Destructive Non Reproducibility MSA (Measurement System Analysis)
rdanis
Hello experts,
is it good to do a destructive and non reproducibility MSA (repeated with single operator only)?
Re: Destructive non reproducibility MSA
yes, unless its not. :)
can you provide a few more details: what is the test method, is it used at incoming in-process or final inspection,,what is the product, any Customer requirements (APQP, etc.)...this help us provide a better answer.
rdanis
It's a breaking strength inspection of extruded tiles (final sampling inspection). We take 5 pcs tiles and use breaking strength machine to know the breaking strength of the tiles. The spec is 1500 N minimum.
I've read Miner's blog and planned to take 30 pcs consecutive produced tiles (expect from 1 batch material mixing) as testing specimen. So what is the next to do? What are the points to be considered in conducting this type MSA?
not sure 30 consecutive is good. from previous data do you get the full range of process variation within 30 tiles? if not consider 2 pairs of consecutive tiles taken from across a lot or multiple lots. if the largest range of variation is seen within a lot you only need a single lot. if the largest range of variation is across multiple lots you will need multiple lots. (there is a way around this but it is better to have your samples come from a representative range of product.
the 2 consecutive pairs become your 'repeated' measures. (you may also need to consider what constitutes 'consecutive' if you use a grid fixture...understanding the next level of process details will help with defining what consecutive really means.
on the other hand if you feel comfortable that the 30 consecutive pieces are representative full range of variation or for some reason you can't take other samples, you could consider breaking the tiles in half and using the halves as your repeated measures.
rdanis
Bev,
I can say 30 pcs consecutive products will not represent the range of the product.
We batch around 70-78 times a day. When we do the next batching, we don't empty the bin from the previous batching.
About selecting multiple lots, We should consider material and process environment characteristic, such as sand moisture, temperature during the curing process and temperature on the yard stocking. The variation may become larger and larger.
Splitting the tiles seems to be not good idea since there is a standard dimension for tile. Cutting the tiles may lead to different broken strength value since (may be) the cutting process it self may affected the strength characteristic and also the tile is shorter.
At first, I want to take the first 30 pcs at the beginning of production process in the morning, but now I'm seeking the better method how to choose the sample, need advice on that.
PS:
I don't fully understand about this statement:
"(you may also need to consider what constitutes 'consecutive' if you use a grid fixture...understanding the next level of process details will help with defining what consecutive really means"
what constitutes 'consecutive' for you?
are the tiles extruded through only one 'cavity' or are they from multiple cavities? the idea of consecutive for destructive testing is that the two consecutive tiles are as alike as possible. same material, same process conditions, etc. so two tiles extruded consecutively form the same 'cavity' are consecutive, but two tiles extruded at the same time from side-by-side cavities probably are not as similar...
rdanis
Bev,
Yes, the tiles are extruded through only one 'cavity'. It's a continuous extrusion which then being cut into pieces of tiles. The extrusion materials are continually batched 70-78 times per shift during the production process.
thanks that makes sense...and consecutive tiles are teh best choice for your 'repeating' pairs.
rdanis
Hello Bev,
Where I can find a good nested MSA template for 10X1X3 (parts=10, appraiser=1 and trials=3) design?
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
armani Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S About NDT (Non-Destructive Testing) and ISO 17020 Other ISO and International Standards and European Regulations 4
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S Looking for A Non-Destructive Crimp Test method to replace Pull Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
E Sequence of Operations - Non-Destructive Testing vs. Trim & Drill Manufacturing and Related Processes 2
C Prices for NDT (Non-Destructive Testing) Inspection for a Boeing 737-400 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Destructive/Non-Repeatable Measurement Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Non Destructive Testing of plain Carbon steel castings using Eddy Current Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R NDT (Non-Destructive Testing) - How I can get at least Level 1 certified? Professional Certifications and Degrees 4
D 76/211/EEC 2.3.3.1 Criteria for Non-Destructive Testing Statistical Analysis Tools, Techniques and SPC 2
G Destructive Testing MSA - Weld Bond Pull - Both destructive and non destructive Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
B GR&R Destructive Data Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
S Destructive Gage RR - Using Crossed - want your thoughts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
T Destructive Tensile Test Sampling Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Samples for a Destructive Test included in a Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Destructive Test Sample Size Reduction Statistical Analysis Tools, Techniques and SPC 10
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B GR&R (Gage R&R) for Destructive Test - Question on how to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Gage R&R Destructive UTS Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Destructive Test Sample Size Determination Statistical Analysis Tools, Techniques and SPC 4
A Performance Qualification For Destructive Testing (Impact Testing) Qualification and Validation (including 21 CFR Part 11) 4
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C "Destructive" Linearity Study Methodology Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M What Sample Size for Destructive Test and is 'T' Test applicable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Batch Acceptance: Cpk requirements and Sample Size - Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Nested vs. Crossed Gage R&R Models for Destructive Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Destructive Attribute MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Gage R&R studies for Destructive Test Devices (pull and push tests) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
