Design & Development Clause 7.3, Applicable or not, What is rule?
#21
Dear Sidney Vianna
Agreed ! but i want slight differnt view, actually design applicablity can be judge by understanding actual application onsite , that is why iso certification process of Two stages in the first stage ( pre audit) one has to check .
What is your opinion about foundry/ melter where organization changes material composition they mixup material and make the different application and Customer are not aware about chemistry then what?
what design applicability ?.
Mixing materials to get different characteristics/chemistry isn't 'design'! This is not new material or changed material. The customer may not be aware of the chemistry but they do order a grade or specification, (in even basic terms) and the blending of raw materials to achieve that grade isn't considered to be 'design' - sorry!
V
vijaysonawane
#22
ISO 9001 clause 1.2
Where any requirement(s) of this International Standard cannot be applied due to the nature of an organization and its product, this can be considered for exclusion.
Where exclusions are made, claims of conformity to this International Standard are not acceptable unless these exclusions are limited to requirements within clause 7, and such exclusions do not affect the organizations ability, or responsibility, to provide product that meets customer and applicable statutory and regulatory requirements.
Refer above , if chemical or chemistry changes in its effect the final products application or requirements and final products performance got effected then claim of exclusion not is acceptable and organization is responsible for design
Look at pharm /medical : where whole RD is on the base Formulation , in change in chemical composition by PPM whole performace of final medicine got changed
Sorry!!!! design is creativity / innovation can be done :argue:
Sidney Vianna
Post Responsibly
#23
If a supplier changes the formulation/chemical composition/metallurgy of a product WITHOUT conferring with the customer, who has design authority, they should be penalized and subjected to criminal prosecution; not given design responsibility rights.
In some cultures, suppliers believe that they can adulterate products without customer formal consent. Not only that is unethical and possibly criminal, but exactly THE OPPOSITE of what ISO 9001 prescribes.
#24
ISO 9001 clause 1.2
I'm well aware of what the standard says regarding exclusions! I'd appreciate you not doing that! Your premise is fundamentally incorrect. You're wrong to suggest that 'creativity/innovation can be done. Here in the USA consumers have seen the effects of producers in other countries who are 'creative' and 'innovative' in changing fundamental characteristics - often to save money - with disastrous effects. As Sidney says, it's illegal, immoral and just plain wrong!
Your suggestions won't work in the Western world and if we are in a global economy, you will have to revise your thoughts about this topic, since the precedents have already been set! No more arguements, please!
Big Jim
#25
I think I see where you are coming from. Foundries check the composition of the melt before they pour. If the check shows that the material in the melt does not meet spec, they add ingredients as needed until it is in spec, checking as many times as needed. This activity would not be design as long as what they are doing is to make sure that they are meeting the customer requirement.
If, however, the foundry took it upon themselves to alter the formula just because they thought they could improve what the customer asked for, they have crossed the line in several ways. They may have moved into design. They have also viotlated their customer's trust to suppply what was specified.
V
vijaysonawane
#26
Thanks for healty discussion,
I involved to puts my view as open forum , I have total respects of your views and defintley I got some insight about discussion.
But discussion is going to wards othe way,forum is not use to blame hence i drop my self ....
Thanks to all
howste
Thaumaturge
#27
I've seen a copy of a registrar's confidential internal document (I've been asked to not disclose the name of the registrar) that has the exact interpretation that Big Jim has stated above. It states that if the organization gives input to customer design, even if they don't have the final authority, then they cannot exclude design from the scope of their system.
I don't believe that it's a correct interpretation. I think having design listed on such certificates would be misleading to customers of the organizations.
BTW, this is not a registrar that I audit for...
ABUHASHIM
#28
please explain what you mean by partial design.
If you mean that the organization has some authority to change the design without customer approval, then they must include 7.3 in their scope. If they have no authority to change the design, even if they provide advice to their customer, then 7.3 should be excluded.
Howste,
your reply is convincing to me, but can I claim a case for Painting Manufacturing company with R&D department, which involve in inventing new types of products ( new colors, or new types of paints for different usage), at this case, they have authority to change in the contents without refering to customers, but, they should not exceed the Legal specifications.
how do you thing such case should be? I mean including 7.3 or NOT
:thanks:
howste
Thaumaturge
#29
If you are designing different formulations of paint which are being sold as commercial off-the-shelf products, then I believe you must include 7.3.
ABUHASHIM
#30
I feel it should be excluded, as in any type of business, you can not go out beyond the limitation of specifications (legal.. local or International), and you have limitation of developments, or new invents in your products conditioning that you shouldn't deviate off these boundaries.
please, comments:D
O How can I justify excluding the R&D group and the design and development clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M IATF Clause 8.3 - Design and Development IATF 16949 - Automotive Quality Systems Standard 5
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
K Process Auditing Clause 7.3 Design and Development Internal Auditing 11
Y Clarification on ISO 9001 - Exclusion of Design and Development, Clause 7.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B The task of Auditing Clause 7.3 Design & Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Clause 7.3.7 Design and Development Changes - Requirements Scope? IATF 16949 - Automotive Quality Systems Standard 6
L ISO 9001 Clause 7.3.2 Design & Development Input - Adequacy, Complete, Unambiguous ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I Design and Development (Clause 7.3) - Do you think we are involved? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
R Different types of Design and Development - AS9100C Clause 7.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D ISO 9001 Clause 7.3 - Design & Development - Requirements help wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Advisory Services - Design and Development requirements per clause 7.3 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Design and Development, Support parts - Clause 7.3 Exclusion AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
W ISO 9001:2008 Clause 7.3 Design and Development Exclusions Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Guidance on ISO 9001 Clause 7.3 Design and Development Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R AS9100C Clause 7.3 Design & Development - Designing a System and Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Design & Development Input Records Requirements - ISO 9001 Clause 7.3.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J When to implement the Development and Design Clause 7.3? Design and Development of Products and Processes 18
W ISO 9001 Clause 7.3 Design and Development Sub-Clause Exclusions Design and Development of Products and Processes 14
D Do we need to include ISO 9001 Clause 7.3? Design and Development Exclusion Design and Development of Products and Processes 8
S Does ISO 9001 Clause 7.3 Design and Development apply? Design and Development of Products and Processes 18
M Manufacturing Process Design and Development Review - TS 16949 Clause 7.3.4 IATF 16949 - Automotive Quality Systems Standard 12
T Configuration Management For Design and Development (Clause 7.1.3) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
L Can this Contract Manufacturer exclude Clause 7.3? Design and Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Design and Development Clause - Prison Rehabilitation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Design and Development Clause for an Organization with R&D Facility Design and Development of Products and Processes 1
B Implement Clause 7.3 Design and Development procedure template example ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Traveler Map, Control Map, Request Map - Clause 7.3.3 Design and Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B How to implement Clause 7.3 - Design and Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I ISO 9001 Clause 7.3 Design and Development for Service Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 41
T Scaffolding Service - ISO 9001 Clause 7.3 Design and development process Design and Development of Products and Processes 3
P Specified stages of design and development shall be defined - TS 16949 clause 7.3.4.1 IATF 16949 - Automotive Quality Systems Standard 4
H Design and Development outputs - How Should I audit it? Clause 7.3.3 Design and Development of Products and Processes 7
Randy Clause 7.3 Design and Development - Verification and Validation Design and Development of Products and Processes 3
L Product Design and Development - How do I know if Clause 7.3 applies? Design and Development of Products and Processes 4
S Design and Development in a small Service Provider - ISO 9001 Clause 7.3 Design and Development of Products and Processes 7
A Design and Development Planning - AS9100B Clause 7.3.1 Design and Development of Products and Processes 2
M What is ?Design and Development? in Construction - Clause 7.3 ISO 9001 Design and Development of Products and Processes 16
K Can we Exclude Design and Development clause in ?Industrial Design? Company? Design and Development of Products and Processes 12
D Design and Development Measureables - ISO9001:2000 Clause 7.3 Design and Development of Products and Processes 5
R How to Comply with ISO 9001 Clause 7.3.1 Design and Development planning Design and Development of Products and Processes 2
C ISO 9001:2000 clause 7.3 Design & Development Exclusion - Collagen casing for sausage Design and Development of Products and Processes 19
R 7.3.2 Design and Development Inputs clause - What is the record needed? Design and Development of Products and Processes 17
J Can We Exclude ISO9000:2000 Clause 7.3.7 (Control Of Design And Development Changes)? Design and Development of Products and Processes 7
I ISO9001 Clause 7.3 include Design and Development of Processes Design and Development of Products and Processes 9
K Design & Development - Exclusion of Clause 7.3.6 - Design and Development Validation Design and Development of Products and Processes 6
E Design and Development Definitions - ISO 9001:2000 Clause 7.3 Design and Development of Products and Processes 10
A ISO 9000:2000 Clause 7.3 Design and Development Requirements Summary Design and Development of Products and Processes 23
