Destructive Gage RR - Using Crossed - want your thoughts
speedworks
Hi, I am analyzing a Gage RR result, in a thermoforming process (plastic sheet run through a mold), and chose to select my part variation by selecting different mold cavities. I chose to have 10 parts, 3 ops, 2 repeats. The 10 parts (cavities) were selected from the mold that provided the most part variation. I chose cavities that produced the highest, lowest and in the middle range. I then made an assumption that each consecutive shot would represent a common part - ie, each cavity 3 for six consecutive shots represented the same part. So my repeats are created by consecutive cavities. I didn't select my parts until the machine had been stabilized (but recognize there could be some material variations). So, here is my question, since I am making the assumption that the 6 consecutive shots represent the same part (by cavity), I should be able to analyze the gage using a crossed method. By the way, the product is PET, and the test involves instron machines. Any thoughts or feedback? Thanks in advance.
speedworks
Hi Miner, I saw your posts, but I am not sure I agree. I think you can use a Crossed method, when the assumption is that you have created 'like' products (to represent the same part). The minitab statguide shows that as well. I think Nested is used when you can't set it up like that or make that assumption. Help me understand your thoughts on it. I too have been heavily involved with gage rrs and noticed you prefer only a nested analysis, but other searched have come up to similar thoughts of what I am suggested. Just want more insight. I also think using the different cavities is giving me my part to part.
I reviewed Minitab's StatGuide and found the guidance to which you referred. While I agree with the guidance in principle, you are applying it is a different mode from which it was intended. It could still work, but the assumptions depend heavily on whether the consecutive runs on a single cavity are indeed similar enough to claim that they are the same part. Do you have data that supports this assumption?
If I were running the analysis, I would run it using both approaches, compare the results and explore any differences. Since you appear to have Minitab and the effort involved in performing the Nested R&R is no different from the Crossed study, why are you reluctant to use it? The nested study is actually more sensitive than the crossed study if you assumptions are incorrect.
speedworks
I don't think I have it set up like a nested design, and am not sure it makes sense in my design. Nested would assume that 2 consecutive cavities are the same for one operator, and if that is the case, I should just assume that all 6 consecutive are the same. These are high speed machines, so the least amount of variation will come with that scenario.
speedworks
Unfortunately, I don't think I have the data, because this org has never done a gage RR; I'm new to the company and am bringing in opex tools and programs. Can't trust the data to see if it is the same anyway.
your assumption that sequential part from the same cavity of a high speed injection molding process will be almost identical is a good assumption.
as with any assumption, only the data will tell you the truth. I have used this very approach for similar - and exact - situations and have performed the study as a crossed study. (but I always check the graphical results and put less emphasis on the statistic that is calculated...). When my assumption is wrong it is clear in the graph and I redo the study - or sometimes jus the analysis as nested...
Miner's point is well taken: perform the study and the analysis both ways. then you will see...
speedworks
Bev, thanks for more insight. The process is Thermoforming PET vs injection molding, but feel the assumption is valid. I did run it both ways, but I think I have it set up wrong in Mtb for the nested way, since I number each part the same (for each cavity). How would you do it otherwise?
Also, would like to hear your thoughts on what I should look at, at the results to determine if either is a better analysis.
That is the issue. In Minitab, select File > Open Worksheet > Look in Minitab Sample Data Folder > Select GAGENEST.MTW > Open then look at how the parts are numbered in the worksheet.
In your example, number parts for operator 1 as 1 - 10, for operator 2 as 11 - 20, and for operator 3 as 21 - 30.
T Destructive Tensile Test Sampling Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B GR&R (Gage R&R) for Destructive Test - Question on how to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Gage R&R Destructive UTS Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Destructive/Non-Repeatable Measurement Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Nested vs. Crossed Gage R&R Models for Destructive Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Gage R&R studies for Destructive Test Devices (pull and push tests) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Y Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
F Gage R&R Destructive Test With Breakaway Fixture To Simulate A Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Destructive Tensile Pull Test Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G Destructive test, gage R&R with one sided tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Destructive Testing GR&R (Gage R&R) - Track tester - JMP Program Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Gage R&R - Destructive Test - Tensile Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
S How do I do Gage R&R in Destructive Testing? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Gage R&R (Repeatability and Reproducibility) Destructive Test Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Procedure on how to conduct a Destructive MSA (Gage R&R) for Force Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Gage R&R - Destructive Test - Pharmaceutical industry - Tablet hardness Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Gage R&R for a Destructive Test - Weld Breakout Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B We found a Gage R&R for Destructive Methods Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Destructive Gage R&R method for a glass factory study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Gage R&R Destructive Tests - Tensile tester to check for paper strength Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O How to do Destructive Test Gage R&R - Rupture Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 28
B GR&R Destructive Data Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
armani Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S About NDT (Non-Destructive Testing) and ISO 17020 Other ISO and International Standards and European Regulations 4
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Samples for a Destructive Test included in a Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Destructive Test Sample Size Reduction Statistical Analysis Tools, Techniques and SPC 10
