Destructive test, gage R&R with one sided tolerance
Status
Not open for further replies.
G
gavinqce
Help
How do I complete a gage R&R study on a test that is destructive to the sample. By the way, the acceptance criteria is a single sided, minimum, tolerance!!
Any clues greatly appreciated
Gavin
gavinqce said:
Help
Gavin
See my response to your other post on the one-sided tolerance.
On the destructive test, the MSA 3rd edition manual has a section on destructive MSA's.
In brief, You should select your parts as follows:
The samples for Part 1 (that will be repeated by a single operator, and those to be reproduced by another operator) should come from as nearly a homogeneous sample/batch as possible.
The samples used as Part 2 should be from a different batch, different production run, or have sufficient time to allow long term variation to occur.
Repeat for Part 3.
Status
T Destructive Tensile Test Sampling Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B GR&R (Gage R&R) for Destructive Test - Question on how to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Gage R&R studies for Destructive Test Devices (pull and push tests) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
F Gage R&R Destructive Test With Breakaway Fixture To Simulate A Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Destructive Tensile Pull Test Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Gage R&R - Destructive Test - Tensile Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
B Gage R&R (Repeatability and Reproducibility) Destructive Test Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage R&R - Destructive Test - Pharmaceutical industry - Tablet hardness Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Gage R&R for a Destructive Test - Weld Breakout Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O How to do Destructive Test Gage R&R - Rupture Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 28
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
S Samples for a Destructive Test included in a Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Destructive Test Sample Size Reduction Statistical Analysis Tools, Techniques and SPC 10
S Looking for A Non-Destructive Crimp Test method to replace Pull Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
A Destructive Test Sample Size Determination Statistical Analysis Tools, Techniques and SPC 4
M What Sample Size for Destructive Test and is 'T' Test applicable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B MSA Study on Test Rig Constraints - Destructive, Long Duration Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Sampling plan for destructive test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Sample Size in Destructive Pull Test and Interpretation of Test Result IATF 16949 - Automotive Quality Systems Standard 5
E MSA requirement for destructive Pull out test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M MSA Study for tensile tester - Its difficult to do an MSA study on a destructive test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E Acceptance Sampling to be used for Lot Acceptance - Destructive Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Destructive Test MSA's - Mechanical properties of adhesives Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA for Destructive Tests - Tensile test as an example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Destructive testing: How to determine starting level in Bruceton test? General Measurement Device and Calibration Topics 1
B GR&R Destructive Data Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S About NDT (Non-Destructive Testing) and ISO 17020 Other ISO and International Standards and European Regulations 4
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
S Destructive Gage RR - Using Crossed - want your thoughts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
