Designing new gauge tracking software
jimmymustang06
We have used GageTrak for many years, but it has become so bloated with "features" that we don't, and won't, use. The whole thing is just cumbersome having to navigate through the various windows and tabs of stuff we don't use. Our IT manager is pretty slick and has programmed many of our UI's on the floor in which measurements are recorded and saved. So to make a long story a bit longer, we are wanting to made a program in our MRP package whereby we could track our gauge calibrations more efficiently only needing to enter information we need to ensure our gauges are still giving us the correct readings.
I'm unclear about what all has to be recorded and still be in compliance with IATF. So far in the "Gage Records" part of the database, We're asking for: gauge ID, description, location (workstation), last cal date, next cal date (calculated), gauge ID of standard. Then in the calibration section of the database: gauge ID, gauge ID of standard, date, standard measurement, gauge measurement before, gauge measurement after. I would imagine we could color-code the measurement field so that if the entered value is not in tolerance, the field would turn red.
For the most part, our gauges are hand-held OD and tubing wall micrometers and calipers. We don't "calibrate" gauges, with regards to "fixing" them to measure correctly again. We basically verify that they are still measuring in tolerance. If they are not, most times, we scrap them and buy new. Our bigger machines (tensile testers, comparators, rockwell hardness etc are calibrated by either OEM's or outside labs.
I guess I'm wondering how much of the measurements, taken during calibration, do we have to record? Is the info above enough?
If you do not get a response, you may want to ask a mod/admin to move this thread to the calibration sub-forum.
John C. Abnet
Teacher, sensei, kennari
Good day @jimmymustang06 ;
So, one key point that it appears you may already understand is the difference between the term "verification" and "calibration". From your description it sounds as if your organization is not equipped to calibrate, but only verify your measurement equipment. If I am correct in this understanding, then I would council that your internal documentation/claim is for periodic verification and you leave calibration to a laboratory set up/certified to do that.
In regards to if your system has "...enough" per your original post.
ISO 17025 is EXTREMELY specific in regards to what is needed specific to the act of calibration and record keeping of calibration activities. If you are not familiar with ISO17025 (certainly not necessary), it may be helpful for you to own/review that standard in order to assist your understand of "calibration" requirements, simply for the purpose of giving you some perspective.
IATF 9001 7.1.5.2 and 16949 7.1.5.2.1 are pretty specific regarding what IS required. As you can see, it is not so specific about "calibration", but it is specific about ensuring that the devices used are identified, traceable (when required) to the measurements made, be validated as to being the proper tool (7.1.5.1.1= MSA) , taken out of service if/when damaged/out of calibration, notification to customer and containment of any potential product shipped, etc..etc..etc...
Remember the authors and intent. IATF 16949 is all about the OEM receiving conforming product. ISO 17025 (likely not a direct requirement for your organization), is all about the handling and calibration of the measurement systems.
Summary:
Identify your measurement tools. Determine when they need verified (think tape measure vs OD mic). Verify them as determined. Keep records. React and record/contain/recall product if/when a measurement tool is determined to have been measuring wrongly.
Here are some previous discussion links you might find helpful...
Definition - Calibration vs. Verification of Calibration vs. Verification - Definitions
Definition - Calibration vs. Verification - Definition of
Verification vs. Validation vs. Calibration - What is the difference?
Hope this helps.
Be well. (and safe)
"Verification" in this sense is a form of calibration. Calibration is comparison to a standard and may or may not involve adjustment and specific record-keeping.
John C. Abnet
Agree fully Jim. Just hoping to point out that there are additional requirements of a calibration lab over and above what it appears the OP organization is performing. Indeed, there are some simple semantics to the actual terms, but as we know certified calibration requires a whole additional level of requirements. Hoping not to confuse the terms.
Thanks for adding this clarification.
Be well. (and safe)
K Designing a gauge to check the Axis of Snorkel of Axles Design and Development of Products and Processes 5
P Designing a "part-specific" Receiving Gauge - Gauge first or job? Design and Development of Products and Processes 4
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Leadership Role in Designing QMS - Upper Management Support Quality Manager and Management Related Issues 16
S Designing the experiment with minimum run Statistical Analysis Tools, Techniques and SPC 0
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
F Designing a Hollow Medical Device for Autoclavability Other Medical Device and Orthopedic Related Topics 2
Claes Gefvenberg Designing Supplier Questionnaire Forms Supplier Quality Assurance and other Supplier Issues 25
M Designing a Quality Assurance and Control System Quality Manager and Management Related Issues 3
P Sheet Metal Design: Standard method for designing Electrical Knockouts Design and Development of Products and Processes 7
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Line Balance Simulation when Designing a New Production Line Lean in Manufacturing and Service Industries 1
D Designing a Training Course called "Role of the Laboratory Quality Manager" Training - Internal, External, Online and Distance Learning 13
A Designing a Documents Control System from scratch (in a php intranet) Document Control Systems, Procedures, Forms and Templates 5
A Designing a Closed Loop Water System using Adiabatic Cooling Towers Manufacturing and Related Processes 5
R AS9100C Clause 7.3 Design & Development - Designing a System and Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S API Std 620 vs. API 650 standard? Which is the least restrictive in designing a tank? Manufacturing and Related Processes 1
A Designing an Ethylene Oxide Sterilization Process Other Medical Device Regulations World-Wide 7
M Designing a Nonconformance Management Process Nonconformance and Corrective Action 35
Q Are there any threads specifically concerned with designing with AutoCAD? Design and Development of Products and Processes 1
C Designing Control Charts - Variable with Small Variation and Tight Control Limit Statistical Analysis Tools, Techniques and SPC 20
C Designing control chart for non-normal variables Statistical Analysis Tools, Techniques and SPC 3
A Is the Assembly of the Prototype after Designing considered a Production Process? Design and Development of Products and Processes 11
M Designing a scope for APQP Design and Development of Products and Processes 2
B Designing a Test Part to Assess CMM Operator's Knowledge Design and Development of Products and Processes 9
D Designing an ISO 9001 Internal Audit Training Course - Need Help Internal Auditing 6
S Project Management QMS - Manufacturing and Designing of Special Purposed Machines Design and Development of Products and Processes 5
L Categories for data collection - Designing a form for when errors occur Nonconformance and Corrective Action 6
J Designing a Mil-Std-105 or ANSI/ASQ Z1.4 Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 49
R Designing and building our own machines Design and Development of Products and Processes 5
V Designing an integrated ISO 9000 - ISO 14000 System in a Big Marine Port Design and Development of Products and Processes 3
S US Success in Designing & Manufacturing World-Class Goods Design and Development of Products and Processes 2
Claes Gefvenberg Document control applications - Be very wary about designing your own Document Control Systems, Procedures, Forms and Templates 4
F 8.2.1 Customer Satisfaction - Designing & Building a Solid waste disposal facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
O Need documentation - Designing a data acquisition system for the enviromental chamber Design and Development of Products and Processes 3
M Why do we call it "Gauge" R&R Quality Tools, Improvement and Analysis 1
CaliperJim Double Ended Thread Plug Gauge Calibration General Measurement Device and Calibration Topics 9
C Pressure Gauge Calibration General Measurement Device and Calibration Topics 3
J Gauge Management - with ambiguous requirements & no support ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Gauge R&R Question Using Minitab Software 1
J Gauge Suggestion: Specialty or Custom General Measurement Device and Calibration Topics 1
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
