Design History File (DHF) for New Generation of Product
I work for a med device startup that is still in a development phase. The first generation product (GEN 1) has a well-laid out Design History File (DHF), maintained both in an index and a separate hard copy set of documents, but will not be developed further.
GEN 2 has some significant changes but is basically an evolution of GEN 1. I intend to only maintain an index as keeping a hard copy set seems a waste of time, although the auditors like it.
Should all the documents in the GEN 1 DHF be included in the GEN 2 DHF? There would then be 2 sets of customer requirements, product requirements, user requirements, software development plans, etc. If so, should I identify each document as being for GEN 1 or GEN 2, or both?
I took over this project from my predecessor and did not have input into the first DHF.
Thanks in advance for your help.
TWA - not the airline
First and foremost: What does your Design Control procedure require?
Can you handle this as a design change, i.e. indication/contraindication/user group and environment/performance requirements stay the same? If so, then you'd need to follow your design control/change control procedures and IMHO typically you'd keep the old DHF and just up-date the respective sections regarding design output and design verification&validation with either a new revision or a new doc valid only for GEN2.
If not then it probably would be considered a really new product and you'd develop it acc. to your design control procedure and typically you'd end up with a complete set of documents, where even the ones that have a copy&paste content would at least have to be reviewed again during design review. In that case I personally would not just reference to the doc of the GEN1 DHF...
Ronen E
Problem Solver
Moderator
I would simply reference GEN 1 DHF index (as a whole) in GEN 2 DHF.
Cheers,
Ronen.
O
Oscar Wang
Aye. do you think all DHFs of your GEN 1 are suitable for GEN2 including all descriptive informaiton in these DHF? If so, i suggest you follow a change control process but not a brand new NPI process.
A Design History File - Not ready to share the design drawings or Bill of Material US Food and Drug Administration (FDA) 2
R No design history file or device master record ISO 13485:2016 - Medical Device Quality Management Systems 5
R Suggestions for putting together a DHF (Design History File) ISO 13485:2016 - Medical Device Quality Management Systems 3
D Questions about the contents of a Design History File 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
E Updating DHF (Design History File) to include Alternative Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
V Template / format for Device History File & Design Verification of transdermal patch 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
JoCam Ownership of Design History File EU Medical Device Regulations 6
K ISO 13485 and DHF (Design History File) requirements ISO 13485:2016 - Medical Device Quality Management Systems 9
N 510k without DHF (Design History File) that we bought a 3 years ago US Food and Drug Administration (FDA) 4
A DHF (Design History File) for a Legacy Product (Class iii Medical Device) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
B When To Share Your DHF (Design History File) With A Customer US Food and Drug Administration (FDA) 1
S Cost Targets as Design Inputs in your DHF (Design History File) US Food and Drug Administration (FDA) 7
C Should Research Findings be in the Design History File? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
renenatasha Usage of web articles in DHF (Design History File) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
A Medical Device DHF (Design History File) - One per Design Change? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
L Creating DHF (Design History File) for Medical Device Systems Design and Development of Products and Processes 8
O ISO Standards For Intramedullary Pin Design History File Other Medical Device Related Standards 2
K How to start a Design History File (DHF) for Medical devices Company 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R Design History File DHF Practices and Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D Design History File (DHF) - Buy-For-Resell Products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
A Design History File Maintenance - Who is responsible for the Design History File 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M What are typical Roles & Responsibilities of DHF (Design History File) Librarian? US Food and Drug Administration (FDA) 6
H Paper based DHF (Design History File) updates for Software Updates 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Who should document the Design Review Meeting and Design History File? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
Q DMR-Device Master Record vs DHF-Design History File vs DHR-Device History Record 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 50
C Remediating a Design History File (DHF) for an IVD developed prior to 1997 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Design History File (DHF) Maintenance Information wanted 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
O DHF (Design History File) Template Other US Medical Device Regulations 13
C How to establish a Design History file (DHF)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
W Design History File (DHF) Template Example for Consideration. Design and Development of Products and Processes 12
S Which documents in the DHF (Design History File) should be controlled? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q DHF (Design History File) on New Medical Device Product ISO 13485:2016 - Medical Device Quality Management Systems 9
M Design History File - Medical Device Quality Systems Manual Section 3, Design Control Design and Development of Products and Processes 1
R Implementing Design History Documents/ Technical Documents in the QMS ISO 13485:2016 - Medical Device Quality Management Systems 3
N Design Validation Conventions for Design History Files 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Design history files for combination products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
W Maintaining Component Traceability in DHR (Design History Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Medical Device Service Records linked to DHR (Design History Record)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
E Better control of DHR (Design History Record) during processing Document Control Systems, Procedures, Forms and Templates 5
R Cloud Computing Requirements for Design History Files for Software Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M DHR (Design History Record) Requirements - Concessions Quality Manager and Management Related Issues 12
W Design History Verification Records Control and Approvals US Food and Drug Administration (FDA) 3
A Is a Distributor responsible for Design History Files 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
H Working from a previous design history. How can I best leverage the exisitng DHF? Other US Medical Device Regulations 4
DuncanGibbons Section 8.3 relevant for design organisations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
R Is a FAIR required on parts that we design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
