Design Philosophy - Iran Medical Device Registration
G
gathagmador
Hello All,
I am completing a device registration for Iran and am stuck on one element the "Design Philosophy" The description of this in the registration info seems to be all over the place. Does anyone have an example of what this should look like they would kindly pass along?
L
LFZR88
Re: "Design Philosophy" - Iran Medical Device Registration
Hi
I don't have any specific experience on this but I assume... ;) that they have taken this from the Canadian registrations which reads
(3)4.4 Design Philosophy
The features that enable the device to be used for the medical conditions and purposes for which it is manufactured, sold or represented by the manufacturer should be described. A brief description of the underlying science/technology, design concepts, and/or theoretical principles supporting the device's function should be provided, linking them to the claimed indications for use. References and comparisons with appropriate previous versions or generations of the device can be presented with reference to the previous version's Canadian medical device licence number. A tabular format is preferred for comparisons.
I don't know if this helps.... good luck
tibon74
Hi !! could I have some details on the Iran regulation ?
Should we appoint a local representative? who is the license owner ? how much time it takes to approve a product? is there a renewal process ? if so, when ?
thank you !
L
LFZR88
Hi All,
we have just found this application document for Iran with guidance notes, it contains info about the design philosophy that was asked back in August and other useful guidance.
Design Philosophy :
This section requests a description of the features that enable the device to be used for the medical conditions and purposes for which it is manufactured, sold or represented by the manufacturer. To satisfy this requirement, a brief description of the design philosophy and performance specifications for the device should be provided, linking them to the claimed indications for use. References and comparisons with appropriate previous versions or generations of the device should be presented. A tabular format is preferred for this comparison.
In the event that the use of the device is self-evident to the intended user, the customary or most frequent conditions or uses of the device should be summarized. This section should include an overview of the purposes and principles of operation for the device and a summary of the method of its use and operation, unless these instructions are not required for the
safe, effective use of the device. Details on the strength of materials and the accuracy, sensitivity and specificity of the device should also be supplied.
The physical aspects of the device, including packaging, operational capabilities and the processing of inputs and the resultant outputs, must be provided. This should include a summary comparison of the design input parameters (operation specifications) with the resultant performance specifications (design output characteristics).
hope this helps
Liz
  • Application Form +guidance for completion.pdf
P
primate
Dear all,
I have a query regarding registration of medical devoces in Iran.
The local representative : Does the local distributor become a sole distributor in Iran for the exporting company?
If yes, does the local authorised representative become for distributor product by product, or for the whole company?
If yes, for how long?
Thank you,
Best regards,
Primate
T Design and Development training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Nawal Design Review Requirments Manufacturing and Related Processes 3
R ANOVA MSA GR&R in ATE replacing operators (Error Design is not balanced) Using Minitab Software 4
G What is Design&Development and what is product in a Research company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
adztesla Design change and Process change Class 3 medical device Medical Device and FDA Regulations and Standards News 2
R ISO 13485:2016 DESIGN TRANSFER Forum News and General Information 0
adztesla Adding new supplier/ Medical device design change ISO 13485:2016 - Medical Device Quality Management Systems 2
T Clinical Study Design for IVD Self-Test (lay user) Products UK Medical Device Regulations 0
T Design of Experiment - Test for Curvature Quality Tools, Improvement and Analysis 4
I Design Verification Testing on Non-Validated Equipment ISO 13485:2016 - Medical Device Quality Management Systems 2
Z Design verification test sample size under the scope of first in human study submission in Europe Medical Device and FDA Regulations and Standards News 3
T Mandatory requirements for design verification sample 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
T Class B IEC 62304 - 5.4 Software Detailed Design IEC 62304 - Medical Device Software Life Cycle Processes 4
L Design Transfer Concept of cloud SaMD US Medical Device Regulations 2
M IVD Device Design Change Medical Device and FDA Regulations and Standards News 2
S Design and Development document ISO 13485:2016 - Medical Device Quality Management Systems 2
M Risk-based approach to Test Method Validation for Design Verification? US Medical Device Regulations 5
S Is design and development clause 8.3 applicable for laboratory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Design: Verification Vs Validation And Validation Vs Transfer ISO 13485:2016 - Medical Device Quality Management Systems 19
L To control the essential design outputs Medical Device and FDA Regulations and Standards News 4
C MD Design and development procedure ISO 13485:2016 - Medical Device Quality Management Systems 1
B Validation of design for valve api 6d 25 edition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
B Hi , everyone i need a procedure for validation of design prototype api 6d (valve manufacturing) Oil and Gas Industry Standards and Regulations 1
K Exclusion of 8.3 Design and Development for Design Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Recognised/reputable courses for ISO 13485 Section 7.3 (Design & Development)? ISO 13485:2016 - Medical Device Quality Management Systems 1
J Design/Development. Oil and Gas Industry Standards and Regulations 6
O Regarding design and development requirements for a medical device EU Medical Device Regulations 6
W Rights of Supplier in Design & Build WP Manufacturing and Related Processes 0
K ISO 13485 Design Requirement with respect to "component" manufacturers ISO 13485:2016 - Medical Device Quality Management Systems 11
rob3027 ISO 13485 justification for design and development exclusion for medical packaging ISO 13485:2016 - Medical Device Quality Management Systems 18
K What constitutes design under 9001? Design and Development of Products and Processes 15
P Product Requirements Control during Design Changes Design and Development of Products and Processes 4
B Minitab factorial design regression equation center point term Manufacturing and Related Processes 5
J Design Input Verification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P Self Certified Class 1 MDR 2017/745 Design Change CE Marking (Conformité Européene) / CB Scheme 2
N Design V&V courses Career and Occupation Discussions 11
B AS9100 Design Authority questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Process FMEA responsible For "Make to Design Parts" (Inhouse or Suppliers ?) FMEA and Control Plans 3
K CE design Certificate EU Medical Device Regulations 3
M ISO 13485 consultants and auditors with design oriented focus ISO 13485:2016 - Medical Device Quality Management Systems 7
T Design Transfer & use of "prototype" components in production devices. ISO 13485:2016 - Medical Device Quality Management Systems 10
Q What are Quality Requirements for Design? Quality Management System (QMS) Manuals 8
G Mfr. Process Validation BEFORE Design Transfer? Other Medical Device and Orthopedic Related Topics 1
B Use of Statistical Techniques in Design Verification Design and Development of Products and Processes 18
X Design stage overview (Product specification) EU Medical Device Regulations 3
gohyl Fixture Setup Design Manufacturing and Related Processes 3
D IS0 13485 - Design perspective to regulatory requirement. ISO 13485:2016 - Medical Device Quality Management Systems 3
T Software item classification and Detailed Design IEC 62304 - Medical Device Software Life Cycle Processes 4
armani 7.1.5 and design and development of product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Sidney Vianna ISO 9001 News ISO 9001 Design Specification to be developed - May 2022 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
