Design Control - Management of Electronic CAD files
McQueenster
We were recently audited to BS9001;2015 which identified a deficiency in our control of Electronic CAD files, including approvals. I've thought the best way to approach this is to create a stand-alone document which covers the specific implementation of CAD and how the workflows are implemented as well as where the design files are stored. The advantage of this is that if we move to another CAD package in the future then only one document is affected.
Does anyone have a sample document they can share that has been created to specifically control CAD design files to meet BS9001? The CAD software we are currently using is Altium.
McQueenster
What was the nonconformity?
The non conformity was that there wasn't sufficient controls in place to trace the checking and approval of designs. Altium provides workflow that can manage this at both a component and system design level. I am considering taking those workflows and formalising them in a CAD control document.
McQueenster
A separate procedure may ignore the controls already in your Altium software:
ISO 13485 Compliance: Tools for PCB Designers and Manufacturers
Asking Altium users how they demonstrate conformity may reveal how to deal more effectively with your auditor.
Thank you for the link. What I have found is that the Altium workflows are configurable and can be set up to meet internal business process. There are default Altium workflows which I may adopt, and document, for my 'company standard' to demonstrate control
John Broomfield
Being as Altium is part your system, and it includes documented workflows as part of your management system, this should be sufficient for effective planning, operation and control.
Or did your auditor cite evidence to the contrary?
Jean_B
To add nuance: sufficient if authenticity of the (electronic) approvals is guaranteed through validation. Which becomes "prove it (someone else authorizing as if they were an appropriate person) cannot reasonably be done, to the degree that unauthorized designs cannot or clearly should not be used".
McQueenster
Thank you for your reply. I have documented some of the auditor comments below
The auditor highlighted:
1. The choice of appropriate responsible person for checking and sign-off was not controlled as it was an informal arrangement
2. The approval/release process (workflow) was selectable by the Altium designer and therefore inconsistent rules being applied
3. Version control was not being applied to printable output meaning that the current schematic could not be identified from previous versions
4. CAD design schematic templates contained inconsistent information as each designer has a template preference.
These as all variables I think a CAD control document needs to capture.
Z Software for design control ISO 13485:2016 - Medical Device Quality Management Systems 5
W Need for current design or process control FMEA and Control Plans 2
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Relabeler for patent expired product - design control responsibilities? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Design Control - Ways of capturing inputs from manufacturing Other Medical Device Related Standards 5
M Medical Device Design Control Auditor Recommentations General Auditing Discussions 19
R Operator's manuals as prevention design control FMEA and Control Plans 2
S Design Control for Class I Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Defining Approvals Required for Design Control Documents ISO 13485:2016 - Medical Device Quality Management Systems 6
C Design Transfer - How do you guys control the design transfer process? Document Control Systems, Procedures, Forms and Templates 5
S Is Human Factor Testing required as part of Design Control Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
W Design Control Assistance required ISO 14971 - Medical Device Risk Management 7
V For a Drug-Device Combination Product, 'Design Control' Process is triggered at? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Design Control - Can Validation be based on a limited/first Production Run ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Design Control for Relabeling and Repackaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Dual ISO 9001 (Manufacturing) and ISO 13485 (Design Control) for same product line ISO 13485:2016 - Medical Device Quality Management Systems 3
J Incoming Inspection Plans under Design Control (part of DMR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Design & Documentation of Control Systems and Procedures Document Control Systems, Procedures, Forms and Templates 11
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
A Design Control Requirements: IDE exempt, NSR Device (Clinical Study) US Food and Drug Administration (FDA) 2
M Class II Medical Device Design Control Non Conformance 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
I Content to be included or excluded in Design Control Meeting Minutes ISO 13485:2016 - Medical Device Quality Management Systems 4
H ISO 9001 Document Control Requirements - Design and Development Department Checklists Document Control Systems, Procedures, Forms and Templates 3
M QSR - Design Control on Existing Device not Designed following QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H Medical Device Design Control Requirements (820.30) on Existing Products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Internal Design Control Audit ISO 13485:2016 - Medical Device Quality Management Systems 5
E Better control of DHR (Design History Record) during processing Document Control Systems, Procedures, Forms and Templates 5
D Class I and Class II Medical Device Accessory Design Control Requirements US Food and Drug Administration (FDA) 3
G Understanding Identification of Design in QSR 21 CRF Part 820.30 Design Control (f) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Tracking Log for IP during Design Control Process Document Control Systems, Procedures, Forms and Templates 1
K 7.3.7 Control of Design & Development Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Design Control - Parent Company is located in Australia 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S New Requirements for Design Control in AS9100 C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
W Design History Verification Records Control and Approvals US Food and Drug Administration (FDA) 3
B Design Control and Release Manual plus a Quality Manual Quality Manager and Management Related Issues 13
K Design Control SOP - Streamlining with R&D Department ISO 13485:2016 - Medical Device Quality Management Systems 6
A R&D Design Control - Ideas to Improve the Quality of Drawings Design and Development of Products and Processes 7
H Design Control Requirement - Initial Distributor of a Class I Video Laryngoscope US Food and Drug Administration (FDA) 4
M ISO 17025 and Design/Process Control Requirements ISO 17025 related Discussions 2
bobdoering Myth or Mythunderstanding: Implications of the Economic Design of Control Charts Statistical Analysis Tools, Techniques and SPC 1
C At what stage does Design Control play a role in Medical Device Development ISO 13485:2016 - Medical Device Quality Management Systems 2
B Suggestions on how to control a Design Dossier? Document Control Systems, Procedures, Forms and Templates 2
T Request for a Design Control Procedure or Process Flow for HVAC Design Document Control Systems, Procedures, Forms and Templates 1
A Design/Change Control Procedure - How to cope with Changes during Development? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 26
J What things go in Design Control Documentation for a 510k of Class II Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Design Control & Rapid Prototyping - Medical Device Software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Declaration of Conformity to Design Control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Declaration of Conformity to Design Control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
