgot to / didn't know to ask for, most often from a user's perspective and not from a performance standpoint.
Howard Atkins
Forum Administrator
#16
The best example I have/use for the design control processes is baking a cake:
Plan - the recipe
Inputs - the ingredients
Outputs - the cake
Design review - checking the stages of the consistency etc.
Verification - added all the ingredients, oven and correct temperature.
Validation- eating -the real test.
W Need for current design or process control FMEA and Control Plans 2
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Relabeler for patent expired product - design control responsibilities? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Design Control - Ways of capturing inputs from manufacturing Other Medical Device Related Standards 5
M Medical Device Design Control Auditor Recommentations General Auditing Discussions 19
R Operator's manuals as prevention design control FMEA and Control Plans 2
S Design Control for Class I Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Defining Approvals Required for Design Control Documents ISO 13485:2016 - Medical Device Quality Management Systems 6
C Design Transfer - How do you guys control the design transfer process? Document Control Systems, Procedures, Forms and Templates 5
S Is Human Factor Testing required as part of Design Control Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
W Design Control Assistance required ISO 14971 - Medical Device Risk Management 7
V For a Drug-Device Combination Product, 'Design Control' Process is triggered at? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Design Control - Can Validation be based on a limited/first Production Run ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Design Control for Relabeling and Repackaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Dual ISO 9001 (Manufacturing) and ISO 13485 (Design Control) for same product line ISO 13485:2016 - Medical Device Quality Management Systems 3
J Incoming Inspection Plans under Design Control (part of DMR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Design & Documentation of Control Systems and Procedures Document Control Systems, Procedures, Forms and Templates 11
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
A Design Control Requirements: IDE exempt, NSR Device (Clinical Study) US Food and Drug Administration (FDA) 2
M Class II Medical Device Design Control Non Conformance 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
I Content to be included or excluded in Design Control Meeting Minutes ISO 13485:2016 - Medical Device Quality Management Systems 4
H ISO 9001 Document Control Requirements - Design and Development Department Checklists Document Control Systems, Procedures, Forms and Templates 3
M QSR - Design Control on Existing Device not Designed following QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H Medical Device Design Control Requirements (820.30) on Existing Products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Internal Design Control Audit ISO 13485:2016 - Medical Device Quality Management Systems 5
E Better control of DHR (Design History Record) during processing Document Control Systems, Procedures, Forms and Templates 5
D Class I and Class II Medical Device Accessory Design Control Requirements US Food and Drug Administration (FDA) 3
G Understanding Identification of Design in QSR 21 CRF Part 820.30 Design Control (f) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Tracking Log for IP during Design Control Process Document Control Systems, Procedures, Forms and Templates 1
K 7.3.7 Control of Design & Development Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Design Control - Parent Company is located in Australia 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S New Requirements for Design Control in AS9100 C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
W Design History Verification Records Control and Approvals US Food and Drug Administration (FDA) 3
B Design Control and Release Manual plus a Quality Manual Quality Manager and Management Related Issues 13
K Design Control SOP - Streamlining with R&D Department ISO 13485:2016 - Medical Device Quality Management Systems 6
A R&D Design Control - Ideas to Improve the Quality of Drawings Design and Development of Products and Processes 7
H Design Control Requirement - Initial Distributor of a Class I Video Laryngoscope US Food and Drug Administration (FDA) 4
M ISO 17025 and Design/Process Control Requirements ISO 17025 related Discussions 2
bobdoering Myth or Mythunderstanding: Implications of the Economic Design of Control Charts Statistical Analysis Tools, Techniques and SPC 1
C At what stage does Design Control play a role in Medical Device Development ISO 13485:2016 - Medical Device Quality Management Systems 2
B Suggestions on how to control a Design Dossier? Document Control Systems, Procedures, Forms and Templates 2
T Request for a Design Control Procedure or Process Flow for HVAC Design Document Control Systems, Procedures, Forms and Templates 1
A Design/Change Control Procedure - How to cope with Changes during Development? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 26
J What things go in Design Control Documentation for a 510k of Class II Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Design Control & Rapid Prototyping - Medical Device Software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Declaration of Conformity to Design Control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Declaration of Conformity to Design Control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
A QSR (820.30 part e) Design Review and Design Control Responsibilities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
