Design for Assembly in DFMEA - Failure Effect of Sub-System(s)
Cephissus
Hello all,
Another recurring problem that I am facing
For System A to work, it needs Sub-Systems A.1 and A.2 to be assembled together.
In general, a failure of Sub-System A.1 or Sub-System A.2 will lead to a failure of System A.
What happens when a Design failure of Sub-System A.1 will mean that it cannot be assembled to Sub-System A.2 ?? As such System A can't even exist and therefore the discussion about its functions and failures become irrelevant?
How would you describe the Failure Effect of Sub-System A.1 can't be assembled? And how would you rate it in terms of Severity?
From your description, you would focus on the severity of the impact to your assembly process. Not knowing your process, we cannot state a specific value. In some processes this severity would be minimal, while in others, it could be pretty severe, resulting in downtime due to the unavailability of parts. I highly doubt that it would be a 9 or 10 as that would mean a process safety issue.
If the PFMEA tables take the impact on your process into account, then yes. The usual tables are often very generic and externally focused.
GRP
If you are in the automotive industry, I would add to this the following passage from SAE J1739 related to DFMEA:
The effects of the failure mode should be considered against the next level up assembly, the final product, and the end customer when known. End customer effects should state what the user might notice or experience. They should clearly state if the effect of a failure mode could impact safety or non-compliance to regulations, when applicable. The intent is to forecast the failure effects consistent with the team's level of knowledge.
This means that in the effects column there should coexist effects at multiple levels. It is deemed a good practice to rank the severity of the failure mode as per the highest of the multiple effects associated to it. Also, for a proper severity ranking there should be a collaboration with the customer if possible.
What I find tricky with FMEAs sometimes is how failure modes, effects and causes can mix up depending on how you approach the issue. If you would like to share more of your case, in vague and general terms, we could try to develop it further.
GRP
Hello all,
As you say, if the design failure makes it impossible to constitute the product, then you have no function. I would address this as assembly not possible / no function, commonly an 8 in ranking tables, unless safety or govt regulations are involved.
T Electronic Assembly Design FMEA (DFMEA) FMEA and Control Plans 6
R DFA & DFM - Examples for Design for assembly and design for manufacturability Lean in Manufacturing and Service Industries 2
W Design and Development, and Assembly Process Quality Metrics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G Cell Design - Use DFMA (Design for Manufacture & Assembly) Analysis Lean in Manufacturing and Service Industries 2
G Recommend a good book on Assembly Line Design Manufacturing and Related Processes 4
michellemmm Hardware Design Standards - Printed Circuit Board Assembly EASA and JAA Aviation Standards and Requirements 2
I Anybody know about DFA (Design for Assembly) ? Design and Development of Products and Processes 1
P How to implement DFMA (Design for Manufacturing and Assembly)? Lean in Manufacturing and Service Industries 6
J DFA (Design for Assembly) & DFM (Design for Manufacturing) - Seeking Templates Document Control Systems, Procedures, Forms and Templates 4
F Applicability of 7.3 Design to Assembly Operations Design and Development of Products and Processes 2
C Seeking: FMEA Beginners Guide - PCB Design and Assembly Design and Development of Products and Processes 14
DuncanGibbons Section 8.3 relevant for design organisations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
R Is a FAIR required on parts that we design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
J Significant change related to design and intended use EU Medical Device Regulations 3
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
U NOC - What is considered a "design change" EU Medical Device Regulations 5
Q PPT used as Design Review ISO 13485:2016 - Medical Device Quality Management Systems 3
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
D Design controls - Inputs, outputs, V&V, DHF, DMR ISO 13485:2016 - Medical Device Quality Management Systems 10
LostLouie Manufacturer divorced from Design process, is he justified in design process deficiencies? ISO 13485:2016 - Medical Device Quality Management Systems 9
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 4
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
A Design History File - Not ready to share the design drawings or Bill of Material US Food and Drug Administration (FDA) 2
W Need for current design or process control FMEA and Control Plans 2
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Qualification and Validation (including 21 CFR Part 11) 5
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
A Sample Agreement available for Outsourcing Medical Device Design activity? ISO 13485:2016 - Medical Device Quality Management Systems 1
DuncanGibbons How is the arrangement between Design and Production organisation envisaged? EASA and JAA Aviation Standards and Requirements 4
L Design & Development of a SERVICE Service Industry Specific Topics 13
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A AS9102B - 3.6 Design Characteristics and form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
S MDR Delay - MDD design Change? (before new MDR DOA) EU Medical Device Regulations 8
J Iterative design and production for custom made products ISO 13485:2016 - Medical Device Quality Management Systems 3
T Design Input detail & specificity ISO 13485:2016 - Medical Device Quality Management Systems 4
J Design file for pre-existing products - Inputs and Outputs ISO 13485:2016 - Medical Device Quality Management Systems 5
