Design input/output traceability for mechanical parts
shimonv
Hi Fellows,
I'd like to hear your thoughts on linking design output to design input.
With software it's straight forward because the IEC 62304 is very clear about the requirement for traceability. Also, and usually, each code block is designed to meet a specific design requirement. The traceability matrix is one for one.
With hardware (especially mechanical components) it's different. Each design input is linked to multiple drawings and assemblies, and there is a lot of overlap (same set of part numbers could address multiple input requirements).
I've seen a bunch of approaches for handling linkage between mechanical components and design inputs.
It is a special challenge for small companies who do not have software tools for managing design QA.
What is your best practice?
Thanks,
Shimon
Ronen E
Problem Solver
Moderator
I believe that the concept of trying to trace back individual physical components to design inputs is wrong. There is no such regulatory requirement that I know of. Maybe it really is a result of the SW development mindset, which is becoming more and more prevalent in the last decade or two.
The actual requirement is that the whole of the Design Output (plural) satisfies the whole of the Design Input. It may, in some instances, be of value to trace certain Design Output subsets (e.g. a subset of drawings or maybe even a single drawing) to a certain Design Input requirement (or requirements subset), but I wouldn't obsess about it just for the sake of appearance.
somashekar
You would not get a better answer than the #2 above.
Ex: If the input for the design of a patient monitor cable says that it must be long enough to be able to reach the patient applied area from the monitor...... then the design output for the cable could be saying length = 12' (+/- 3")
This output comes from a lot of review and verification activities.
There could be other inputs about the cable coming from regulatory as well, leading to more design considerations.
If your company decides that the cable color will be blue, then the design output will indicate a certain pantone shade of blue for the cable, which will help the cable manufacturer to make and your inspection to check and pass..... and so on
shimonv
Thanks Ronen. That has been my thinking as well, but other companies are doing it and that creates a new "norm". I don't want to force R&D to do something that has little to no value.
Somashekar - the examples you gave are for externally visible specs.
Ronen & Somashekar: how will you handle a reviewer who comes and looks at the design input requirements and than asks for an evidence for a certain requirement that was implemented in internal mechanical sub-assembly?
I could argue that traceability in the h/w layer is not explicitly required (not very strong argument nowadays) and/or point to the master V&V plan having made sure that it traces tests to a specific requirement.
Is there anything else that can be done?
Shimon
somashekar
Hi Shimonv.
I still prefer examples to say rather than detail.
If the design input requirement is that the emissions of the vehicle must meet BS IV standards, tats it.
What other design and developments are made, modified or otherwise invented is not listed into the design input requirements.
Your approved tests of the vehicle emissions proving that the BS IV standards norms are met or exceeded is the design output proof (meeting input requirements) and what engine you have finally built (Its design specifications, Bill of materials, Drawings, etc etc ...) are the design outputs meeting input requirements.
I guess you are making a very exhaustive list calling it input requirements, which is not the intent of the design and development process.
shimonv
Thanks. The design input is not very exhaustive.
Let's take for example infusion pump. The design input requires to have the ability to detect occlusion in the administration set. This requirement is implemented the development of a flow control sensors. So, you would present the bench test report for occlusion detection and say - "see, I meet the input requirement" without actually pointing out to the electro-mechanical sub-assembly which is the actual design output.
I am with you, but I can see some auditors arguing to the contrary.
somashekar
Just reversing the order for a reviewer response... (I assume you are referring to the external reviewer in a audit situation)
If the question is "How do you meet the requirement of occlusion detection ?
Then...
"We have a flow control sensor sub-assembly which is able to detect blockage or closing in the administration set thereby triggering the stopping of the infusion." (design consideration)
The bench test report for occlusion detection is the verification / validation report of the same.
I can't see a case of argument...
Ronen E
Problem Solver
Moderator
This is called "regulatory creep" and we must all resist it if we want reason to rule.
This is rather easy if Design Control is implemented while keeping in mind the rationales and intentions behind it. When Design Verification is planned and executed, it should follow the Design Input requirements. I usually make a note at the top of each verification item/activity, which Design Input requirement is being verified. If this is followed all the way through to the summary report, it becomes easy - you take the requirement ID from the Design Input (any that a reviewer is interested in) and you look for it in the Design Verification summary report. If you have many requirements you can create a table/matrix/index that lists the Design Input requirements' IDs and the Design Verification sections that address each; however, this is not even necessary if the document is searchable.
Ronen E
Problem Solver
Moderator
Then...
I fully agree, and would like to add: The risk management file is a good place to capture such considerations.
D Design Input/Output and Design V&V (Verification and Validation) Interpretations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
M Design Input & Output in Stages - Overkill? ISO 13485:2016 - Medical Device Quality Management Systems 16
sagai Are some Design Input elements part of the Design Output? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R Design Input/Output Form - Your feedback appreciated ISO 13485:2016 - Medical Device Quality Management Systems 3
T Design Input vs. Design Output - What constitutes Design Input? Design and Development of Products and Processes 11
L Looking for ISO 13485 Design Input and Output Files - Templates/Examples Design and Development of Products and Processes 2
S Design Input and Output Documents - Seeking specific examples - Medical Devices Design and Development of Products and Processes 7
T Design Input detail & specificity ISO 13485:2016 - Medical Device Quality Management Systems 4
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
S Referencing International Standards as Design Input Design and Development of Products and Processes 5
D Any Product Design Input sample for Colonoscope devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q When is a Design Input Good Enough? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Are Software Requirements Specifications part of Design Input? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Implementation of Design Input Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L ISO 9001 Clause 7.3.2 Design & Development Input - Adequacy, Complete, Unambiguous ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Formal Way for Documenting Design Input Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Revise or to Not Design Input Document for On-Market Cleared Class II Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Design & Development Input Records Requirements - ISO 9001 Clause 7.3.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Looking for input on the design/syllabus of a 2-day AS9100 Transition Course AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
W What is "Design Input" by QSR, 21 CFR Part 820 ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
J Preparation of Documents defining Design Input ISO 13485:2016 - Medical Device Quality Management Systems 10
GStough Risk Management Has to Begin Prior to Design Input, But... Design and Development of Products and Processes 10
P Design Input Proposal and Design Control Checklist Formats wanted ISO 13485:2016 - Medical Device Quality Management Systems 1
R Product Design Input as per TS 16949 clause 7.3.2.1 Design and Development of Products and Processes 9
D Design Input - Question on Specific Performance Criteria for Medical Devices Design and Development of Products and Processes 3
S Design Input class 3 device Design and Development of Products and Processes 5
K Design Input document example format/template needed Design and Development of Products and Processes 12
C Home made gage examples - Input to design new home made gages General Measurement Device and Calibration Topics 9
R Checklist for Design Input items for Medical Devices wanted Design and Development of Products and Processes 4
A Manufacturing process design input vs Design information checklist Design and Development of Products and Processes 1
M Design Input - 820.30(c) - Addressing incomplete, ambiguous... requirements Design and Development of Products and Processes 1
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
J Significant change related to design and intended use EU Medical Device Regulations 2
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
U NOC - What is considered a "design change" EU Medical Device Regulations 5
Q PPT used as Design Review ISO 13485:2016 - Medical Device Quality Management Systems 3
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
D Design controls - Inputs, outputs, V&V, DHF, DMR ISO 13485:2016 - Medical Device Quality Management Systems 10
LostLouie Manufacturer divorced from Design process, is he justified in design process deficiencies? ISO 13485:2016 - Medical Device Quality Management Systems 9
R DFA & DFM - Examples for Design for assembly and design for manufacturability Lean in Manufacturing and Service Industries 2
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 4
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
A Design History File - Not ready to share the design drawings or Bill of Material US Food and Drug Administration (FDA) 2
W Need for current design or process control FMEA and Control Plans 2
