"Destructive" Linearity Study Methodology
Calibrator24
Is there a "destructive" Linearity study? How does the study being conducted and what type of instruments does this type of study applicable?
The methods of selecting specimens (i.e., split, consecutive, etc.) will work as well for linearity studies as for R&R studies if parts must be used. However, linearity studies should be performed using standards unless there is some reason that that is not feasible.
What type of measurement system are you trying to assess?
Calibrator24
So, would it mean that if accurate standards are available, and Linearity study can be done with these standards, there is no need to do the destructive method using the actual parts?
I raised this question because I got confused with what I've learned from a friend when during one of their audit in TS16949, the auditor looks for a linearity study of their wirepull tester using the destructive method though they were able to show results using accurate standards similar to what they were using in calibration. The auditor reasoned out that the linearity study has to be done by simulating their testing process. Seems absurd to me. Correct me if I'm wrong but for me the best way to determine the linearity is to use a traceable, known standard to determine the bias of an instrument over the entire measuring range.
You are correct. Bias, Linearity and Stability studies are to be done with standards if at all possible. If standards are not available, a Master part may be used, but this is not the ideal situation. R&R studies must be performed using actual product.
I would challenge the auditor to show where in the MSA manual it states to use parts for Linearity studies. Reasoning it out just does not cut it.
cruss
I can tell you what was my case. The auditor was asking me for a pull tester MSA study. I used a simple machine capability study excel sheet , and the samples taken with the "Split sample " method ( 10 metters of wire devided on 50 pieces :notme:) , and the result was OK. Also the auditor put OK in the report.
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 2
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S About NDT (Non-Destructive Testing) and ISO 17020 Other ISO and International Standards and European Regulations 4
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
S Destructive Gage RR - Using Crossed - want your thoughts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
T Destructive Tensile Test Sampling Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Samples for a Destructive Test included in a Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Destructive Test Sample Size Reduction Statistical Analysis Tools, Techniques and SPC 10
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Looking for A Non-Destructive Crimp Test method to replace Pull Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
E Sequence of Operations - Non-Destructive Testing vs. Trim & Drill Manufacturing and Related Processes 2
C Prices for NDT (Non-Destructive Testing) Inspection for a Boeing 737-400 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B GR&R (Gage R&R) for Destructive Test - Question on how to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Gage R&R Destructive UTS Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Destructive Test Sample Size Determination Statistical Analysis Tools, Techniques and SPC 4
A Performance Qualification For Destructive Testing (Impact Testing) Qualification and Validation (including 21 CFR Part 11) 4
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M What Sample Size for Destructive Test and is 'T' Test applicable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Destructive/Non-Repeatable Measurement Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Batch Acceptance: Cpk requirements and Sample Size - Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Nested vs. Crossed Gage R&R Models for Destructive Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Destructive Attribute MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Gage R&R studies for Destructive Test Devices (pull and push tests) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
hogheavenfarm Cyclic Destructive Testing - Continuous vs. Segments Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
D Project to Reduce Destructive Sampling in Crimping Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Y Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B MSA Study on Test Rig Constraints - Destructive, Long Duration Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Non Destructive Testing of plain Carbon steel castings using Eddy Current Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
F Gage R&R Destructive Test With Breakaway Fixture To Simulate A Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Sampling plan for destructive test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
