Design Control - Ways of capturing inputs from manufacturing
Chef100
Hi all
In the design control process, I have seen different ways of capturing inputs from manufacturing. When I say inputs I am referring to e.g. an input from manufacturing regarding including a new specification on e.g. a drawing etc.
How do you guys capture this? I have seen models where this is included through the process risk assessment but I have also seen alternative models. How do you capture this in your systems?
Marcelo
Hi all
Hi, a "design control process" does not exist. What you have is a design process, then you would put "controls" in the design process (which is the regulatory name for specific records you need to make in certain stages of the design process).
In the case you mentioned, you usually do not capture design input requirements from manufacturing, because design input requirements must come from user needs (which are derived from voice of the costumer and other related sources). Manufacturing is usually involved on the design solutions (and related design output requirements), not design input requirements. This, in the case of a usual design process.
Chef100
Hi
I was not referring to "Design inputs". I am referring to "inputs" as a general thing. So yes, it would be inputs to "Design Outputs". But still, if the production think they need somehow a specification in order to better control the process, it could be that this particular specification isn't needed from a design perspective.
Some of cause does this as a specific "Design for manufacturing" exercise but not all does that. A parallel question could be if your records distinguish between "design specifications" and "process specifications".
Sidney Vianna
Post Responsibly
In my experience, most of the time, Manufacturing provides input during Design Reviews where manufacturability issues are discussed vis a vis the in-house and contracted manufacturing capabilities. Also during PFMEA, Manufacturing goes over potential production failure modes and ways of avoiding them.
Marcelo
Hi
Ah ok, sorry, my bad. This case you mentioned is usually captured by an engineering change request or engineering changing order. but from your comments, it seems that you want to identify processes where manufacturer can identify the inputs, right? These really depend on how you set-up your system. for example, the mentioned risk assessments are one way, but you would really need a feedback system for manufacturing info be reviewed, usually by triggers and if the defined triggers do not happen, by a time trigger. This is related (in particular in the medical device field) to post-market surveillance systems (see my post here, for example, when some of the the feedbacks I mentioned are
improvement of product quality and detection of manufacturing problems - http://www.medicaldevice.expert/uncategorized/creating-a-post-market-surveillance-pms-system-for-medical-devices-part-1/).
Ronen E
Problem Solver
Moderator
ISO 13485:2016, s. 7.3.3 Design and development inputs, says "These inputs shall include: ... e) other requirements essential for design of the product and process."
That's quite open-ended. IMO design inputs should come from all relevant stakeholders. It's the designer's onus to collect and include as many relevant inputs as practical, and personally, as a designer, I always target manufacturing at that stage because I'd hit it sooner or later anyway. Generally speaking, if something is important to the design it is better addressed as soon as practicable because as the design process progresses it becomes more difficult, complicated and costly to introduce changes, and if something is important we'll have to address it anyway.
In some organisations the first round of risk management indeed takes place in parallel with (or prior to) creating the first design input draft, and through this process some input from manufacturing is sometimes gathered, but typically at this early stage the net effect is additional/revised design input requirements.
Later on of course I would encourage manufacturing contribution through design reviews and even hands-on involvement in creating the design itself.
W Need for current design or process control FMEA and Control Plans 2
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Relabeler for patent expired product - design control responsibilities? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Medical Device Design Control Auditor Recommentations General Auditing Discussions 19
R Operator's manuals as prevention design control FMEA and Control Plans 2
S Design Control for Class I Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Defining Approvals Required for Design Control Documents ISO 13485:2016 - Medical Device Quality Management Systems 6
C Design Transfer - How do you guys control the design transfer process? Document Control Systems, Procedures, Forms and Templates 5
S Is Human Factor Testing required as part of Design Control Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
W Design Control Assistance required ISO 14971 - Medical Device Risk Management 7
V For a Drug-Device Combination Product, 'Design Control' Process is triggered at? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Design Control - Can Validation be based on a limited/first Production Run ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Design Control for Relabeling and Repackaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Dual ISO 9001 (Manufacturing) and ISO 13485 (Design Control) for same product line ISO 13485:2016 - Medical Device Quality Management Systems 3
J Incoming Inspection Plans under Design Control (part of DMR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Design & Documentation of Control Systems and Procedures Document Control Systems, Procedures, Forms and Templates 11
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
A Design Control Requirements: IDE exempt, NSR Device (Clinical Study) US Food and Drug Administration (FDA) 2
M Class II Medical Device Design Control Non Conformance 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
I Content to be included or excluded in Design Control Meeting Minutes ISO 13485:2016 - Medical Device Quality Management Systems 4
H ISO 9001 Document Control Requirements - Design and Development Department Checklists Document Control Systems, Procedures, Forms and Templates 3
M QSR - Design Control on Existing Device not Designed following QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H Medical Device Design Control Requirements (820.30) on Existing Products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Internal Design Control Audit ISO 13485:2016 - Medical Device Quality Management Systems 5
E Better control of DHR (Design History Record) during processing Document Control Systems, Procedures, Forms and Templates 5
D Class I and Class II Medical Device Accessory Design Control Requirements US Food and Drug Administration (FDA) 3
G Understanding Identification of Design in QSR 21 CRF Part 820.30 Design Control (f) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Tracking Log for IP during Design Control Process Document Control Systems, Procedures, Forms and Templates 1
K 7.3.7 Control of Design & Development Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Design Control - Parent Company is located in Australia 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S New Requirements for Design Control in AS9100 C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
W Design History Verification Records Control and Approvals US Food and Drug Administration (FDA) 3
B Design Control and Release Manual plus a Quality Manual Quality Manager and Management Related Issues 13
K Design Control SOP - Streamlining with R&D Department ISO 13485:2016 - Medical Device Quality Management Systems 6
A R&D Design Control - Ideas to Improve the Quality of Drawings Design and Development of Products and Processes 7
H Design Control Requirement - Initial Distributor of a Class I Video Laryngoscope US Food and Drug Administration (FDA) 4
M ISO 17025 and Design/Process Control Requirements ISO 17025 related Discussions 2
bobdoering Myth or Mythunderstanding: Implications of the Economic Design of Control Charts Statistical Analysis Tools, Techniques and SPC 1
C At what stage does Design Control play a role in Medical Device Development ISO 13485:2016 - Medical Device Quality Management Systems 2
B Suggestions on how to control a Design Dossier? Document Control Systems, Procedures, Forms and Templates 2
T Request for a Design Control Procedure or Process Flow for HVAC Design Document Control Systems, Procedures, Forms and Templates 1
A Design/Change Control Procedure - How to cope with Changes during Development? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 26
J What things go in Design Control Documentation for a 510k of Class II Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Design Control & Rapid Prototyping - Medical Device Software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Declaration of Conformity to Design Control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Declaration of Conformity to Design Control 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
A QSR (820.30 part e) Design Review and Design Control Responsibilities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
M Procedure for Control and Maintain of Records in each Design Stage 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
