Destructive Test Sample Size Determination
Apoch
I am faced with a task to determine the sample size required from a bunch of test fall-outs that are to to be subjected to destructive tests. Question is how shall I come up with this figure?
I was thinking of generating an OC curve based on LTPD. But the thing is, the population is from a bunch of failed units. Hence, LTPD is not applicable.
Any inputs guys?
Stijloor
Any inputs guys?
Suggestions anyone?
Thank you!!
Stijloor.
Jen Kirley
Quality and Auditing Expert
Good day,
Unless I misunderstood you, you are testing failed units. If that's the case, testing units that fell out isn't destructive sampling, it's failure analysis. In failure analysis the unit is dissected and examined forensically for the cause of its defect.
But if you are interested in destructive test sampling out of good units, there are threads like Sampling Plan for Destructive Testing - Personal Body Armor Plates. When looking at that thread, please also look at the links to related threads at the bottom of the page.
I hope this helps!
Jennifer makes a lot of good points. Other considerations include whether this generates variable or attribute data. As stated, this sounds like failure analysis. In this you may be trying to characterize some physical properties and perform a hypothesis test, or to quantify the relative proportions of different failure modes. The type of data and the purpose of the testing all influence the required sample sizes.
quickly because it's late: there is a similar thread here titled "sample size for rejected units". there is good advice in this series for your question.
bottom line - there is no reason for fancy statistics. take some of each failure mode (test parameter failed) and see what you get. sometimes we spend too much time on the fancy math on not enough on the good engineering of discovery.
A Destructive Test Sample Size Reduction Statistical Analysis Tools, Techniques and SPC 10
M What Sample Size for Destructive Test and is 'T' Test applicable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Sample Size in Destructive Pull Test and Interpretation of Test Result IATF 16949 - Automotive Quality Systems Standard 5
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Destructive Tensile Test Sampling Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
S Samples for a Destructive Test included in a Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Looking for A Non-Destructive Crimp Test method to replace Pull Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B GR&R (Gage R&R) for Destructive Test - Question on how to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Gage R&R studies for Destructive Test Devices (pull and push tests) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B MSA Study on Test Rig Constraints - Destructive, Long Duration Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
F Gage R&R Destructive Test With Breakaway Fixture To Simulate A Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Sampling plan for destructive test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
H Destructive Tensile Pull Test Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
G Destructive test, gage R&R with one sided tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E MSA requirement for destructive Pull out test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M MSA Study for tensile tester - Its difficult to do an MSA study on a destructive test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E Acceptance Sampling to be used for Lot Acceptance - Destructive Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Gage R&R - Destructive Test - Tensile Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
B Gage R&R (Repeatability and Reproducibility) Destructive Test Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Destructive Test MSA's - Mechanical properties of adhesives Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O MSA for Destructive Tests - Tensile test as an example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Gage R&R - Destructive Test - Pharmaceutical industry - Tablet hardness Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Gage R&R for a Destructive Test - Weld Breakout Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Destructive testing: How to determine starting level in Bruceton test? General Measurement Device and Calibration Topics 1
O How to do Destructive Test Gage R&R - Rupture Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 28
B GR&R Destructive Data Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S About NDT (Non-Destructive Testing) and ISO 17020 Other ISO and International Standards and European Regulations 4
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
S Destructive Gage RR - Using Crossed - want your thoughts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
