Designing a Sampling Plan - AQL
Black arrow
#11
Hello again,
Thanks you all for your support i have now lot of links and information to dig in. Bev D, i started to check your excel files you sent to me and i have 2 questions regarding one of them.
Regarding "Excel document: "Confidence Intervals Cpk Process Capability.xls",
- Can you please define "Error". Is it acceptable defect rate , 'accepted' 10 % of the time - or rejected 90% of the time.
-Can you also explain the difference between "CPK not less than" and "CPK min"?
- You wrote "for example if you want a Cpk of 1.67, and a 95% confidence (alpha) with an acceptable error rate of .1 then your sample size is 408." But if i choose a larger sample size than 408? For example 462, do i have 96% confidence (alpha)?
My colleague and i discussed if you also have an excel file for conversion of Cpk to PPM?
Statistical Steven
Statistician
#12
Here is a PPM to Cpk/Ppk and Cpk/Ppk to PPM coversion
Hello again,
#13
Thanks Steven!
I've also attached a larger spreadsheet that has Cpk to ppm conversions as well as other indices. you might find this helpful.
as for the questions concerning the Cpk spreadsheets:
- the error is the amount of 'inaccuracy' you want in the Cpk estimate. the smaller this number is, the larger the required sample size.
- the confidence sets the 'precision' of the estimate and will control the confidence intervals. the more precise the estimate (the higher the confidence) the larger the required sample size.
The min Cpk is the lower confidence limit for the intended Cpk. This is an estimate of what might happen before you get any results. For example if you are trying to determine if you have a Cpk of 1.33 with an error of .15 and confidence of 95%, the spreadsheet will give you a sample size of 120. If you really have a process at 1.33 and you use the sample size indicated (120) you could conceivably get an actual result as low as 1.151 or as high as 1.509.
Once you get results, the 'not less than' column is used: If your actual result is 1.33 then in all likelihood the true value is not less than 1.18
Black arrow
#14
Thanks Statistical Steve and Bev D
I made som tests on my own just to increase my knowledge about how confidence interval is related to sample size. I randomly selected pieces from a existing batch and started with few sample size.
Before we measure the parts we decided that:
Desired Cpk=1.2 (159 PPM, One sided tolerance)
Confidence 95%
Error: 0,15
From the excel document: Sample Size 100
Cpk min:1,021 Cpk max: 1,379
Calculated Cpk in mintab 17
Sample Size: 5 =>Cpk: 0,71
Sample Size: 20 =>Cpk: 0,85,
Sample Size: 50 =>Cpk: 0,91,
Sample Size: 100 =>Cpk: 0,97, From excel doc. (Cpk min=0.82, Cpk max=1.12 , Cpk not less than: 0,844)
What conclusion can i take from this? My actual result is 0,97 and true value is not less than 0,844. Is that correct?
Black arrow
#15
I really appreciate if some one could reply on the above.
1) My actual Cpk result is 0.97 from my sample size of 100 but the true value is not less than 0,844?
2) And PPM is then 5671 based on 0,844 and one sided-tolerance?
If i study the Cpk from low selected pieces of just 5 to increased number of pieces, up to 100 pieces i can see that Cpk increased from 0,71 to 0,97. The tricky part is how represented the Cpk=0.97 is compared to the whole batch of 5000 pieces. If i calcultate with Cpk=0.844 and PPM=5671,can i say that 28 pieces from the batch of 5000 is out of tolerance?
#16
yes, that is correct. there is always error in any sample - only 100% is 'accurate'. (although technically, the confidence intervals are only a measure of the precision of the estimate and not the accuracy. It is wrong to say that the true Cpk is not less than .844, but since this distinction is lost on so many people - such as auditors - it is not a bad thing to claim)
yes. OR you can use the actual estimate instead of the worst case estimate...
theoretically yes. BUT for this to be accurate, you must have a truly random sample from the lot of 5000 AND you must have a Normal distribution. even symmetrical bell shaped distributions often deviate substantially from the theoretical Normal in the tails - where few values truly reside. most distributions are truncated and the theoretical Normal model has infinite tails - so you are most likely overstating the defect percent.
sorry - I'm sure you want a definitive accurate and precise answer - but those simply don't exists in real life.
JohnStewart
#18
As soon as you know all parameters you want to set you can try AQL Calculator app on google play market from blueSkyCorner.
It's really useful
Cheers
J Designing a Mil-Std-105 or ANSI/ASQ Z1.4 Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 49
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
A Leadership Role in Designing QMS - Upper Management Support Quality Manager and Management Related Issues 16
S Designing the experiment with minimum run Statistical Analysis Tools, Techniques and SPC 0
F Designing a Hollow Medical Device for Autoclavability Other Medical Device and Orthopedic Related Topics 2
Claes Gefvenberg Designing Supplier Questionnaire Forms Supplier Quality Assurance and other Supplier Issues 25
M Designing a Quality Assurance and Control System Quality Manager and Management Related Issues 3
P Sheet Metal Design: Standard method for designing Electrical Knockouts Design and Development of Products and Processes 7
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Line Balance Simulation when Designing a New Production Line Lean in Manufacturing and Service Industries 1
D Designing a Training Course called "Role of the Laboratory Quality Manager" Training - Internal, External, Online and Distance Learning 13
A Designing a Documents Control System from scratch (in a php intranet) Document Control Systems, Procedures, Forms and Templates 5
K Designing a gauge to check the Axis of Snorkel of Axles Design and Development of Products and Processes 5
A Designing a Closed Loop Water System using Adiabatic Cooling Towers Manufacturing and Related Processes 5
R AS9100C Clause 7.3 Design & Development - Designing a System and Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S API Std 620 vs. API 650 standard? Which is the least restrictive in designing a tank? Manufacturing and Related Processes 1
A Designing an Ethylene Oxide Sterilization Process Other Medical Device Regulations World-Wide 7
M Designing a Nonconformance Management Process Nonconformance and Corrective Action 35
Q Are there any threads specifically concerned with designing with AutoCAD? Design and Development of Products and Processes 1
P Designing a "part-specific" Receiving Gauge - Gauge first or job? Design and Development of Products and Processes 4
C Designing Control Charts - Variable with Small Variation and Tight Control Limit Statistical Analysis Tools, Techniques and SPC 20
C Designing control chart for non-normal variables Statistical Analysis Tools, Techniques and SPC 3
A Is the Assembly of the Prototype after Designing considered a Production Process? Design and Development of Products and Processes 11
M Designing a scope for APQP Design and Development of Products and Processes 2
B Designing a Test Part to Assess CMM Operator's Knowledge Design and Development of Products and Processes 9
D Designing an ISO 9001 Internal Audit Training Course - Need Help Internal Auditing 6
S Project Management QMS - Manufacturing and Designing of Special Purposed Machines Design and Development of Products and Processes 5
L Categories for data collection - Designing a form for when errors occur Nonconformance and Corrective Action 6
R Designing and building our own machines Design and Development of Products and Processes 5
V Designing an integrated ISO 9000 - ISO 14000 System in a Big Marine Port Design and Development of Products and Processes 3
S US Success in Designing & Manufacturing World-Class Goods Design and Development of Products and Processes 2
Claes Gefvenberg Document control applications - Be very wary about designing your own Document Control Systems, Procedures, Forms and Templates 4
F 8.2.1 Customer Satisfaction - Designing & Building a Solid waste disposal facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
O Need documentation - Designing a data acquisition system for the enviromental chamber Design and Development of Products and Processes 3
J IVD sampling sizes for buyer Reliability Analysis - Predictions, Testing and Standards 0
C Sampling - ISO 16269-6 vs ISO 2859 Other ISO and International Standards and European Regulations 0
L Sampling Plan Risks AQL - Acceptable Quality Level 6
Q Sampling method for Distributor verification activities EU Medical Device Regulations 1
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
R Reduced sampling plan for sterial products APQP and PPAP 0
A ISO 2859-1 - 9.3.3.2 Switching score - Sampling Plans and PPM AQL - Acceptable Quality Level 0
