Design Verification & Process Validation - Statistical sample sizes
Nancylove
Hi all:
I’ve seen a lot of threads of Design Verification, Process Validation and statistical sample sizes, but I haven’t seen anything that answers my question. I’m looking forward to input from experts in these areas regarding to my questions below.
If you have a feature such as 2 plastic tubes that are bonded together and a product requirement of tensile strength (ex: 5 N) for the bonded assembly, should you do both design verification and process validation for the same requirement? Design verification is required per 7.3.6 of ISO 13485, and since it’s a mfg process, Process Validation per 7.5.6 is required also. What is the purpose of doing Design Verification for this feature if Process Validation will provide the final results? Why not perform Process Validation to satisfy the 7.3.6 requirements?
Note: I did find one post from 2008 in which the conclusion seems to support Process Validation can satisfy Design Verification, but I'd like the latest input.
Thank you.
Ronen E
Problem Solver
Moderator
You might receive (useful?) input here but the only expertise you will find here is a self-professed one. It is solely up to you to determine the real worth of any advice you find here.
On point:
Design Verification (DV henceforth) and Process Validation (PV) are intended to serve different purposes and occur at different stages of the D&D endeavour. After the case, a proper PV might technically satisfy the requirements of DV, but in the majority of cases its (proper) timing will completely miss the purpose of DV. Typically, DV occurs at the prototype stage, when the commercial production process doesn't yet exist or is just starting to form. It usually involves a relatively small unit count (typically prototypes), is not intended to provide full assurance, and is targeted at gaining sufficient confidence that the design, as at the time arrived at, is satisfactory (meets the latest approved design input). The manufacturing techniques employed may be provisional and quite different from the scaled up production techniques that will be in place for PV (typically, quite some time later). A fully successful DV may trigger design freeze, setting up a pilot- or an initial full-scale production line, progressing to design validation (sometimes blended with PV) etc. But the DV might also end up being less than fully successful, and trigger design input updates or design changes (which will typically lead to another DV iteration).
PV doesn't have to take place at all. It's required only where 100% production verification can't/doesn't happen in a specific process. Where it does take place, the purpose is to prove that the established production process is reliable (actually, part of the process establishment may occur as part of PV). For PV, the design is already not in question.
Perhaps you will find interest in my article about design verification.
Nancylove
On point:
Thank you. Your comments makes sense.
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Sample Size in Design Verification & Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Can Process Validation actually be Design Verification? Design and Development of Products and Processes 4
Q Differences between Sample Sixes for Design Verification vs. Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
D Design and Process - Validation vs. Verification - What is the difference? Design and Development of Products and Processes 20
C Items used for Design Verification Design and Development of Products and Processes 4
J Managing design verification regression testing of design changes Design and Development of Products and Processes 1
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
D Design Verification - Is testing required? Design and Development of Products and Processes 5
R Design Verification Documentation ISO 13485:2016 - Medical Device Quality Management Systems 19
R Design verification for interim design outputs - sampling rationale ISO 13485:2016 - Medical Device Quality Management Systems 2
D Testing to failure for design verification Reliability Analysis - Predictions, Testing and Standards 11
D Supplied item design verification Supplier Quality Assurance and other Supplier Issues 5
Ronen E A Rational Basis for Design Verification Design and Development of Products and Processes 5
V Which batches should or could be considered for design validation and design verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
R Medical Device Design verification sample prototype Other Medical Device and Orthopedic Related Topics 14
E Sample size for design verification of variable in single use device Design and Development of Products and Processes 20
S Source of QMS templates including templates for design verification/design validation Document Control Systems, Procedures, Forms and Templates 2
C Deviation in Design verification Other Medical Device Related Standards 6
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
J Design Verification - Managing Changes Design and Development of Products and Processes 4
S CE Mark Approval Design Verification and Validation Questions CE Marking (Conformité Européene) / CB Scheme 8
V Template / format for Device History File & Design Verification of transdermal patch 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
H Is design verification and validation required for samples accompanying the quotes ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Pre-Design Verification - Using Continuous / Variables Data Statistical Analysis Tools, Techniques and SPC 2
W Qualification of Design Verification Equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P ISO9001 Scope Exclusion Verification in a Design Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Design Verification: "Difference" in Sample Size Calculations? Design and Development of Products and Processes 1
S Verification and Validation of Post Market Design Change Design and Development of Products and Processes 2
H Form that will satisfy Design Review and Design Verification Requirements (7.3) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Design Inputs and Verification Activities CE Marking (Conformité Européene) / CB Scheme 5
R Need help on defining scope for Design Verification File for Class III IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
smryan Satisfying the ISO 9001:2008 7.3.5 Design & Development Verification requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P How to separate Product Design Review, Verification, and Validation Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Uriel Alejandro Trouble with a Mechanical Design Technical Verification Check List AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Design and Development Outputs Approval, Verification and Validation IATF 16949 - Automotive Quality Systems Standard 4
A ?820.30(d) Design Output Release - Before or After Verification? Design and Development of Products and Processes 6
T DVP&R (Design Verification Plan and Report) for Vehicle Labels? APQP and PPAP 3
W Design History Verification Records Control and Approvals US Food and Drug Administration (FDA) 3
G Legacy Product - Do we need follow QSR 820? Design Verification and Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
S Design and Development - Review vs. Verification vs. Validation Design and Development of Products and Processes 15
S Acceptance Criteria at Design Verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Sample Size for Design Verification and Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Chennaiite Is Design Verification Software required to be Calibrated IATF 16949 - Automotive Quality Systems Standard 7
B Is Ship Test considered Design Verification or Design Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
