Design Verification Documentation
racglobal
Hello everyone,
I understand there are different design verification methods. CAD drawings/PCB drawings are one form of design output. To verify the outputs against the inputs, it is usually an inspection. How does one write a design verification report to demonstrate the design output (design drawings) meets the design input requirements? I've only seen design verification report for tests. How does one write a report that summarizes an inspection of a drawing? I'd appreciate any insight.
Thanks.
Jen Kirley
Quality and Auditing Expert
Good day racglobal,
A report can contain descriptive and/or numerical information. Inspection of a part against the drawing(s) will usually include dimensional checks, but the notes should also be addressed. A note that says "Cable ties 12345 attached at point A, B and C" Can have a line n the report saying "Cable ties 12345 attached at points A, B and C - Present" which indicates the required BOM part was verified to be present. If the print calls out for a material type, the report can refer to a Certificate of Analysis; if a special requirement for something like RoHS compliance is included in the notes, a line item confirming RoHS certificate of compliance can be included in the report.
Line by line by line, the drawing's features have been identified by circles with numbers in them that correspond to line items on the inspection report. This is called a "bubbled pint." It is included as a reference along with the inspection report and mentioned certificates as required, as a package showing your initial product has been verified to conform to requirements.
Is this what you wanted to know?
Ronen E
Problem Solver
Moderator
You don't design-verify individual design outputs, you verify the design output as a whole. You go through individual design inputs, and look for supporting evidence in/by the design outputs, wherever you can find it. It may be one or more detail from a drawing, multiple details from several drawings, or other things.
You don't "verify a drawing" (design-verify). One might inspect a drawing, but that's more of an engineering check, part of the actual design effort.
That's verifying the realization against the drawing, not verifying the design ("verifying the drawing", ugh) against the design input.
Jen Kirley
Thank you Ronen, please feel free to give a better example than I did. I usually stick to other subjects because of this.
Watchcat
You don't design-verify individual design outputs, you verify the design output as a whole. You go through individual design inputs, and look for supporting evidence in/by the design outputs, wherever you find them
I agree with what you are saying, but I don't think I would describe this as verifying design outputs "as a whole." Clearly verification involves individual inputs and outputs, nothing holistic.
I think your key point relative to racglobal's question is that verification is driven by inputs, not outputs. If you have outputs that don't verify any inputs, not a problem. If you have inputs that are not verified by any outputs (whether they are drawings or test results or whatever), you definitely have a problem.
I think validation is what deals with the design "as a whole."
akp060
But shouldn't be all outputs (DO) be verified against their inputs? At least that is what the design control guidance says. And if any DO does not satisfy any input how do you map that to a Product Requirement/User requirement. Please cite an example if convenient
Tidge
There was a subtle point in the post by @Watchcat: All inputs require verification that they are satisfied, and even though inputs must be allocated to design outputs there are often certain elements of design outputs that don't derive from specified inputs. Typically the first order of design inputs is to satisfy patient/user needs; higher orders of design inputs can address things like manufacturability and purchasability of raw materials. These higher order inputs can often go unspecified; that is, they won't necessarily be spelled out in a design inputs requirement document...it all depends on the maturity of the organization.
For example: aesthetic choices (e.g. color of wires) are often included on certain design outputs but are usually not directly satisfying a design input whereas the gauge of the wire is likely satisfying the current-carrying capacity of a cable assembly. Engineers often have legitimate reasons for most of the design outputs, but not all of the design choices would have been mandated by the input requirements. It has been my experience that it is best to specifically identify and review the elements of design outputs which are specifically allocated to satisfy design inputs, and also to review the completed design output for suitability for all the "unspecified inputs".
Ronen E
Problem Solver
Moderator
No. The Design Output (singular), as a set, must be verified, but there's no requirement to verify individual design outputs (plural).
Quote?
Where is the requirement to "map" every individual design output to specific design inputs?
akp060
Quote?
I hope I killed three birds with one shot! Excuse me if I have left anything unanswered. Mapping is a logical approach to demonstrate compliance with the above. If we do not map User need(s)>Design Input(s)>Design Output(s) that such and such output correspond such and such input and that in turn to such and such requirements we end up having a design that is to some extent unverified either in terms of design output or user requirements. The end goal is always justifying the indications for use/intended use while neither overdoing or understating, which is always achieved by mapping throughout the design process
C Items used for Design Verification Design and Development of Products and Processes 4
J Managing design verification regression testing of design changes Design and Development of Products and Processes 1
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
D Design Verification - Is testing required? Design and Development of Products and Processes 5
R Design verification for interim design outputs - sampling rationale ISO 13485:2016 - Medical Device Quality Management Systems 2
D Testing to failure for design verification Reliability Analysis - Predictions, Testing and Standards 11
D Supplied item design verification Supplier Quality Assurance and other Supplier Issues 5
Ronen E A Rational Basis for Design Verification Design and Development of Products and Processes 5
V Which batches should or could be considered for design validation and design verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
R Medical Device Design verification sample prototype Other Medical Device and Orthopedic Related Topics 14
E Sample size for design verification of variable in single use device Design and Development of Products and Processes 20
S Source of QMS templates including templates for design verification/design validation Document Control Systems, Procedures, Forms and Templates 2
C Deviation in Design verification Other Medical Device Related Standards 6
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
J Design Verification - Managing Changes Design and Development of Products and Processes 4
S CE Mark Approval Design Verification and Validation Questions CE Marking (Conformité Européene) / CB Scheme 8
V Template / format for Device History File & Design Verification of transdermal patch 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
H Is design verification and validation required for samples accompanying the quotes ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Pre-Design Verification - Using Continuous / Variables Data Statistical Analysis Tools, Techniques and SPC 2
W Qualification of Design Verification Equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P ISO9001 Scope Exclusion Verification in a Design Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Design Verification: "Difference" in Sample Size Calculations? Design and Development of Products and Processes 1
S Verification and Validation of Post Market Design Change Design and Development of Products and Processes 2
H Form that will satisfy Design Review and Design Verification Requirements (7.3) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Design Inputs and Verification Activities CE Marking (Conformité Européene) / CB Scheme 5
R Need help on defining scope for Design Verification File for Class III IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
smryan Satisfying the ISO 9001:2008 7.3.5 Design & Development Verification requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P How to separate Product Design Review, Verification, and Validation Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Uriel Alejandro Trouble with a Mechanical Design Technical Verification Check List AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Design and Development Outputs Approval, Verification and Validation IATF 16949 - Automotive Quality Systems Standard 4
A ?820.30(d) Design Output Release - Before or After Verification? Design and Development of Products and Processes 6
T DVP&R (Design Verification Plan and Report) for Vehicle Labels? APQP and PPAP 3
W Design History Verification Records Control and Approvals US Food and Drug Administration (FDA) 3
G Legacy Product - Do we need follow QSR 820? Design Verification and Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
S Design and Development - Review vs. Verification vs. Validation Design and Development of Products and Processes 15
S Acceptance Criteria at Design Verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Sample Size for Design Verification and Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Chennaiite Is Design Verification Software required to be Calibrated IATF 16949 - Automotive Quality Systems Standard 7
B Is Ship Test considered Design Verification or Design Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D Design Input/Output and Design V&V (Verification and Validation) Interpretations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
D Medical Device Design Verification and Validation Differences 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 16
S Medical Devices Design Verification Sampling Other Medical Device and Orthopedic Related Topics 3
S Checklist for RA and QA Review of DVT (design verification test) for Software Other US Medical Device Regulations 2
