Designing a Test Part to Assess CMM Operator's Knowledge
BBill
Hi everybody,
This is my first post but I have been reading many of the threads that pertain to the ISO 17025 standard over the last few days. However, I haven’t been able to find an answer to my questions. So, here is the deal.
My boss has asked me to design a small test part to be used for testing operator proficiency at using CMMs. The idea is to include specific features into the test part which would expose operator’s basic lack of knowledge.
That way, just by looking at the measured data, one would be able to assess whether the measurement errors (if there were any) were the operator’s fault of due to an un-calibrated machine. So my question is; What kind of features could be incorporated into the part which would test the operator’s proficiency and would allow the person assessing the operator to identify what the operator did wrong just by looking at the raw data.
Any help or ideas will be greatly appreciated on this one!
Thanks in advance.
Bill
True Position
Typically any measurement made with a CMMs main source of error will be within the machine. If the programmer can write the program in the first place is the issue.
Good tests are true positions, secondary datum structures, rotated alignments, alignment between two pins/holes with neither being the origin and them not lining up on either the X or Y axis, etc.
Getting different results for roundness and cylindricity is a good test for a Calypso programmer as well.
John Nabors - 2009
I can't remember working on a CMM that did not come with a sample piece as a training tool. If you do not have one perhaps you could check witth the manufaturer of your CMM(s) to see if they can provide one.
Hawat - speaking of Calypso, how do you like it? Zeiss was just getting ready to transition from U-MESS to Calypso the last time I worked on one.
-John
True Position
I absolutely love Calypso, it is the best CMM software I have ever had the pleasure of using. It's powerful, intuitive, and allows very easy program modification after initial programming.
gard2372
Hi everybody,
Thanks in advance.
Bill
Bill,
Your statements concern me a bit. The general tone of your Boss' direction seems to be directed at operator faults, lack of knowledge and what the oeprator did wrong. Am I totally off base here in reading the tone of your post? :(
The focus IMHO should be on a sound CMM training program. Every operator/programmer has to start somewhere and some pick up to code and "The Right Hand Rule" faster than others. :read:
True Position
It sounds more like he's looking for a method to validate the effectiveness of his training methods.
Kingsld1
I would not be worried so much about the software. If I were to be testing a programmer I would be focused more on basic blueprint reading, GD&T and probably their surface plate skills.
Basic CMM courses generally take a week out of your life and are almost exclusively concerned with teaching the software. They also assume that you know your way around a print and could, if needed, do a setup the old fashioned way.
I have seen people "graduate" from a CMM course with little clue as to how a print is telling them the part should be setup.
I have worked with five different CMM languages. The general concepts are the same no matter what. With very little instruction you can figure out where they hide the command at this time. Learning how to read a print is the crucial difference between a good CMM programmer and a button pusher.
Another thing to remember is that there are no hard and fast rules about the number of points to take for a feature. You have to have some prior knowledge about how true a feature type typically is for a particular process. You also have to be aware of your tolerances and adjust the number of points accordingly.
True Position
I will agree with the previous person. The most important part of using a CMM is knowing how to do the same measurement on a surface plate, and knowing exactly what the print is telling you.
While my software background isn't as extensive as Kingsld1's, he is basically right, probing a circle is pretty much the same all around.
As to how many points? I've found a thousand per 25 mm of circumfrance per helix and 3 rotations minimum is generally quite accurate for bores.
John Nabors - 2009
I completely agree with you. Back in my machinist days I saw that a person who had extensive experience with manual machines and a little bit of training on a CNC could easily show better quality and overall productivity than a person with extensive G-code training who was clueless about how to make a chip.
But then I am biased - I cut my teeth on a Archer knee mill and a Hardinge toolroom lathe.
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Designing new gauge tracking software IATF 16949 - Automotive Quality Systems Standard 4
A Leadership Role in Designing QMS - Upper Management Support Quality Manager and Management Related Issues 16
S Designing the experiment with minimum run Statistical Analysis Tools, Techniques and SPC 0
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
F Designing a Hollow Medical Device for Autoclavability Other Medical Device and Orthopedic Related Topics 2
Claes Gefvenberg Designing Supplier Questionnaire Forms Supplier Quality Assurance and other Supplier Issues 25
M Designing a Quality Assurance and Control System Quality Manager and Management Related Issues 3
P Sheet Metal Design: Standard method for designing Electrical Knockouts Design and Development of Products and Processes 7
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Line Balance Simulation when Designing a New Production Line Lean in Manufacturing and Service Industries 1
D Designing a Training Course called "Role of the Laboratory Quality Manager" Training - Internal, External, Online and Distance Learning 13
A Designing a Documents Control System from scratch (in a php intranet) Document Control Systems, Procedures, Forms and Templates 5
K Designing a gauge to check the Axis of Snorkel of Axles Design and Development of Products and Processes 5
A Designing a Closed Loop Water System using Adiabatic Cooling Towers Manufacturing and Related Processes 5
R AS9100C Clause 7.3 Design & Development - Designing a System and Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S API Std 620 vs. API 650 standard? Which is the least restrictive in designing a tank? Manufacturing and Related Processes 1
A Designing an Ethylene Oxide Sterilization Process Other Medical Device Regulations World-Wide 7
M Designing a Nonconformance Management Process Nonconformance and Corrective Action 35
Q Are there any threads specifically concerned with designing with AutoCAD? Design and Development of Products and Processes 1
P Designing a "part-specific" Receiving Gauge - Gauge first or job? Design and Development of Products and Processes 4
C Designing Control Charts - Variable with Small Variation and Tight Control Limit Statistical Analysis Tools, Techniques and SPC 20
C Designing control chart for non-normal variables Statistical Analysis Tools, Techniques and SPC 3
A Is the Assembly of the Prototype after Designing considered a Production Process? Design and Development of Products and Processes 11
M Designing a scope for APQP Design and Development of Products and Processes 2
D Designing an ISO 9001 Internal Audit Training Course - Need Help Internal Auditing 6
S Project Management QMS - Manufacturing and Designing of Special Purposed Machines Design and Development of Products and Processes 5
L Categories for data collection - Designing a form for when errors occur Nonconformance and Corrective Action 6
J Designing a Mil-Std-105 or ANSI/ASQ Z1.4 Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 49
R Designing and building our own machines Design and Development of Products and Processes 5
V Designing an integrated ISO 9000 - ISO 14000 System in a Big Marine Port Design and Development of Products and Processes 3
S US Success in Designing & Manufacturing World-Class Goods Design and Development of Products and Processes 2
Claes Gefvenberg Document control applications - Be very wary about designing your own Document Control Systems, Procedures, Forms and Templates 4
F 8.2.1 Customer Satisfaction - Designing & Building a Solid waste disposal facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
O Need documentation - Designing a data acquisition system for the enviromental chamber Design and Development of Products and Processes 3
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Test failure Root cause not found Customer Complaints 10
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
