Destructive Testing Failure Mode Sampling Plan
Aileen84
I've been trying to find answers on my own but to no avail.
We just proposed a sample size reduction to our customer on one of the destructive tests that we are doing.
Now, our customer wants to incorporate the failure mode in the sampling plan.
Acceptable: After pull test, it should break in the middle
Failed: Lifted after pull test
Actual data/process performance: 100% break in the middle
Our customer wants to see analysis that our proposed sample size reduction makes sure that it will be able to detect if there are failures (i.e. lifted) after destructive test.
So i tried the AQL, LTPD, Zero acceptance sampling plan.. but I ended up not knowing how to proceed.
Other infos:
Customer's AQL = 0.1%, Level II, Acc=0 for visual inspection.
The answer could just be in front of me but I'm missing it. :(
I hope someone could give input how to close this. Thanks in advance!
Well you could use the reduced sample size code letters but I think the real issue facing you is that most commonly published tables dont' have a .001 AQL level (.1% = .001). that's pretty tight
I have an AQL/RQL spreadsheet that I have updated and attached to this post. It adds a tab for determining the AQL and RQL levels for varying sample sizes (n) fro a c=0 plan (Thanks to Statistical Steven for posting the derivation and formulas last year!!)
If you use the tab "AQL RQL levels fro varying n" and enter the confidence levels you want for the AQL and RQL levels it will provide you a series of sample sizes and their associated AQL and RQL levels.
for example, for a confidence level of 95% for the AQL and RQL levels, a .1% AQL is achieved with a sample size of 50. the corresponding RQL is 6%, meaning that you will reject a lot that is 6% defective 95% of the time it's present.
Aileen84
Thanks Bev D. This is a really helpful template. I am wondering if I can also use the 'c=0 Sample Plan Generator'? If yes, at what distribution should I based my analysis - Poisson or Binomial?
Also, given that I don't have reject from the start, what is the appropriate p value I should use?
Thanks once again!
supreecha
Acceptance Sampling by Attributes
Measurement type: Number of defects
Lot quality in defects per unit
Lot size: 50
Use Poisson distribution to calculate probability of acceptance
Acceptable Quality Level (AQL) 0.1
Producer's Risk (Alpha) 0.05
Rejectable Quality Level (RQL or LTPD) 50
Consumer's Risk (Beta) 0.1
Generated Plan(s)
Sample Size 1
Acceptance Number 40
Accept lot if number of defects in 1 items <= 40; Otherwise reject.
Defects Probability Probability
Per Unit Accepting Rejecting AOQ ATI
0.1 1.000 0.000 0.09800 1.0
50.0 0.086 0.914 4.21743 45.8
Average outgoing quality limit (AOQL) = 0.98000 at 1.00000 defects per unit.
yes you can. but it is an RQL plan generator. so if you put in your .1% AQL then it will give a really large sample size. remember an RQL is the defect rate at which you will detect and REJECT XX% (typically 95%) of the time. The sample size will be 2996. The AQL for this plan (which is generated by default) is 0.000015 or 0.0015% Since your customer's AQL is much larger than that you may not want this plan.
BOTH will be generated. in reality the sampel sizes are usually within 1, so it won't matter much.
OK you can use whatever defect rate YOU want to detect/reject and not ship to the customer. Just be sure to check the corresponding AQL as you wouldn't want to have a higher AQL than your Customer has stated. When you are restricted to a c=0 plan you can typically only specify either the AQL or the RQL and the other level will be whatever it is. When you are not restricted t c=0 then you can specify AQL and RQL and get a sample size that will provide both quality levels. The accept number may be 3 or 4 and while these plans are actually better at providing both you and your customer the protection you need, many people who don't understand get really nervous when you accept a lot that had any defects in the inspection sample. sad but true.
Aileen84
Wow so much to take in! But they are all really good and I appreciate so much the input.
Thank you so much supreecha and Bev D.
I'll work around what you have provided and hopefully see the light at the end of the tunnel. :)
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S About NDT (Non-Destructive Testing) and ISO 17020 Other ISO and International Standards and European Regulations 4
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E Sequence of Operations - Non-Destructive Testing vs. Trim & Drill Manufacturing and Related Processes 2
C Prices for NDT (Non-Destructive Testing) Inspection for a Boeing 737-400 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Performance Qualification For Destructive Testing (Impact Testing) Qualification and Validation (including 21 CFR Part 11) 4
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C Batch Acceptance: Cpk requirements and Sample Size - Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
hogheavenfarm Cyclic Destructive Testing - Continuous vs. Segments Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
R Non Destructive Testing of plain Carbon steel castings using Eddy Current Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Sampling Plan for Destructive Testing - Personal Body Armor Plates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
W MSA for Destructive Testing - Tensile tester - Welding Processes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Destructive Testing GR&R (Gage R&R) - Track tester - JMP Program Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R NDT (Non-Destructive Testing) - How I can get at least Level 1 certified? Professional Certifications and Degrees 4
L Powder used to make neodymium magnets - GR&R for destructive testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Destructive Testing with respect to PPAP submissions APQP and PPAP 4
D 76/211/EEC 2.3.3.1 Criteria for Non-Destructive Testing Statistical Analysis Tools, Techniques and SPC 2
S How do I do Gage R&R in Destructive Testing? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Destructive testing: How to determine starting level in Bruceton test? General Measurement Device and Calibration Topics 1
G Destructive Testing MSA - Weld Bond Pull - Both destructive and non destructive Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
S Destructive Gage RR - Using Crossed - want your thoughts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
T Destructive Tensile Test Sampling Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Samples for a Destructive Test included in a Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Destructive Test Sample Size Reduction Statistical Analysis Tools, Techniques and SPC 10
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Looking for A Non-Destructive Crimp Test method to replace Pull Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B GR&R (Gage R&R) for Destructive Test - Question on how to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Gage R&R Destructive UTS Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Destructive Test Sample Size Determination Statistical Analysis Tools, Techniques and SPC 4
C "Destructive" Linearity Study Methodology Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
