Destructive Tensile Pull Test Gage R&R
H
HRinAZ
Need help with performing a gage R&R for a destructive test (tensile pull).
Any help, pointers, spreadsheets will be much appreciated.
Thanks.
HR
H
HRinAZ
The information on the prior posts did not help me as much as I thought they would. I do not have the AIAG MSA manual, I am in a different industry. Thanks for your suggestions.
HR
Hershal
Metrologist-Auditor
First question.....how is your UTM calibrated? If under ASTM E 4 then the machine part is established at 1%.
Hope this helps.
Hershal
H
HRinAZ
I read through all the threads and it provided a lot of information but not a very basic procedure. So based on all my readings and discussions here is what I intend to do:
Take four consecutive samples from 5 consecutive lots.
Get 2 operators and use 2 samples from each lot and have the 2 operators conduct the destructive test.
Perform the Gage R&R.
The four consecutive samples gives the best chance of getting parts that can be assumed to be relatively close to identical.
The 5 consecutive lots gives the opportunity to evaluate between group (part to part) variation. In this case, variation between lots.
Using MINITAB - Stat>>Quality Tools>>Gage Study>>Gage R&R(crossed) function using the ANOVA method, this should provide us with data on GRR, EV, AV, PV, and DNC. From that we can determine if the measuring system is capable of controlling the testing process.
Also if I get unusual results from the total variation function, the plan is to look at the results with respect to tolerance to get a better look at the performance of the measurement system.
The criteria for determining if the measurement passes the Gage R&R is the lesser of %R&R to total variation and %R&R to tolerance.
Ceplox maniz
Dear all,
I'm new in MSA study especially for destructive test.
According to summary discussion from HRinAZ, where the statement of "Take four consecutive samples from 5 consecutive lots." come from?
Why 5 consecutive lots instead of 3 or 6 consecutive lots?
Regards,
Ceplox
sowmya
Involved - Posts
Its new to me also. We are checking pull strength for terminals. Till now, we have said as it is destructive we cannot conduct MSA. Is that applicable to this also????????
I dont have minitab to do as HR said. Can anybody help me out?
thanks to HR for starting this.
Sowmya
DavidPhillips
I am not an expert on R&R study but I think there is some important new data which might help with the validation of tensile testing equipment in the future.
For tensile testing machines there are three or four variable factors:
1) Measuring sensors (load cell, Extensometer, and transverse strain extensometer - if you are calculating r values). All of these devices can be calibrated (or verified) to International Standards by your testing machine supplier.
2) Software. Up to now there was no way to check if the software uses the correct algorithms when measuring offset yield, UTS, r value, etc. so it was necessary to use standardised sample / specimens.
The EU is introducing TENSTAND standard data sets which can be imported into the testing software. The software then calculates the results using the internal algorithms, and the results checked for accuracy and consistency. Most reputable testing machine manufacturers will already be aware and have the possibility to support this concept.
For more information go to www.npl.co.uk/materials/projects/tenstand/outputs.html
T Destructive Tensile Test Sampling Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
W MSA for Destructive Testing - Tensile tester - Welding Processes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M MSA Study for tensile tester - Its difficult to do an MSA study on a destructive test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Gage R&R - Destructive Test - Tensile Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
O MSA for Destructive Tests - Tensile test as an example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Gage R&R Destructive Tests - Tensile tester to check for paper strength Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B GR&R Destructive Data Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S About NDT (Non-Destructive Testing) and ISO 17020 Other ISO and International Standards and European Regulations 4
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
S Destructive Gage RR - Using Crossed - want your thoughts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Samples for a Destructive Test included in a Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Destructive Test Sample Size Reduction Statistical Analysis Tools, Techniques and SPC 10
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Looking for A Non-Destructive Crimp Test method to replace Pull Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
E Sequence of Operations - Non-Destructive Testing vs. Trim & Drill Manufacturing and Related Processes 2
C Prices for NDT (Non-Destructive Testing) Inspection for a Boeing 737-400 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B GR&R (Gage R&R) for Destructive Test - Question on how to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Gage R&R Destructive UTS Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Destructive Test Sample Size Determination Statistical Analysis Tools, Techniques and SPC 4
A Performance Qualification For Destructive Testing (Impact Testing) Qualification and Validation (including 21 CFR Part 11) 4
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C "Destructive" Linearity Study Methodology Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M What Sample Size for Destructive Test and is 'T' Test applicable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Destructive/Non-Repeatable Measurement Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Batch Acceptance: Cpk requirements and Sample Size - Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Nested vs. Crossed Gage R&R Models for Destructive Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Destructive Attribute MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
