Design of Experiments Using Subgroup Data - Conducting a 2^3 factorial DoE
Re: Design of Experiments Using Subgroup Data
Do you mean that for each experimental run, you are collecting multiple measurements?
If this is the case, this "subgroup" would consist of experimental repeats. Repeats are multiple measurements taken during a single setup of an experimental run. (If the experimental conditions are changed then at a later time are recreated as a new setup, this is called a replicate).
As a general practice, replicates are better than repeats because you are more likely to be able to duplicate experimental results from replicated experiments.
With repeats, the typical method is to calculate the mean and standard deviation of each subgroup. Perform the analysis on the mean to determine the usual information on main effects and interactions. Calculate the log of each standard deviation, then perform a similar analysis on the log(StDev). Look for factors that will significantly reduce the log(StDev) in order to minimize variation.
This is even more effective when used with an outer array that deliberately induces variation into the repeats.
QCMGR
I was thinking more on the order of something like shooting a target 10 times per run. I.e.,
2^3 with 10 shots per run.
Those are repeats.
If you took one shot per run, then changed the setup to another random run then back to the original run for another shot and did the same another 8 times you would have 10 replicates.
The distinction is extremely important because replicates contain more variation than repeats. If factors are significant across repeats, but not across replicates you will not be able to consistently reproduce the results of your experiment.
QCMGR
I don't think I can do that. My thought was to shoot a 10 round group, calculate the mean radius, record values for shot 1-10 and mean radius. The problem is I need to capture the effects on the rifle system over 10 shots.
Are you literally talking about shooting a rifle?
Is your objective to reduce the spread of the 10-shot pattern? If that is the case, then you do want to run repeats, then analyze using a measure of the spread such as the minimum circumscribed diameter of the pattern.
If you can run replicates of the 10-shot patterns, I would recommend doing so.
K Experiments Using Full Factorial Design Using Minitab Software 12
B Taguchi DOE (Design of Experiments) example using Minitab Using Minitab Software 3
P Taguchi method using Minitab - DOE (Design of Experiments) Help Quality Tools, Improvement and Analysis 7
C Design of Experiments or Factor analysis using existing data Quality Tools, Improvement and Analysis 7
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Reliability Analysis - Predictions, Testing and Standards 0
M Data analysis Design of Experiments Using Minitab Software 3
J DoE (Design of Experiments) - Multiple responses with different factors Using Minitab Software 2
K Power point training slides on DOE (Design of Experiments) Wanted Training - Internal, External, Online and Distance Learning 2
M Design of Experiments - Paper Helicopter Example Using Minitab Software 1
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
N DOE (design of experiments) in Minitab 16 Using Minitab Software 6
P When can we apply DOE (Design of Experiments)? Six Sigma 8
P Cyclic Effect Factoring in DOE (Design of Experiments) Quality Tools, Improvement and Analysis 1
J How to Estimate the Number of Replicates on a DOE (Design of Experiments) Six Sigma 5
K Minitab Lack-of-Fit Test in DOE (Design of Experiments) Using Minitab Software 4
AnaMariaVR2 Design of Experiments in a Cooking Show Coffee Break and Water Cooler Discussions 0
M Taguchi L4 Orthogonal Array Design of Experiments (DOE) in an Excel spreadsheet Excel .xls Spreadsheet Templates and Tools 3
V Linking the FMEA Causes & Action Plan with DOE Experiments or Experimentation Design FMEA and Control Plans 1
C Design of Experiments to Reduce Variation in a Lathe Operation Quality Assurance and Compliance Software Tools and Solutions 9
C 3 Factor DOE (Design of Experiments) Template Document Control Systems, Procedures, Forms and Templates 0
L DOE (Design of Experiments) suggestions Using Minitab Software 7
L DOE (Design of Experiments) - Analyse Variation with Minitab Using Minitab Software 5
E 5^2 DOE (Design of Experiments) with 3 Replications, 5 Levels 2 Factors Statistical Analysis Tools, Techniques and SPC 6
M DOE (Design of Experiments) for 3 Variables, Many Levels Quality Tools, Improvement and Analysis 2
J DOE (Design of Experiments) Dependent Factors Using Minitab Software 1
C DOE (Design of Experiments) with 'Uncontrollable' Factors Using Minitab Software 5
Q DOE (Design of Experiments) for Accounting - New to Minitab need help Using Minitab Software 5
Q Design of Experiments - What tool to use? Using Minitab Software 7
M DOE (Design of Experiments) - CQE Primer question Professional Certifications and Degrees 4
C Training courses for DOE (Design of Experiments) Training - Internal, External, Online and Distance Learning 3
D Design of Experiments (5 factors with 3 levels) - How to proceed with Minitab? Using Minitab Software 41
S Sample Size Attribute DOE (Design of Experiments) Six Sigma 9
M Excel files for DOE (Design of Experiments) Excel .xls Spreadsheet Templates and Tools 6
T Minitab - Mixture DOE (Design of Experiments) - Sandability of a Gelcoat Using Minitab Software 5
R Custom DOE (Design of Experiments) Analysis in JMP Quality Tools, Improvement and Analysis 11
P Need help on DOE (Design of Experiments) - EPS molding process Quality Assurance and Compliance Software Tools and Solutions 2
A Good books on DOE (Design of Experiments) - Recommendations wanted Book, Video, Blog and Web Site Reviews and Recommendations 3
T Design of Experiments - DOE with Centre Point Using Minitab Software 7
T Screening DOE (Design of Experiments) with qualitative response Quality Tools, Improvement and Analysis 23
A The basics of DOE (Design of Experiments) & Validation Statistical Analysis Tools, Techniques and SPC 4
D Critical quality characteristics on a heat seal machine - Design of Experiments help Quality Tools, Improvement and Analysis 20
M Design of Experiments (DOE) - Help with homework problem Quality Tools, Improvement and Analysis 5
A Any good reference books for Design of Experiments? Quality Tools, Improvement and Analysis 9
M DOE (Design of Experiments) with 3 factors with levels of 3,3 and 5 Quality Tools, Improvement and Analysis 3
P What if DOE (Design of Experiments) is not possible? Six Sigma 16
J DOE (Design of Experiments) for ultrasonically welding plastic lids Quality Tools, Improvement and Analysis 15
C Shainin and DOE (Design of Experiments) Information Misc. Quality Assurance and Business Systems Related Topics 2
A DOE - Design of Experiments? What does that mean? Quality Tools, Improvement and Analysis 5
S Design of Experiments - Details of Shainin technique and a training source - India Quality Tools, Improvement and Analysis 5
P DOE (Design of Experiments) or Hypothesis test? Applicability and use of each? Six Sigma 6
