Destructive Testing with respect to PPAP submissions
dbzman
Hello Everyone and Marry Christmas!!
Can anyone tell me how one would deal with distructive testing with respect to PPAP submissions? I know that most PPAP require 300 part sampling for production runs. We don't want to destroy 300 parts.
Thanks!
Mike W
:thanx:
D.Scott
Mike,
The 300 parts are usually for the customer's evaluation, not for testing. Check with your SQE to see what they want tested. When we do destructive torque/tension testing, we normally do 10 parts. Of course if the customer says test 300 and he is paying for it, then 300 it is.
Good luck
Dave
dbzman
1.2.1 Significant Production Run
To adequatly determine if we have meet the customer requirements (the parts are correct) we have to cut them to test them.
section 1.2.1 Significant Production Run, states that a run of 300 parts is required.
Is this for statistical studies at our facility or for submission to the customer?
We are preparing a PPAP for a customer and the part has to have a certain case depth hardness. To follow 1.2.1 w would have to cut 300 parts.
The truck industry allows as small a sample as 30 pieces.
I may be confusing issues.
:thanx:
Mike W
D.Scott
I think you will find that the samples you do your testing on have to come from a production run of at least 300 parts. I am 99.9% sure you don't have to cut 300 parts.
1.2.1 of PPAP gives the minimum size run to take whatever PPAP samples you need. If your customer requires a 100 part sample then they have to come from a production run of at least 300 consecutive parts. Destructive testing is determined by the spec you are working to - sometimes the customer's own, sometimes an OEM or even ASTM, ISO etc. The required number of parts to test will be stated in the test method or by agreement with the customer.
Contact your customer if you are unsure but I urge you not to cut 300 parts until you confirm that's what he wants. The PPAP manual 1.2.1 DOES NOT require 300 samples. It requires you to run a significant enough number to be sure your process is running normally - in this case 300 parts minimum. They don't want you to run 5 parts just because your customer only asked for 5 samples.
Dave
dbzman
Thanks! Thanks! Thanks!
The info you gave me helps a lot!
You help is greatly appreciated.
Mike W
:agree:
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S About NDT (Non-Destructive Testing) and ISO 17020 Other ISO and International Standards and European Regulations 4
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Sequence of Operations - Non-Destructive Testing vs. Trim & Drill Manufacturing and Related Processes 2
C Prices for NDT (Non-Destructive Testing) Inspection for a Boeing 737-400 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Performance Qualification For Destructive Testing (Impact Testing) Qualification and Validation (including 21 CFR Part 11) 4
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C Batch Acceptance: Cpk requirements and Sample Size - Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
hogheavenfarm Cyclic Destructive Testing - Continuous vs. Segments Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
R Non Destructive Testing of plain Carbon steel castings using Eddy Current Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Sampling Plan for Destructive Testing - Personal Body Armor Plates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
W MSA for Destructive Testing - Tensile tester - Welding Processes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Destructive Testing GR&R (Gage R&R) - Track tester - JMP Program Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R NDT (Non-Destructive Testing) - How I can get at least Level 1 certified? Professional Certifications and Degrees 4
L Powder used to make neodymium magnets - GR&R for destructive testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D 76/211/EEC 2.3.3.1 Criteria for Non-Destructive Testing Statistical Analysis Tools, Techniques and SPC 2
S How do I do Gage R&R in Destructive Testing? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Destructive testing: How to determine starting level in Bruceton test? General Measurement Device and Calibration Topics 1
G Destructive Testing MSA - Weld Bond Pull - Both destructive and non destructive Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
S Destructive Gage RR - Using Crossed - want your thoughts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
T Destructive Tensile Test Sampling Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Samples for a Destructive Test included in a Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Destructive Test Sample Size Reduction Statistical Analysis Tools, Techniques and SPC 10
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Looking for A Non-Destructive Crimp Test method to replace Pull Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B GR&R (Gage R&R) for Destructive Test - Question on how to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Gage R&R Destructive UTS Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Destructive Test Sample Size Determination Statistical Analysis Tools, Techniques and SPC 4
C "Destructive" Linearity Study Methodology Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
