Design FMEA for a component - Should I make the following assumptions?
david316
When doing a design FMEA for a component should you make the following assumptions?
-The component meets its specifications (e.g. for a plastic part its meets the dimensions and tolerances specified on the drawing)
-The component is suitably designed to meet its intended function.
For example, assuming we are looking at a simple plastic component of a system, would it be appropriate to state something like below as a cause of a failure mode
-Dimension x tolerances are to wide
-Dimension x is to small
When doing a Design FMEA, you assume that the product will be manufactured exactly as designed. However, you may consider whether the dimension or the tolerance on the dimension was designed too small or too wide. For example, if a failure mode is bending or breaking, a potential cause might be that the dimension was designed too thin. Or, another failure mode might be the assembled dimension is too large, and the failure cause was the tolerance on a component was too wide allowing an assembly stackup too wide.
You may also consider whether the design will create manufacturability issues (e.g., mold draft is too shallow).
david316
Great. Thanks very much. That is helpful. Using your example, if we identified the design was to thin which would be a suitable risk control be:
-Design must be x thick
-Design must be of a thickness that will with stand a bend force of y over 100 cycles.
Chennaiite
Never-say-die
Suitable Risk control for "thin" design can be one or more of the following, in my imagination;
Preventive control :
Design calculation used to fix "thickness" specification, proven design in similar part/application, CAE analysis, "thickness" fixed based on technical Design Standard;
Detection Control :
Endurance testing, Load test or Any other tests to detect Bending or Breaking in the above example;
Chennaiite gave a very good response to your question. I'll just add a few more examples.
Preventative: Finite element analysis, Monte Carlo simulations, derating of components.
Detection: any type of physical testing, demonstration testing
david316
Actually, one other question because I am a little confused about how detection controls get used. Using the above example for a design FMEA, if I have one of the following
Detection Control :
Does this mean that during development I conduct this test to see if the current design bends/breaks and if it does I fix the problem? It is doesn't bend/break do I assume the design is adequate? I'm a little confused on how you use a detection control as part of a design FMEA.
Chennaiite
Never-say-die
Simple answer is - Yes.
Let me add some quick points for consideration :
If one or more of the Preventive controls can give you confidence in the design, it is your discretion to take a technical judgment to forgo physical testing. Example, Structural analysis can be performed in your PC using Finite Element Analysis tool. But correlation factor between the analysis tool and physical testing is the point of consideration;
Or If it is a proven design with minimal & insignificant Specification changes, may be physical testing is not required;
A Design FMEA, Process FMEA, Component FMEA --> FDA requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 18
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
P Design FMEA for Industrial Machinery FMEA and Control Plans 3
Marc Definition DFMEA (Design FMEA) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
D Do you need requirements for a Design FMEA FMEA and Control Plans 1
R Development of Design FMEA - Functional Requirements FMEA and Control Plans 1
K Determining Effect of Failure without a DFMEA (Design FMEA) FMEA and Control Plans 1
Moncia Design FMEA - Where to Start FMEA and Control Plans 20
T Would a Leak be a Failure Mode on a Design FMEA? Design and Development of Products and Processes 2
M Severity Reduction in a Design FMEA (DFMEA) FMEA and Control Plans 25
G How to identify Key Characteristics (KC) in a Design FMEA (DFMEA) FMEA and Control Plans 2
V Examples of Design and Process FMEA for Pharmaceutical Product Development ISO 14971 - Medical Device Risk Management 7
V Linking the FMEA Causes & Action Plan with DOE Experiments or Experimentation Design FMEA and Control Plans 1
C AIAG FMEA 4th Ed "Design Assumption" - I Need Examples FMEA and Control Plans 15
R DFMEA (Design FMEA) on Printed Circuit Boards (PCB's) FMEA and Control Plans 2
R Rear Axle Gear Group DFMEA (Design FMEA) - Example wanted FMEA and Control Plans 2
M ISO 14971 Risk Analysis and use of a DFMEA (Design FMEA) ISO 14971 - Medical Device Risk Management 8
A AIAG Design FMEA Severity Rankings - Noncompliance Government Regulation? FMEA and Control Plans 9
Chennaiite DFMEA (Design FMEA) at Vehicle Level - Some inputs needed. FMEA and Control Plans 4
V Biggest bottleneck/hurdle in Implementation of Effective Design FMEA FMEA and Control Plans 4
P Design FMEA (DFMEA) Basics - Help needed IATF 16949 - Automotive Quality Systems Standard 3
S DFMEA (Design FMEA) for a New Line Operation of the Underground Operation FMEA and Control Plans 10
T Electronic Assembly Design FMEA (DFMEA) FMEA and Control Plans 6
V In Design FMEA, how to give Occurrence Rating? FMEA and Control Plans 4
michellemmm Reverse Engineering a Design FMEA using aerospace DFMEA guidelines FMEA and Control Plans 2
M What are Comfort and Convenience Items on a Design FMEA FMEA and Control Plans 4
K Design FMEA Detection Scoring - FMEA 3rd edition manual FMEA and Control Plans 7
R Use of Design and Process FMEA tools - Kitchen Cabinets Manufacturing Quality Tools, Improvement and Analysis 6
O Bulk Material PPAP - Design Matrix instead of a normal Design, Production FMEA APQP and PPAP 3
T DFMEA (Design FMEA) - We already have a PFMEA (Process FMEA) FMEA and Control Plans 5
P Design FMEA (DFMEA) required on all products and their parts? Design and Development of Products and Processes 5
R Can a DFMEA (Design FMEA) effectively analyse design modifications? FMEA and Control Plans 12
C DFMEA (Design FMEA) and PFMEA (Process FMEA) - Who should lead? FMEA and Control Plans 14
A DFMEA (Design FMEA) - Occurance and Detection Ratings FMEA and Control Plans 2
B How to fill s/c and c/c in DFMEA (Design FMEA)? Design and Development of Products and Processes 3
S DFMEA - Is a Design FMEA required? FMEA and Control Plans 3
M DFMEA (Design FMEA) for Trailers or any heavy vehicle design Design and Development of Products and Processes 1
D Would Design & Process FMEA (PCBA) be sufficient to fulfill requirement of Cl 7.1? ISO 13485:2016 - Medical Device Quality Management Systems 2
N How to Calculate RPN in Design FMEA (DFMEA) vs. Process FMEA (PFMEA) FMEA and Control Plans 9
D Bulk Suppliers - Design FMEA Required? Aluminium ingots FMEA and Control Plans 10
M When to start a DFMEA (Design FMEA)? APQP and PPAP 2
K Could a good Design FMEA have prevented this? Death inside centrally locked car FMEA and Control Plans 6
B What is the meaning of the Occurrence in the DFMEA (Design FMEA)? FMEA and Control Plans 8
S FMEA Severity Rating - Will a Process Design Change also Change the Severity Rating? FMEA and Control Plans 21
R DFMEA (Design FMEA) - Document or Record? Document Control Systems, Procedures, Forms and Templates 3
S Do you have any information about Design FMEA? FMEA and Control Plans 1
W DFMEA (Design FMEA) for Bulk Material - Resin for Plastic Injection Moulding FMEA and Control Plans 1
K DFMEA (Design FMEA) - Plastic Injection Molding FMEA and Control Plans 2
