Designing a Closed Loop Water System using Adiabatic Cooling Towers
alokb
Dear All,
I am not sure whether it is right forum to raise this query here.
Nevertheless I like to put it here and ask for support, if I can be directed to right place.
We are having evaporative cooling towers ( circulation flow 3100 m3/hr and 1900 m3/hr) which we are replacing with Adiabatic cooling towers.
The most obvious change is in the form of water flow being changed to closed circuit from open circuit.
There are many basic apprehension in mind like designing of pump head /NPSH available/expansion tank designing etc etc. Basically these query relates to designing of closed loop water system.
What should I do first?
Thanks and regrads.
Alok
Stijloor
Dear All,
Thanks and regards.
Alok
Can someone help or has suggestions for Alok?
Thank you!!
Stijloor.
Ronen E
Problem Solver
Moderator
Dear All,
Thanks and regrads.
Alok
Purchase the "Closed loop water cooling system design handbook"?... :lol:
harry
Not sure about your area but these days, such work are considered 'specialist' work in my area and usually, the supplier of the system would be able to carry out the design, submit for approval (if needed) and carry out all the installation, testing and commissioning works - save the customers a lot of hassles.
K
KLDLetts - 2012
Harry's approach is the one I see done most often these days, even from our on-site engineering department. There is no/little benefit to recreating the wheel, if there is a commercially available product for your purpose!
But, as an engineer, I guess I'd start by determining the temperature change I want and my delivery pressure...which would start a long line of calculations to determine the outlet pressure (since this is an adiabatic process), flow rates, etc.
kuyakut
First thing you do is find out if there is some benefits in terms of cost savings , less monitoring , easy to use. If changing from free flow to closed circuit doesnt give you any form of cost saving. My suggestion is to stick to your current system.
Just my 2 cents of opinion
Kuyakut
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
A Leadership Role in Designing QMS - Upper Management Support Quality Manager and Management Related Issues 16
S Designing the experiment with minimum run Statistical Analysis Tools, Techniques and SPC 0
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
F Designing a Hollow Medical Device for Autoclavability Other Medical Device and Orthopedic Related Topics 2
Claes Gefvenberg Designing Supplier Questionnaire Forms Supplier Quality Assurance and other Supplier Issues 25
M Designing a Quality Assurance and Control System Quality Manager and Management Related Issues 3
P Sheet Metal Design: Standard method for designing Electrical Knockouts Design and Development of Products and Processes 7
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Line Balance Simulation when Designing a New Production Line Lean in Manufacturing and Service Industries 1
D Designing a Training Course called "Role of the Laboratory Quality Manager" Training - Internal, External, Online and Distance Learning 13
A Designing a Documents Control System from scratch (in a php intranet) Document Control Systems, Procedures, Forms and Templates 5
K Designing a gauge to check the Axis of Snorkel of Axles Design and Development of Products and Processes 5
R AS9100C Clause 7.3 Design & Development - Designing a System and Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S API Std 620 vs. API 650 standard? Which is the least restrictive in designing a tank? Manufacturing and Related Processes 1
A Designing an Ethylene Oxide Sterilization Process Other Medical Device Regulations World-Wide 7
M Designing a Nonconformance Management Process Nonconformance and Corrective Action 35
Q Are there any threads specifically concerned with designing with AutoCAD? Design and Development of Products and Processes 1
P Designing a "part-specific" Receiving Gauge - Gauge first or job? Design and Development of Products and Processes 4
C Designing Control Charts - Variable with Small Variation and Tight Control Limit Statistical Analysis Tools, Techniques and SPC 20
C Designing control chart for non-normal variables Statistical Analysis Tools, Techniques and SPC 3
A Is the Assembly of the Prototype after Designing considered a Production Process? Design and Development of Products and Processes 11
M Designing a scope for APQP Design and Development of Products and Processes 2
B Designing a Test Part to Assess CMM Operator's Knowledge Design and Development of Products and Processes 9
D Designing an ISO 9001 Internal Audit Training Course - Need Help Internal Auditing 6
S Project Management QMS - Manufacturing and Designing of Special Purposed Machines Design and Development of Products and Processes 5
L Categories for data collection - Designing a form for when errors occur Nonconformance and Corrective Action 6
J Designing a Mil-Std-105 or ANSI/ASQ Z1.4 Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 49
R Designing and building our own machines Design and Development of Products and Processes 5
V Designing an integrated ISO 9000 - ISO 14000 System in a Big Marine Port Design and Development of Products and Processes 3
S US Success in Designing & Manufacturing World-Class Goods Design and Development of Products and Processes 2
Claes Gefvenberg Document control applications - Be very wary about designing your own Document Control Systems, Procedures, Forms and Templates 4
F 8.2.1 Customer Satisfaction - Designing & Building a Solid waste disposal facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
O Need documentation - Designing a data acquisition system for the enviromental chamber Design and Development of Products and Processes 3
N Validation of special processes - thread closed Oil and Gas Industry Standards and Regulations 3
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
D Class II medical device - When should a complaint be closed? Customer Complaints 6
A Can change control can be closed if the CAPA is still open? Nonconformance and Corrective Action 3
K What is supposed to happen when a CA cannot be closed out or the root cause... General Auditing Discussions 1
V Open vs Closed Systems - Criteria for Categorization in cGMP Environment Qualification and Validation (including 21 CFR Part 11) 4
A Retrospective Effectivness Review of Closed CAPAs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Closed Customer Complaint Response Form Examples? Customer Complaints 3
M CCFT (Closed Coupled Field Technology) Technology in Clean Environments Misc. Quality Assurance and Business Systems Related Topics 1
Q Are ECO's closed after they are shown to be Effective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A What happens if an External Audit NC (Nonconformance) is not closed in 90 days? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Reopening a Closed Division - Multi-division tier 2 automotive supplier IATF 16949 - Automotive Quality Systems Standard 7
E C/A (Corrective Action) not closed in a timely manner Nonconformance and Corrective Action 26
M closed thanks Document Control Systems, Procedures, Forms and Templates 1
