Design process goal for ISO 9001
#11
OK the question now is...Did you require KPI's with goals and a review? If you did, then shame on you (self inflicted), if you didn't then shame on him (making crap up).
I did not require those, so I am relieved to say its shame on him. He has his mindset and preferences on certain subjects, I was just hoping this was another one where he was misspeaking about a goal for a process so I am able to converse this with him and can hopefully get both of us on the same page.
John Broomfield
#12
Not sure what you or your auditor mean by design goals but here a suggested objective for your design process:
1. To translate customer needs into specified requirements for our services and products.
2. Verified by customer approval of the design inputs (description of customer needs) and of the resulting specifications per the design plan.
Best to engage the design team in describing their actual objectives. They may want to add a time-based element.
normzone
#13
This may be an entirely separate issue, so pardon if I go astray here, but this reminds me of a nonconformance I dealt with recently where the Quality Objectives had no stated target level, and some of the "Quality Objectives" did not pass the quantifiable test.
You can assign a target level to the former, but the latter means while it may be a good idea, it's ineligible to be a Quality Objective.
Randy
#14
Nothing says objectives have to be quantifiable, they only have to be "measurable", objectives may also be "qualifiable"
normzone
#15
Thanks [Randy] ... that's a good point. I've always sought measurements I could quantify, but you are correct that it is not the requirement.
In the instance I referred to above, we had no clear method of measurement.
"Never" would be good, "some" or "lots" was bad, and "many" was worse though. But the nonconformance was for not meeting 9001:2015 - 6.2.1 & 6.2.2
Randy
#16
Was it involving the word "relevant"? If so, it's your decision as to what's relevant for monitoring & measuring improvement (which is all that objectives do, define what you deem to be necessary to improve, provide a starting point and an end point and includes all the happy stuff in between the two).
I know there's more to it than this, but I struggle not to choke fellow auditors that make garbage up, don't really know what they are doing and continually complicate something that is intended for a mom & pop, 10 employee business with 2-3 customers to easily and effectively do.
(The whizzo-bango experts, pip pip proper people are gonna kill me with the next bit)
Oh yes, oh yes I know, big multi-thousand employee, multi billion $ companies are different.....Really? Large or small organizations have the same problems, needs, expectations, and everything else, just to varying degrees and they are....Managing cash flow while meeting expectations to a point that what comes in outweighs what goes out....It's all the same! Objectives are just goals or self defined expectations that YOU determine are necessary to improve areas that you've identified as either weak or identified as necessary to go to the next level (whatever that level is). In this case if you ain't got no problem in design (and the beans are coming out of the pot well cooked), your customers are happy campers, you're jumping thru every little hoop there is (and you're making $$$ to boot) what are supposed to improve upon?
Am I reading this whole thing wrong?
AMIT BALLAL
#17
His words from the audit report, out of section 4.4.1c.
Evidence: "No KPI's with goals for review." I did have KPI's, but not enough to help with the goal review apparently.
Was the auditor referring to "Effectiveness" measures for the design process (to check whether required output of the process is achieved)?
Please specify the KPIs you had shown to the auditor.
#18
I agree with what youre saying. I think its safe to say we know what is relevant to our process that makes our customers happy and keep them coming back. Maybe it seems in his eyes we should be jumping through more hoops, but what he is too stubborn to see is we are meeting and exceeding our customers expectations with our design process. I agree with how do we improve on this thing thats working well, dont fix what aint broke.
normzone
#19
You are not reading it wrong ... but you are perhaps a bit optimistic (I'll bet you don't hear THAT often ;-)
The challenge is that customers are sometimes less than fully satisfied. Evidence of this is in Management Review minutes, and efforts to address those challenges can be ... inconsistent.
#20
I have started the ISO 9001 quality system for a metal fabrication job shop company and in our Stage 1 audit he pointed out we don't have a good goal set for design and measurables for that goal. We rarely do design, but its enough to not be exempt from it. Most of our design is recreating prints or models from customers to fit our system. Maybe 5-10 times a year do we actually start a design from scratch for a customer. So my question is how do I set a goal for something we rarely do? How can we measure something efficiently/easily that we rarely or barely do? Would there be an easy way to track our small design projects like I mentioned earlier by time or something, and if so how would we create a goal off of that?
Anything helps,
Hi Austin, Demonstrate that you have control over the design process.
Something in place that ensures you deliver what the customer has agreed with you upon. Tell the auditor thats your goal and you measure it with forms.
The simplest way if your starting from scratch is to create three forms. The first a "customer specifications" form or whatever you want to call it. Use it to capture the dimensions or specifications the customer wants, it can be a questionnaire or anything you like. Its a place to capture all the customers requirements. The second form would be a tracking form, something that tracks how many times you have sent them a draft and the draft number. Making sure you name it something different each time you send a new revision or draft to the customer. The third form is the approval form. The customer references the draft they would like made for them. Thats your design control. It doesn't have to be complicated for it to be effective.
It facilitates the goal of ensuring you deliver what the customer expects and has agreed with you upon.
It negates risk of rework, costs, time and damaged customer perception.
You measure whether its effective based on returns/customer satisfaction and whether the three forms exist with every new draft made. The forms will become a system that serves you.
Just write a 1 page SOP titled Design Control to fomalise it all and thats the simpliest way I would do it.
LostLouie Manufacturer divorced from Design process, is he justified in design process deficiencies? ISO 13485:2016 - Medical Device Quality Management Systems 9
W Need for current design or process control FMEA and Control Plans 2
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
B Supplier of design and manufacture process ISO 13485:2016 - Medical Device Quality Management Systems 10
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
C Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
C IATF 16949 8.3 Exclusion - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 5
C Design Transfer - How do you guys control the design transfer process? Document Control Systems, Procedures, Forms and Templates 5
W Design and Process Validation - Different? ISO 13485:2016 - Medical Device Quality Management Systems 6
H Measuring Design Process Design and Development of Products and Processes 4
B Outsourcing process design (8.3.3) IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Cl. 8.3 - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 - Cl. 8.3.3 - Product design inputs, manufacturing process design inputs IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
V For a Drug-Device Combination Product, 'Design Control' Process is triggered at? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
Q ISO 9001:2015 - Design of Process vs. Design of Service Service Industry Specific Topics 4
T TS16949 Process Design Requirements IATF 16949 - Automotive Quality Systems Standard 2
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
N What does an effective design process look like? (shoots flare in the air) Design and Development of Products and Processes 2
O Design and Development Process - Does one size fit all? ISO 13485:2016 - Medical Device Quality Management Systems 13
L Medical Device New Product Design & Development- How long does this process take you? Other Medical Device and Orthopedic Related Topics 1
D ISO 9001 Design Process Flow Chart ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G ISO 14001 & Product Design Process Environmental Aspect Review Requirements ISO 14001:2015 Specific Discussions 7
W Design and Development, and Assembly Process Quality Metrics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Audit Design Process every Surveillance Audit - AS9104 Requirement? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
H How to make the Design Review Process Effective Design and Development of Products and Processes 1
R Process Development Requirements for a Contract Manufacturer with no Design Design and Development of Products and Processes 5
V Examples of Design and Process FMEA for Pharmaceutical Product Development ISO 14971 - Medical Device Risk Management 7
Chennaiite How to Measure Effectiveness of the Design Validation Process? Design and Development of Products and Processes 7
K Process Auditing Clause 7.3 Design and Development Internal Auditing 11
V The best practice to maintain & link Design and Process FMEAs FMEA and Control Plans 8
A ISO/TS 16949 - 7.3.3.2 Manufacturing Process Design Output IATF 16949 - Automotive Quality Systems Standard 6
AnaMariaVR2 Pharma ?Quality by Design? (QbD): An Introduction, Process Development & Applications Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Q Tracking Log for IP during Design Control Process Document Control Systems, Procedures, Forms and Templates 1
B 7.3.1 Design & Development Planning related to Process Design IATF 16949 - Automotive Quality Systems Standard 4
T How to link Process Design Changes in Serial Production to Design & Development? Design and Development of Products and Processes 6
D AS9100C PEAR (Process Effectiveness Assessment Report) for Design and Development AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M ISO 17025 and Design/Process Control Requirements ISO 17025 related Discussions 2
L Design Validation Process Owner - Who should be the process owner of validation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
kedarg6500 Manufacturing Process Design and Development Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S TS 16949 7.3.3.2 Question - Manufacturing Process Design Output. IATF 16949 - Automotive Quality Systems Standard 8
O Outsourcing part of Design & Dev Process- Still requiring D&D ver & val-7.3.5, 7.3.6? IATF 16949 - Automotive Quality Systems Standard 6
V Examples for failure modes of Design & Process FMEAs FMEA and Control Plans 5
T Request for a Design Control Procedure or Process Flow for HVAC Design Document Control Systems, Procedures, Forms and Templates 1
A Design FMEA, Process FMEA, Component FMEA --> FDA requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 18
