Design verification for interim design outputs - sampling rationale
racglobal
Hello everyone,
In building a large and complex electrical medical device also linked to software, there are many what I call interim design outputs (for examples, a populated PCB board) that are not the final design output (the finished medical device) but are what I call "sub-systems" or "modules", in performing design verification (to verify that the outputs meet our input requirements), what is the sampling rationale? We are taking what we receive from a supplier to see if the component meets specifications. This PCB board would be an interim design output; is there a particular sampling rationale when planning the design verification for an interim design output? In this case, how many PCB boards would be tested? I would appreciate any insight on this. Thanks.
indubioush
Design verification sample sizes should be driven by the associated risks of the component or system. Usually you have requirements for confidence/reliability according to the associated risk level. The higher the risk, the greater the required confidence/reliability. This required confidence/reliability will determine the sample size. For example, if 95/95 confidence reliability is required, this would mean a sample size of 60. This is why it is very important to perform risk management activities early on in the development process. With all of that said, however, it seems to me that you are doing some feasibility testing at this point. If you plan on repeating your test later for your official design verification, you can select any sample size you want right now.
Ronen E
Problem Solver
Moderator
Hello everyone,
Have a look at my article. It'll walk you through a rational design verification process that can be applied with relatively small (given) sample sizes, and at that is statistically sound (well, until someone shows me how it isn't).
Jumping straight to questions like sample size or confidence levels is a little silly without first considering whether the underlying most basic inference assumptions hold (e.g. "the sample represents the population/process", "the samples come from a homogeneous process", "the measuring system is good enough").
C Items used for Design Verification Design and Development of Products and Processes 4
J Managing design verification regression testing of design changes Design and Development of Products and Processes 1
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
D Design Verification - Is testing required? Design and Development of Products and Processes 5
R Design Verification Documentation ISO 13485:2016 - Medical Device Quality Management Systems 19
D Testing to failure for design verification Reliability Analysis - Predictions, Testing and Standards 11
D Supplied item design verification Supplier Quality Assurance and other Supplier Issues 5
Ronen E A Rational Basis for Design Verification Design and Development of Products and Processes 5
V Which batches should or could be considered for design validation and design verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
R Medical Device Design verification sample prototype Other Medical Device and Orthopedic Related Topics 14
E Sample size for design verification of variable in single use device Design and Development of Products and Processes 20
S Source of QMS templates including templates for design verification/design validation Document Control Systems, Procedures, Forms and Templates 2
C Deviation in Design verification Other Medical Device Related Standards 6
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
J Design Verification - Managing Changes Design and Development of Products and Processes 4
S CE Mark Approval Design Verification and Validation Questions CE Marking (Conformité Européene) / CB Scheme 8
V Template / format for Device History File & Design Verification of transdermal patch 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
H Is design verification and validation required for samples accompanying the quotes ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Pre-Design Verification - Using Continuous / Variables Data Statistical Analysis Tools, Techniques and SPC 2
W Qualification of Design Verification Equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P ISO9001 Scope Exclusion Verification in a Design Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Design Verification: "Difference" in Sample Size Calculations? Design and Development of Products and Processes 1
S Verification and Validation of Post Market Design Change Design and Development of Products and Processes 2
H Form that will satisfy Design Review and Design Verification Requirements (7.3) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Design Inputs and Verification Activities CE Marking (Conformité Européene) / CB Scheme 5
R Need help on defining scope for Design Verification File for Class III IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
smryan Satisfying the ISO 9001:2008 7.3.5 Design & Development Verification requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P How to separate Product Design Review, Verification, and Validation Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Uriel Alejandro Trouble with a Mechanical Design Technical Verification Check List AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Design and Development Outputs Approval, Verification and Validation IATF 16949 - Automotive Quality Systems Standard 4
A ?820.30(d) Design Output Release - Before or After Verification? Design and Development of Products and Processes 6
T DVP&R (Design Verification Plan and Report) for Vehicle Labels? APQP and PPAP 3
W Design History Verification Records Control and Approvals US Food and Drug Administration (FDA) 3
G Legacy Product - Do we need follow QSR 820? Design Verification and Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
S Design and Development - Review vs. Verification vs. Validation Design and Development of Products and Processes 15
S Acceptance Criteria at Design Verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Sample Size for Design Verification and Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Chennaiite Is Design Verification Software required to be Calibrated IATF 16949 - Automotive Quality Systems Standard 7
B Is Ship Test considered Design Verification or Design Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D Design Input/Output and Design V&V (Verification and Validation) Interpretations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
D Medical Device Design Verification and Validation Differences 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 16
S Medical Devices Design Verification Sampling Other Medical Device and Orthopedic Related Topics 3
S Checklist for RA and QA Review of DVT (design verification test) for Software Other US Medical Device Regulations 2
