Designing a "part-specific" Receiving Gauge - Gauge first or job?
P
prana - 2008
Hi all...
Hope i'm posting this in the right section...
I'm a self-employed engineering designer, currently designing a "part-specific" receiving gauge for a Ford bracket.
I've done a few designs earlier which work absolutely fine and with the gauge currently in question, i have a problem. I am pretty much new to the process, but i have quite an idea of how things work.
The job has two ear-like projections with quite a long gap in btwn. One face of the ear-like-projection has to be checked for flatness, also it's M10 thread. The other projection, separated with no material in btwn, has a D20mm bore. No flat-face check here. However, the complexity of the 3D tapering-contour around the D20mm bore, which is such that a gauge portion (even a P-like projection from the gauge) is not possible, (view the snapshots attached, please) calls for the pin to engage with the job/component first and then with the gauge. The check is only for concentricity and bore size.
Is this an accepted procedure considering that by protocol (or so i thought), the pin should enter the gauge portion first and then the component?:confused:
Please let me know...
P
prana - 2008
tho am still expecting a response from someone, i've received a go-ahead from my client for the current configuration. thoughts welcome. in fact, i was abt to type "good suggestions get a complimentary dinner for two at a restaurant of your choice". so pl comment. pour in thoughts, just loud-think. u never know what might help.
U
Umang Vidyarthi
Hello Prana, welcome to the cove.:bigwave:
I see you are new here, so my advise is to refrain from 'offers' for getting good suggestions. Covers here work on the principle of 'Help each other', and they will only be more than happy to help you, just have to be patient.
Can you rephrase your querry since it is unclear(to me), and also mark the area that is to be checked for flatness & thread, and the bore. Also tell us w.r.t. what, the concentricity of D20 bore is required to be checked?
Umang :D
justncredible
Flatness with what looks like a plug gage, the only way you could check that flatness would be with a feeler gage. You could just use a striaght edge scale to lay on there for that check. The other is a plain simple plug gage from what I can tell. I would have them put centers on each end for a fast recheck of the gage. Putting a head on one end may lead to a operator beating it in with a hammer, LOL. I have seen lead men do worse to a gage.
B Designing a Test Part to Assess CMM Operator's Knowledge Design and Development of Products and Processes 9
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
A Leadership Role in Designing QMS - Upper Management Support Quality Manager and Management Related Issues 16
S Designing the experiment with minimum run Statistical Analysis Tools, Techniques and SPC 0
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
F Designing a Hollow Medical Device for Autoclavability Other Medical Device and Orthopedic Related Topics 2
Claes Gefvenberg Designing Supplier Questionnaire Forms Supplier Quality Assurance and other Supplier Issues 25
M Designing a Quality Assurance and Control System Quality Manager and Management Related Issues 3
P Sheet Metal Design: Standard method for designing Electrical Knockouts Design and Development of Products and Processes 7
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Line Balance Simulation when Designing a New Production Line Lean in Manufacturing and Service Industries 1
D Designing a Training Course called "Role of the Laboratory Quality Manager" Training - Internal, External, Online and Distance Learning 13
A Designing a Documents Control System from scratch (in a php intranet) Document Control Systems, Procedures, Forms and Templates 5
K Designing a gauge to check the Axis of Snorkel of Axles Design and Development of Products and Processes 5
A Designing a Closed Loop Water System using Adiabatic Cooling Towers Manufacturing and Related Processes 5
R AS9100C Clause 7.3 Design & Development - Designing a System and Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S API Std 620 vs. API 650 standard? Which is the least restrictive in designing a tank? Manufacturing and Related Processes 1
A Designing an Ethylene Oxide Sterilization Process Other Medical Device Regulations World-Wide 7
M Designing a Nonconformance Management Process Nonconformance and Corrective Action 35
Q Are there any threads specifically concerned with designing with AutoCAD? Design and Development of Products and Processes 1
C Designing Control Charts - Variable with Small Variation and Tight Control Limit Statistical Analysis Tools, Techniques and SPC 20
C Designing control chart for non-normal variables Statistical Analysis Tools, Techniques and SPC 3
A Is the Assembly of the Prototype after Designing considered a Production Process? Design and Development of Products and Processes 11
M Designing a scope for APQP Design and Development of Products and Processes 2
D Designing an ISO 9001 Internal Audit Training Course - Need Help Internal Auditing 6
S Project Management QMS - Manufacturing and Designing of Special Purposed Machines Design and Development of Products and Processes 5
L Categories for data collection - Designing a form for when errors occur Nonconformance and Corrective Action 6
J Designing a Mil-Std-105 or ANSI/ASQ Z1.4 Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 49
R Designing and building our own machines Design and Development of Products and Processes 5
V Designing an integrated ISO 9000 - ISO 14000 System in a Big Marine Port Design and Development of Products and Processes 3
S US Success in Designing & Manufacturing World-Class Goods Design and Development of Products and Processes 2
Claes Gefvenberg Document control applications - Be very wary about designing your own Document Control Systems, Procedures, Forms and Templates 4
F 8.2.1 Customer Satisfaction - Designing & Building a Solid waste disposal facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
O Need documentation - Designing a data acquisition system for the enviromental chamber Design and Development of Products and Processes 3
A MDR ANNEX XI part A or Part B EU Medical Device Regulations 0
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
V Part selection for R&R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
D Is PMCF really a continuous activity per Annex XIV,Part B? EU Medical Device Regulations 5
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Relabelling a component that will be sold as a spare part - Do I become legal manufacturer? EU Medical Device Regulations 2
